Question about Panasonic KXTGA931S Cordless Phone
Speaker phone shuts phone off
When I press speaker phone the phone goes dead.
How do i check nokia 6070 set dead problem?
Can you please be a little me more clear regarding the problem! Is the phone dead now or the phone randomly shuts down and then after some time is able to boot again?
Oct 08, 2014 | Nokia 6070 Cellular Phone
Philips HTS3440/37
Please elobrate further your problem.. i'm a bit confuse " If I press mute button it goes to mute,press mute again sound will come back on" This is normal.i.e. that is the function of mute button.
Sep 07, 2007 | Philips HTS3440/37 System
How do you take the phone off of speaker setting
There should be a button on the phone with a speaker on it just press that button until speaker goes off
Aug 29, 2012 | Motorola Mobility Quantico
Base appears to be shorted for phone connection. When I first hook phone line up I have a dial tone, but when I press stop on any handset or speaker phone the phone will not disconnect. The line eventually...
I have same problem but it will happen while I am in middle of talking. handset will go dead and say it is not connecting to base, but base indicates line is in use. I try it with other handsets to no avail
Apr 13, 2011 | Panasonic KX-TG9341T Cordless Phone
My phone just stopped ringing. I have checked the volume and it is OK. I have shut it down, removed the battery, then started it back up - no luck. What can I do next?
hi there!
good thing you know how to powercycle a phone, however, if its a hardware issue, you need to then take it out for repair. its possible that the speakers' contacts needs to be checked or replaced if the speakers are already dead.
Apr 12, 2011 | Nokia 2720 Fold Cell Phone
Nokia 2630 .The problem is White screen for 2-3 sec. then turn off .Help pls
1. Check the battery. They may be worn out and dead.
2. Next time, your screen goes blank / white, shut off the mobile voluntarily, restart the phone and press reset button.
3. This will fix the problem. Caution: You may lose all your data.
May 15, 2010 | Nokia 2630 Cell Phone (Unlocked) - Black
I just got my surround sound back from being repaired and when i turn it on it says protection and goes to standby. what am I doing wrong
Disconnect all speakers at the receiver then turn it back on. If it stays on, re-connect speakers one by one and test power. Once you find the connection/speaker that's causing it to shut down, disconnect the speaker at the speaker and test again. That will rule out the wiring as the cause. If it still shuts down, replace that wire. if it powers on and stays on, meter the speaker for a dead short. If your not sure how to do that, take the speaker to any audio retailer or electronics retailer and they will test it for you and generally for free. If you need further help on this, post a comment and I can help you more. Hope this helps.
Oct 30, 2009 | Samsung HT-DS610 System
Power shut off
Plz check the terminals where the battery is connected,sometimes those small metal contactors become pressed & do not make a contact with the battery.Try to pull them out carefully to be in contact with the battery terminals.
Jul 20, 2008 | Sony Ericsson K610i Cellular Phone
Hand set goes dead
Next time it goes dead, try wiggling the cord where it plugs in the handset and where it plugs into the phone. If the problem goes away, you will need a new cord.
Hope this helps, and if so, please rate my advice.
Feb 05, 2008 | RCA 25202RE3 Corded Phone
Phone goes dead
this problem may be of battery loose connection, or some BGA Ic have loose its ball
Jan 14, 2008 | Motorola Mobility RAZR V3
Panasonic KXTGA931S Cordless Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
