Question about Whirlpool WMH1163XVQ Microwave Oven
Whirlpool wmh1163xvq1- This oven does not switch on
We have whirlpool wmh1163xvq1 used to work nicely. These days it doesn't swicth on. Please help trouble shooting steps
Manual for Panasonic Model NNS767WAS
Hi Connie:
I suggest visit this link Panasonic NNS767WAS Microwave Oven Manual
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | Panasonic Microwave Ovens
MISSING OWNERS MANUAL FOR MODEL gh4155xpq-0 Microwave
Do you mean the Whirlpool Microwave Hood Combination GH4155XPQ0? Most Whirlpool appliance manuals are available here: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . The direct link to the manual for the GH4155XPQ0 is https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208204919.pdf .
Sharp doesn't have a microwave with this model number. If you gave the incorrect model number but the correct manufacturer, please add a comment with the correct model number.
I hope this helps.
Dec 03, 2011 | Microwave Ovens
Whirlpool Electric combination Microwave and Oven -- when I try to turn on the microwave the words "door" comes on screen and unit does not start. The door does latch but still does not start....
I could have been more specific with a model number, but if this general answer doesn't do the trick, feel free to contact me with your full model and specific symptoms here.
It's usually a bad door switch or door switch mount. My helpful text file on door switches is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's one of those overdesigned Whirlpools, it can be one of many components. See the example photo at the bottom of this reply.
Oct 05, 2011 | Whirlpool RMC275PD Microwave Oven
Our Whirlpool Microwave Oven makes a loud winding noise and doesn't heat.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 01, 2011 | Whirlpool MH6150XLS Microwave Oven
While changing the light bulb on the bottom of Whirlpool MH1140XM, the bulb popped. I replaced it but now all I get is a hum whether I push timer, light or oven settings. The oven appears to be heating...
Hello, Thank You for using FixYa. I will be helping you today.Make sure no wires were pinched in the process. The turntable motor runs off the board that's why im thinking you have a grounded wire somewhere.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Whirlpool MH1140XM Microwave Oven
Controls work,microwave does not cook ,turntable not turning
One thing worth checking is the doors safety switch as sometimes they become misaligned and although the buttons and the display works the oven will not.
Please remember that electrical appliances can be very dangerous to work on and you should really have them repaired by a professional as they can cause serious harm and or death.
Microwaves have hi voltage capacitors that can store electricity for hours, days and weeks so just because they are not plugged in doesn't mean they are safe.
A repair person would remove the ovens case and and locate the door safety switch which will be where the 2 prongs from the door enter the oven body.
They would then realign the switch to make sure it is being engaged when the door closes.
The switch can be bypassed but this is not a good idea as the oven will operate even when the door is open which is a really bad idea.
Hope this helps,
Best regards,
Dave
Nov 25, 2010 | Whirlpool MH6140XK Microwave Oven
The microwave don't heat but everything else is working
This no heating is highly suggestive of a faulty magnetron.Due to the faulty magnetron, the oven is not heating.Read :-
http://www.gallawa.com/microtech/mag_test.html
Note - Changing magnetron is REALLY dangerous. Kindly take all the precautions while repairing it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 13, 2010 | Whirlpool MH1150XM Convection/Microwave...
GE Profile Spacesaver XL Sensor Microwave
You have a bad door swicth or a bad wiring connector to one of the door switches... secondary swicth or the door sense switch.
Dec 16, 2008 | GE Advantium 120 Convection/Microwave Oven
Whirlpool Microwave (Magi-cook) Problem
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
If you need further assistance, please feel free to contact me directly through the links at our site: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 07, 2008 | Whirlpool GH7145XF Microwave Oven
Whirlpool WMH1163XVQ Microwave Oven Logo
24 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
