Question about Samsung CLX-6210FX Laser Printer
Jammed toner cartridges
I have a Samsung clx-6210fx printer and all the toner cartridges are jammed on the right side, so I cannot remove them from my machine. Is there any way I can get them out?
    Scholar:
  • Samsung Expert
  • 113 Answers
Hi.
you could use a test pen to push all the right side black latch that holds the toner back to the normal position. in a normal position it shall be in and not out as if you see it carefully the latch on the right side of the door is where it help to set in the transfer belt.
Posted on Apr 19, 2010
How do i fix paper jam2
Paper has jammed In the fuser area (open back door to fuser area) or Check Inside around the toner cartridge
Jun 10, 2014 | Samsung CLX-3170FN All-In-One Laser...
Clx-3175 laser printer always results in a paper jam -why? how to fix it? Help help please
first remove the power and remove the cartridge cover and inspect for tiny piece of paper remove the piece of paper or you can use an mild air blower to flush it out for that first remove the toner and use the air blower and clean the inside of the printer if there is any tiny piece of paper the paper get jammed often
Oct 26, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I have a Samsung CLX6210FX. I get this error Paper Jam 2 Check Inside. I check the paper tray and the toner door but could not find where the paper jam is. Please help
This can be very difficult to find especially if they are small pieces. If you remove the toner cartridge and with a flashlight look all around for any evidence of paper. Also check thoroughly all the doors that will open and all around the rollers. Lastly and this is difficult is the fuser in the very back of the printer. These rollers are extremely hot and sometimes when the fuser goes bad, it will keep the paper in the fuser causing the jam. On the menu you will probably see error codes as well. Hope this helps.
Mar 19, 2011 | Samsung CLX-6210FX Laser Printer
I have a paper jam with a samsung CLX 3175FN. Can't get the stuck paper out! Turning on and off didn't work.
If the paper is jammed inside the machine follow these steps:
1. Open the front cover and pull the toner cartridge out, lightly pushing it down.
2. Remove the jammed paper by gently pulling it straight out.
3. After removing the jammed paper, make sure there is no additional paper in the paper path.
4. Insert the toner cartridge and close the front cover.
If the paper is jammed in exit are follow these steps:
1. Open and close the front cover. The jammed paper is automatically ejected from the machine.
2. Gently pull the paper out of the output tray.
- If you do not see the jammed paper or if there is any resistance when you pull, stop and go to the next step.
3. Open the rear cover.
4. Carefully remove the paper by pulling in the direction.
- If the paper tears, make sure that all of the paper fragments are removed from the printer.
5. Close the rear cover. Printing automatically resumes.
Nov 17, 2010 | Samsung Office Equipment & Supplies
Toner low warning still appearing CLX6210
some printers reset the counter when the instruction to change toner comes up. if it is merely warning you i would wait until the instruction to change appears
Jun 30, 2010 | Samsung CLX-6210FX Laser Printer
I have a paperjam on my colour laser printer CLX 3170 and I dont know how to get to the paperjam inside the machine
Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
My printer is 5 weeks old. My Samsung CLX 3175FN color laser printer has a paper jam. I have removed as much of the paper as possible, but it is still jammed ( where I cannot get at it ) in the upper rear...
Have you turned the printer off then tiurn it back on. If you have a paper jam, after you remove the paper, you must restart it for it to clear.
Otherwise, if there is paper still in the printer, turn off the printer remove all 4 toner cartridges and the waste cartridge. Once you do that you may be able to see the paper. You may be able to take one more thing out to where you can see the paper better, I am not sure.
Kevin
Jul 19, 2009 | Samsung CLX-3175FW Multifunction Laser...
Canon copier D761's printer cartridge is jammed
That door above the cartridge needs to be open all of the way, maybe even push it back gentley to make sure. Should be at 90-92 degree angle. Then the cartridge will come out.
Jan 08, 2009 | Canon imageCLASS D761 Copier
Samsung 6210 paper jam
open access(load area) check feed roller take a q tip and use rubbing alcohol and clean photo eye that detects paper be sure all jammed paper is removed
most jams are at the exit and there may be some paper obstructing that area
insert card stock through the paper path
insert ine
Dec 30, 2008 | Nikon COOLPRINT Thermal Printer
Keeps jamming
check your toner cartridge and also u need to service the printer fuser aseembly.also change roller.or taplon tape.
thats all
also see there is not any paper jam in parts.
Oct 09, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-6210FX Laser Printer Logo
87 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
