Question about Razor Cycling
Charging a razor epunk
How do i charge it
5 Suggested Answers
  • 319 Answers
SOURCE: Won't charge up, won't run
uh...the charger's supposed to have a DC output
Posted on Feb 12, 2008
  • 850 Answers
SOURCE: e-100 razor scooter battery will not take charge
its dead they need to be recharged every time they have been used
Posted on Jul 18, 2009
brector3
  • 1624 Answers
SOURCE: razor wont charge
Yes, the batteries can be changed. You will find replacement batteries for model 6705X at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To change the batteries, you will need to remove the lotion cartridge cover on the back and then remove the screws on the back of the inner cover. Remove the back to get to the inside of the shaver. The batteries are soldered to the circuit board. You can unsolder them or it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs. Reassemble in reverse order
If you are not able to do this repair yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Posted on Jun 10, 2010
  • 16 Answers
SOURCE: razor bella problems
Most likely a bad battery. Check out put voltage on all posts. If it's 12 Volts DC or more, then it should be ok, and you'll need to start looking in the wiring such as the speed control switch. If not, your problem is a bad battery cell and you should replace it. NEVER TRY TO SERVICE A BATTERY!!!!!
Posted on Jun 12, 2012
Hannah Montana razor scooter says charged but wont go whats wrong
I haven't used my razor scooter in years. I just bought a charger and it seem like it is charging but it keep saying it is on low. I twisted the gas thing and it is making a noise like it want to go. But I am not sure I have charge it for 12 hours now. Do I need a battery or is it just taking it time to charge.
Sep 17, 2015 | Electric Razor Pocket Mod Scooter
How to fix a Braun series 7 razor that will not charge in cleaning stand
Try plugging the cord directly into the shaver. If it charges this way, your clean and charge unit is bad. A replacement can be ordered from the link below
http://shaveroutlet.com/braun-pulsonic-clean-charge-base.html
May 27, 2014 | Braun 7000 Series Foil and Cutterblock
9595 Charger won't charge while in stand
Your charging and cleaning stand is faulty. They are not repairable because parts are not available. You can purchase a new clean and charge stand at shaveroutlet.com
Braun Series 7 and Pulsonic Clean Charge Base
May 21, 2017 | Braun Shavers Male Pulsonic System 9595CC...
How long do you have to charge it for? , and do i leave it on or off?
the Razor MX350 will accept a charge if powered on or off, charging time is 8 hours, if the green light shows before this time still leave it plugged in as it may not be reading right.
Jun 25, 2011 | Razor MX350 DIRT ROCKET - BLUE
Have an e100 razor electric scooter. it has not been used for a couple of years. I got a new e100 charger and tried to charge but i noticed that the green light stays on and the red light charging does not...
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are available at:
razor.com
Jul 20, 2010 | Razor E100 Electric Scooter
Razor charged but not running
You didn't specify how old you model is.
Generally I would say, the battery is failed.
You might try taking it to whereever you bought it and politely ask for a replacement. Its also a good idea not to leave these in cars during sub freezing weather.
Apr 09, 2010 | Norelco Cool Skin 7775X Electric Shaver
I no longer have the owners manual. What does it
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
Jul 14, 2009 | Norelco Rechargeable Cordless Men's Razor...
Razor phone won't charge
Hi, I had the same problem with my Old Razor, I bought a new battery and that fixed the problem.
New Batteries for Razors are around £6 - £7 online. google it.
Apr 16, 2009 | Motorola Mobility RAZR V3
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Feb 12, 2008 | Norelco Advantage 6705 X Electric Shaver
Cycling Logo
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
