Question about Velodyne DPS-12 Subwoofer
Where is fuse in velodyne dps-12 - Velodyne DPS-12 Subwoofer
    Scholar:
  • 65 Answers
Just a guess, but the drawing in the manual shows a fuse rating of 2 amps where the power cord enters the box. Is this a combination fuse/connector. Have you looked if the rocker switch accommodates a fuse? Sorry if no help.
Posted on Dec 14, 2013
  • 151 Answers
SOURCE: subwoofer
Yes you do as this is were it gets the information from to play a bass line or effects from a film,if you dont have a amp or receiver you have a coffe table.
hope this helps.
CABLE GUY.
Posted on Jul 03, 2008
  • 151 Answers
SOURCE: how to connect pioneer reviever to velodyne subwoofer
Look for the sub pre out on the back of your amp and connect a sub cable to this and next to the LFE or phono type input on the back of the sub ,if it has two inputs left and right pick the left side ,set the cross over to suit your system and speakers,if you are not sure set the cross over to 80 hertz,this is a thx standard.
hope this helps.
CABLE GUY.
  • 124 Answers
SOURCE: Velodyne ULD-12 driver voice coil sensor availability
Contact Velodyne. That is the only source for this part.
Posted on Jan 04, 2009
SOURCE: Subwoofer is not working
Please check the pins of the plug (round one connecting woofer and speaker). Most probably one or more of the pins could have been bent.You can straighten it with a long and strong needle. All the 10 or more pins need to be seated in the slot. Each pin has a specific function for the sound system.I tried this to my computer speaker Altec Lansing VS2521 and it was successful. I have already posted my method after I made a query like you. If my suggestion does not work be patient for a while and apply your mind exclusively on the problem and you will also come across a solution. Any way keep us informed of your progress.
Thanks and regards
M. Narayanan
Posted on Jan 17, 2010
AJIN G
  • 6694 Answers
SOURCE: My Velodyne DPS-10 subwoofer hums when you plug in
hi,
You have to check the RCA cable to the sub woofer. The RCA cabe have two connections inside it, one is for gain and the other is for ground sheild. If the ground sheild is broken then there will be hum from the sub woofer and it will increase if you touch the ground (rear metal pannel is connected to the ground). Replace the cable and check it again.
ok
Posted on Jul 17, 2011
Thanks and regards
M. Narayanan
Jan 17, 2010 | Velodyne DPS-12 Subwoofer
No light no so sound, but when turn on or off we
Contact Velodyne, you may need service on the unit.
Dec 22, 2009 | Velodyne DPS-12 Subwoofer
Subwoofer
hope this helps.
CABLE GUY.
Jul 03, 2008 | Velodyne DPS-12 Subwoofer
Velodyne subwoofer
First make sure that the cables are properly connected up. Make sure that the output of the amplifier feeding the sub is working properly and has no faults.
If the above is okay, it is possible that the power supply in the sub, and or the output stage has a failure. In this case the sub will require shop service to have it working again.
Jerry G.
Jun 12, 2008 | Velodyne DPS-12 Subwoofer
Volodyne dps 12
maybe its the amplifier that does not take too much power to the speaker you need to buy a new amplifier and the sound will not cutoff.
May 31, 2008 | Velodyne DPS-12 Subwoofer
Major buzz/Humming sound coming from my subwoofer
Well there are only a few reasons i can think of that just might be the reason behind said buzzing.
1. It may be connected to another power source ( amplified or powered supply ) or incorrectly connected. It may also be too close to said power supply.Try letting the dog (sub) out on his leash a little Drag out the manual that came with the sub, and check the correct procedure for your type of setup.
**People do read manuals still don't they ?**
2.The only other problem i have heard of is port noise in low registers. Keep the the port area clean, as it may suck up dirt, or even worse, small children!
3. However, if you're considering placing this subwoofer in a cabinet, I'd recommend allowing ample breathing room for the heat sink. This can also be done by drilling smaller holes in the cabinet ( 8-12 mm holes - with the owners permission of course) but please do remember to keep the port area clean.
4. The product ie: Velodyne DPS-12 Subwoofer, came with a bad power supply, presuming it is new, check your warranty.
(not very likely - see also scenarios 1, 2 or 3.)
Velodyne has been making subs forever and do it well.
Jan 17, 2008 | Velodyne DPS-12 Subwoofer
How to connect pioneer reviever to velodyne subwoofer
hope this helps.
CABLE GUY.
Dec 27, 2007 | Velodyne DPS-12 Subwoofer
Speakers
start/settings/control panel/sound and audio devices
Nov 27, 2007 | Velodyne DPS-12 Subwoofer
Velodyne DPS-12 Subwoofer Logo
168 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Matthew Spark
Matthew Spark
Jerry Greenberg
Jerry Greenberg
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
