Question about Refrigerators
Whirlpool arc 6700
REPLACING EVAPORATOR SENSOR
My Whirlpool microwave over-the-range oven makes a loud roaring sound when it turns on and won't heat.
Sounds like it could be a bad magnetron. The roaring could be a shorted mag or possibly a mag arcing in the wave guide If it is arcing in the wave guide, better to replace the unit.
Nov 01, 2017 | Microwave Ovens
My Whirlpool microwave randomly makes a growling noise (with vibration) when not in use. It seems to be coming from the top above the fan area. Something going out?
sometimes a bad relay on the main timer board will tell the unit to heat with nothing in it and it will arc in the wave guide or antenna area. Arcing sounds like growling or grumbling. "Random" may be from the relay sticking sometimes and then sometimes not. Will destroy the wave guide and the magnetron and the unit could not be repaired. Would have to be replaced if that happens
Aug 12, 2017 | Whirlpool Microwave Ovens
I HAVE A WHIRLPOOL MODEL GI6FDRXXY 07, AND THE EVAPORADOR MOTOR DOESNOT WORKING... IT NO RECEIVE THE 12 V... WHY? A NEED A WIRING DIAGRAM... TO CHECK...
If your evaporator motor is not working, you are so correct. The air circulated in the refrigerator is due to the evaporator motor fan. If left to operate without a fan to provide a heat load for your compressor, it could cause your compressor to fail. Your problem is most likely the defrost sensor inside the cover of your evaporator. It is probably stuck open and will not put power to your evaporator fan. Take you model number to Searspartsdirect.com and find the defrost sensor for your refrigerator and replace it.
Hope this helps
Dec 13, 2014 | Whirlpool GI6FDRXXY
How do i force defrost on this fredge
To check defrost you first need to have an evap coil temp below 32, the thing you replaced was prob the temp sensor for the defrost.
Find the def timer and turn it till it goes into def.
May 15, 2014 | Whirlpool GX5FHDXTS Stainless Steel
Arching battery
You've got a short in your electrical system somewhere. Probably in the starter. Dis you have the key off when changing battery. I;ve had a slight arc when replacing battery but nothing serious. If the arc is a strong arc and you don't hear sensors kicking on, check for shorts.
Jan 25, 2013 | 1995 Chevrolet Corsica
Hi i have a very old 1970? whirlpool electric single oven
It sounds like you burned out the oven heating element control board.
Jul 18, 2017 | Whirlpool Ovens
Whirlpool electric range model rge-6700. Oven lock is locked with oven door open. how can i disengage?
Good the door can open ! Replace the door latch assembly.
Please Rate this!
Jul 06, 2008 | Kitchen Ranges
Whirlpool Side By Side GD5RHAXNQ00-Electrical Issue
The arcing noise is just that, a loose connection causing electricity to arc from one place to another. this is initiated by opening the door and closing the light switch. The small glow is from a small amount of voltage reaching the bulb. If you are inclined, repair it. remove the cover, look for the burnt wire or connection. If its a removable part, replace it. If not clean it up and/or make a new connection. One thing is for sure, it will not get any better and may get worse and burn up something more critical.
Jan 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
