Question about Brother MFC-5860CN InkJet Printer
Machine Error 48 - Brother MFC-5860CN InkJet Printer
  • Janis
    Janis Nov 28, 2013
    Hi Anthony Velicaria, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
What are printer error messages 4F and 48 on Bother MFC-J430W wireless printer
Error 4F and Error 48.
Actual Message will be:
Unable To Init 4F
Unable To Clean 48
These messages indicate the Waste Ink Tank is full.
This is the space in your machine that will store all the ink that is used in cleaning the printhead. Once this is full the only way to continue printing is reset the Purge Counter and clean out the Waste Ink Station. If you do the reset and not he cleaning of the waste ink station you will eventually end up with the waste ink tank overflowing and leaving a huge mess to clean up. If you clean out the tank but not reset the purge counter it won't work till then.
Unless you are satisfied with your ability to dismantle and reassemble your printer you may want to just replace it as it can take some time and causes alot of mess.
May 01, 2016 | Brother MFC-J430w Inkjet All-in-One
Error 48:00
48:00 error is a PPS(Paper to paper space) system failure.
You need a trained tech to look at the machine.
The PPS solenoid cable could be damaged. Could be a bad PPS solenoid or a bad print mech
Nov 09, 2010 | HP Designjet Z3100 InkJet Photo Printer
I was not able to print because it has shown machine error 48, what does it means ? please help me to solve this problem . Thanks .. Glorie A. Fernando
Error #48 means that there is a problem on the print head. I would suggest going to control panel, find your printer, right-click and open "properties", and have the printer do a head cleaning as well as a printer head alignment.
Oct 28, 2010 | Brother Office Equipment & Supplies
Error code 48
Code 48 is internet disconnect.
On the machine if the machine is set up for internet connection, turn it off. Sometimes email is turned on and the other settings are not setup correctly.
Make sure all settings are done correctly
If one is faxing make sure the phone line is connected correctly and their is a good sounding dial tone.
One area to keep in mind is a phone dial tone turning off and on.This can be a phone company issue or poor line connectors in the building, even a corroded plug on the phone receptical.
Check these areas, even replace the phone line cord with a new one.
On the machine a fax machine not sending or recieivng, suspect a board causing the problem.
Jun 08, 2010 | Xerox FaxCentre F116 Plain Paper Laser
Machine error 48 appears on my machine or Init unable 48. how to reset or what is the problem?
That error says the connection to the printhead is bad, you have to take out the long thin covers over the cables under the top cover and reseat the ribbon cable connections. Sometimes when plugged in at the factory some of the contacts on the end of the cable fold back and you need to trim off 1/8 inch and re insert the cables.
Jan 31, 2010 | Brother DCP 165C Compact Color Inkjet...
Machine error 48, brother 420cn
defective print head cable or circuit board. new ph needed.
May 03, 2008 | Office Equipment & Supplies
Looking for assistance
48 = head cable problem
lift top of machine as if changing ink, there is a black cover that needs to be removed to expose head cable, check it is pluged into board fully
remove A, check cables at B
Dec 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
BROTHER DCP-315N
Have you had this machine apart/head removed?
error 48 = Head flat cables or carriage-head flat cable broken or not connected.......or main P.C.B.
Are you serious, I have never seen this on any inkjet, ........"Try to get temperature of room.. warming up"
Do you live in a igloo?
Nov 05, 2007 | Brother DCP-110C All-In-One InkJet Printer
Error code de
DE is a error code for your door switch. The door is not locking properly. You need to get a new door latch mechanism.
Sgt 48
Mar 29, 2007 | LG WD-1280FHD Front Load Washer
Brother MFC-5860CN InkJet Printer Logo
21 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
