Question about Music
Williams and sonoma roasting thermometer sku 6700488
Need operator manual
Why do keys produce no sound?
Hi Kyle:
Have a look at your manual.
Sometimes you'll find that there will be an "input" setting required.
You might also try google with his link.
https://www.google.ca/#q=Williams+Allegro+88-Key+Digital+Piano
Hope this helps.
Cheers.
Oct 13, 2015 | Williams Allegro 88-Key Digital Piano
I would like to know the code about the C5 condenser behind the catch of the power supply unit about the board mother. mine is roasted. Thank you
2200mfd / 16volt
Make sure there are no other problems before you replace it!
It does not get barbequed by itself.
Have Fun.
Dec 11, 2014 | Alesis Sr 16 Stereo Drum Machine
Connect williams allegro midi to usb
You probably want to connect to an audio input.
Oct 08, 2014 | Williams Allegro 88-Key Digital Piano
We need to change battery on Korg X5DR Can we do it ourselves and how?
Here is your service manual:
http://elektrotanya.com/korg_x5d_sm.pdf/download.html
Y The Lithium cell is a CR2032-HE2 type.
At the site above, scroll down to "get manual" and click to download the service manual. IGNORE other download links for viewers, etc. This replacement will take a soldering iron... it is NOT in a coin cell holder. In addition, I cannot find the HE2 tab configuration for sale so I suspect you are going to have to make do with a http://www.newark.com/jsp/search/productdetail.jsp?SKU=42M1351 or equivalent which has solder tabs out horizontal. I can't even find what the HE2 type is but I suspect it is the stiff mounting tabs through the board. BE VERY CAREFUL in unsoldering those as it is easy to lift the etch on the board.
Jul 16, 2011 | Music
I have a Williams Encore Digital piano. When I power up there is no sound. Upon power up there are 8 small rectangle on the LCD screen. 7 red light are lit. They are the 4 lights above the "user...
Holding the page up and down buttons while powering on supposedly resets it. I have no sound except demos, but no lights showing like yours, and williams tech support said to reset that way but it didn't seem to do anything. Good luck hope this helps!
Jun 27, 2011 | Williams Encore Digital Piano
My Williams Allegro 88 keyboard sustain pedal is doing the opposite of sustaining. I lost the manual so I also don't know how to reset it and if this will fix the problem.
Assuming this has worked in the past (otherwise if you have changed to different pedal that is the problem) the usual thing is the machine samples the state of the pedal at power up and assumes the polarity of the pedal is at rest. Make sure you are not pressing it as you power up. Also verify the pedal is COMPLETELY plugged in... sometimes they are not quite fully in and that causes a problem, especially with the two stage versions that are sometimes used.
May 06, 2011 | Williams Allegro 88-Key Digital Piano
I have just purchased a Williams sonata 88 but it does not have a owners manual. Where can I purchase one from?
Download it for free at this URL:
http://dl.owneriq.net/f/f82b3b7d-6d13-4662-b864-40c21800e0fd.pdf
You're welcome.
Nov 21, 2010 | Music
The Williams Sytmphonic keyboard was toppled and disconnected feom pedelshow to reconnect expressikon pedels to piano keyboard
Here is a link:http://www.williamspianos.com/products/encore.cfm If you don't have one, download the manual. If it still doesn't play correctly with the pedal connected according to the manual you will have to contact them to see about servicing. The information is also at that link.
Aug 18, 2010 | Williams Encore Digital Piano
The input for the ac adapter is loose and cuts outt all the time.
Connector is probably damaged. If you can open the unit you can get replacement connector from DigiKey.com and Mouser.com. You need to compare dimensions of the barrel AND the pin to insure you get the correct part. Also the pins that go through the board. One could go through Williams, but they may not have a parts dept.
Aug 11, 2010 | Williams Encore Digital Piano
Music Logo
59 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
