Question about Crafts & Hobbies
Craftsman 980555 mine just stopped working. Can I fix it?
I need a piston stop for a craftsman finish nailer part number4573.00 sears states they are not being made anymore do other nail guns use the same part
I am not familiar with nail guns but if there is a place to put a piston stop, can you use a piece of rope instead? I have used rope to stop the piston on chainsaws I have fixed where my piston stop tools wouldn't work
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 14, 2013 | Craftsman Garden
Craftsman dsg 6500 slips when going up hills
That was happening to mine. Installed a new clutch....all fixed. Not cheap though.
Jun 26, 2012 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman rider mower 917259567 has a knob for adjusting the mowing height. how does it work, mine seems to be broken
The adjusment knob works only when the mower deck is in the UP, position. You then start by turning the knob CLOCKWISE, if you turn it far enough the mower deck wont go down. You back it off ( COUNTER-CLOCKWISE) to hold the deck in a lower position. Just rember you cant fine tune the heightsetting knob with the weight of the deck resting on the stop (knob), just pick the dech up a little then adjust the knob.
Hope this helps, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 11, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My friends Craftsman air compressor stopped running
The compressor in question is basically a throw away.
My personal opinion is it's more trouble then it's worth.
Even after it's fixed you still have a throw away compressor.
However it is possible to repair it if the parts are still available.
Check out the link below for parts and diagrams for the compressor in question.
Hope this helps and good luck.
http://
www.mastertoolrepair.com/-c-271_535_537.html
http://www.mastertoolrepair.com/
Jun 10, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman snow blower wheels wont move. Help!
If it is a 5.5 HP dual stage, like mine, it could be that the belt has popped off the friction pulley. If you drain the gas, tip the unit on its "face" and remove the large shield on the bottom you will see a 3" pulley attached to the drive shaft. There will also be what looks like a fan belt floating around in there. That fan belt nees to go on the pullet, as it serves as the friction disk tio drive the wheels. Good luck. this happens to mine ALL the time. very frustrating. :(
Jan 19, 2010 | Sport & Outdoor - Others
My craftsman easy fire stapler diagram
Mine stopped working last night. I took it apart and was able to reassemble it properly.
When both sides are rejoined the tip of the spring has to be inserted in the hole on the corresponding side (note red arrows on both pics)
This is a great stapler when it's working.
Nov 22, 2009 | Tools & Hardware - Others
I have a Craftsman 19.2 charger that stopped working...
OK, I had trouble with craftsman 19.2 charger stopped working. I took them a part and found there is a lever looking plastic piece that turns the switch inside the charger. The lever gets pushed by a battery and it pushes the switch. Well, over the years of use, the tip of the lever got rounded on mine and not be able to push the inside switch in all the way. So I just super glued a little plastic on the lever piece and put the battery together. It's been working fine ever since.
Sep 17, 2009 | Craftsman Drills
Craftsman 3/4 screw garage opener all remote stopped working
The radio receiver which is part of the logic board is bad. Check your warranty quick and call Sears.
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Crafts & Hobbies Logo
53 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
