Question about Kenmore Dryers
Dryer won't start
I started the dryer, it ran 5 minutes and then the buzzer went off. Now I can't start it at all/
  • 2,113 Answers
Try turning off the 30 amp double breaker and resetting it
Posted on Nov 28, 2013
Buffalo12980
  • 625 Answers
SOURCE: Dryer runs for 5 minutes then stops
look in the vent line for a small disk shaped overload with two wires coming out of it. it may be bad. also check for a lint build-up in the exhaust line out of the blower. check the damper outlet going out of the house for a build-up of lint.
Posted on Aug 21, 2007
Jimster
  • 240 Answers
SOURCE: kenmore 70 series model # 96573220
Sounds like the push to start switch has gone bad. Not to expensive to fix, and pretty easy to do as well. You can remove the rear of the console, remove the push to start switch (lift the tab, then turn to unlock) and replace. Be sure to mark your wires so they go back in the right order. Jim
Posted on Nov 18, 2007
  • 12 Answers
SOURCE: Dryer stops after 5 minutes
dryer moter is covered with lint and over heating.if the moter is not completely burned out `you mite clean it with air pressure .if it still does it `replace it.
Posted on Feb 28, 2008
  • 1028 Answers
SOURCE: Dryer door pops open after
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Posted on Jun 14, 2008
SOURCE: Buzzer won't go off when dryer is stopped - All else works fine - must leave door open
Fiddled around with the start button. It had gotten stuck in the on position and when I moved it around it freed up. I consider this a temporary fix only and have already ordered a replacement switch.
Posted on Aug 03, 2008
Want to disable buzzer
Hello Craig McDaniel - The buzzer signal will sound when the cycle ends and briefly every 5 minutes as it is a reminder to remove the load. For this purpose, unfortunately the buzzer signal cannot be disable. Most of this brands laundry centers and microwaves are preset to do this.
Feb 15, 2013 | Frigidaire FEQ1442ES Electric Dryer
Replaced timing belt and car won't run
You had better check the timing belt again, you may have done something wrong and it skipped teeth.
Sep 04, 2012 | 2001 Volkswagen Beetle
We have an old Frigidaire dryer (1993). It stopped in the middle of a drying and won't start again. The light goes on, the buzzer goes off when tested, but it won't start turning. It is too...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Dryers
I'm pressing the start button but the dryer won't start. it just beeps about 3 times then stops. The first time i tried it it ran for about 5 secs then shut off.
heatman101
Aug 21, 2011 | Frigidaire GLEQ2152ES Electric Dryer
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Matag performa dryer heats but won't tumble.
After checking the door switch and belt (both ok) I took the wires
from the thermal fuses-- straight wired them together and the dryer started working. I went to my local appliance center,
purchased the thermal fuse kit --replaced the old fuses--now it
runs great.
I hope this helps someone else with this problem.
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Several problems ... now no power at all!
Hi. thanks for the question . You started to have the motor problem when it would shut down . wait a while then go again .the growl you hear now. is that the motor is now shot .you need a new motor. thanks the appliance doc
Sep 30, 2008 | Whirlpool LER4634J Electric Dryer
Aug 02, 2008 | Maytag Dryers
Dryer will not start properly, buzzer operating
more than likely your timer is faulty too much to replace most timers about same price to replace your dryer if not cheaper
Mar 16, 2007 | Candy CIV60 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
