Question about Magnum Electronics - Others
What does the fault internal bridging mean. When this code appears the entire coach has no power
2 Suggested Answers
  • 155 Answers
SOURCE: what does po601 pcm internal fault means
Please refer to this site for details:
http://www.aa1car.com/library/pcm.htm
Posted on Jun 12, 2009
Srs air bag light flashing
This code is telling you of an ECS module fault.
An ECS module fault could be caused by:
- the internal accelerometer not operating properly.
- the backup power supply not operating properly.
- an internal module circuit fault detected.
- a microcontroller RAM/ROM/EEPROM fault.
Before doing any of the above, disconnect the vehicles battery and Remove the main connection off of the ECS and clean with electrical connection cleaner, then reinstall, then check the connectors and wires under the seats - these fail all the time.
After checking and cleaning reconnect battery.
Sep 26, 2015 | 1998 Ford Ranger SuperCab
Washing Machine stopped through cycle and now will not turn on
Check the wiring harness, connections, contacts, etc. Look for some corrosion and loose connections. Also, check the water inlet for anything that may cause a reduction in water flow.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
Can't find the transfer switch, and could it go bad. Shore power and generator power works to the main panel box, but won't charge coach batteries
although it is possible to do separately most times the transfer switch is internal to the inverter , and the fact you mention that inverter is not charging batteries tells me your fault lay in the inverter all or part of it is not working , look at it carefully these have sometimes two reset breakers on there cases
Jun 01, 2015 | Inverter Electronics - Others
What does the code F1 mean on a frigidare electrolux 316233852?
The F1 code indicates a control failure. Try pressing a key to see if it displays on the screen. If not, the keypad may have shorted and requires replacement. If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the powericon1.png for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC). If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven. If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary. If the oven is actually overheating, replace the EOC. If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
May 31, 2014 | Kitchen Ranges
It won't start and displays E3 fault code. Manual says this is faulty coils? Took apart and cleaned all, looks good. Still has code displayed and won't run. How to clear fault code? Thank You.Jeff
E3 means "unit-abnormal protection to avoid occurence of unit damage."
Manufactures does not recommend that a homeowner try to attempt a repair on a code like this as it indicates possible wiring or internal problems. Have you checked for an internal fuse on the circuit board? I would also check the incoming power to make sure you have the proper voltage. You can also try unplugging the unit, waiting 30 seconds and plug back in to see if the code disappears.
According to A/A brands, if this code appears, shut off device and call authorized service company. I'm just trying to get you some things you can check yourself prior to doing that.
Hope this helps.
Jul 29, 2011 | Home Pride AA-TH 358 Air Conditioner
2001 dodge ram 1500 fault code 1687
Heryou go its a pretty lengthy diagnostic procedure it appears there is a power problem with the instrument cluster here is the code meaning hope it helps have a good dayDB0b0195e.gif
Feb 19, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Prosine 2.5 fault 195
This internal fault code can mean so many things, but basically it more than likely has some internal parts that the smoke is no longer inside. They can be repaired however, email sunyout@gmail.com to discuss further.
Thanks, Bob
Oct 20, 2008 | Inverter Electronics - Others
Fault code
The information I can find on this shows a code 15, not 16. It shows it as a problem with the #1 shift solenoid or it's harness. Causing different internal transmission concerns. The book I found shows no code 16,this could be a miss print. Either way, this is a concern that appears to be an internal trans. problem.Good luck.
Aug 19, 2008 | 1990 Subaru Legacy
Frigidaire self cleaning convection range
Error code F1
1. Shorted keypad.
2. Control's internal checksum may have become corrupted.
3. Control has sensed a potential runaway oven condition. Control
may have shorted relay, RTD sensor probe may have gone bad.
1. Disconnect power, wait 30 seconds and reapply power. If fault returns
upon power-up, replace EOC.
2. Check RTD sensor probe and replace if necessary. If oven is
overheating, disconnect power. If oven continues to overheat when
the power is reapplied, replace EOC. Severe overheating may require
the entire oven to be replaced, should damage be extensive.
3. Replace EOC.
Check resistance at room temperature, if less than 500 ohms, replace
Temperature (°F) Resistance (ohms)
32 ± 1.9 1000 ± 4.0
75 ± 2.5 1091 ± 5.3
250 ± 4.4 1453 ± 8.9
350 ± 5.4 1654 ± 10.8
450 ± 6.9 1852 ± 13.5
550 ± 8.2 2047 ± 15.8
650 ± 9.6 2237 ± 18.5
900 ± 13.6 2697 ± 24.4
Hope it helps please let me know
Jun 11, 2008 | Frigidaire Ovens
Electronics - Others Logo
Top Magnum Electronics - Others Experts
Are you a Magnum Electronics - Other Expert? Answer questions, earn points and help others
