Honeywell cm61ng binding with relay box issue
I replaced my cm61ng thermostat as the original had a broken LCD. I can't sync the new thermostat with the relay box. I've looked up the binding instructions and followed them but it simply won't connect. I can't re-bind my broken cm61ng now as the display is unlegible. Any ideas? thanks
    Master:
  • 571 Answers
Make sure all the pins line up, and your thermostat wire is not causing the binding.
Posted on Dec 10, 2013
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
Make sure all the wires to the termination posts are flush (or stuffed in the wall) behind the plastic so that there is no bowing.
Nov 28, 2013 | Honeywell Programmable Thermostat Heater
Honeywell cm61ng connection to relay box
Make sure the green button is on @ the relay box.
Nov 27, 2013 | Honeywell Programmable Thermostat Heater
Colman evcon ''B'' relay connection on new programmable t/stat
Hello The B wire now goes to the O termnal on new thermostat.
Apr 03, 2010 | Coleman Heating & Cooling
IT COMES ON WHEN IT WANTS , NO MATTER WHAT I SET IT AT ITS A CM61NG , IF I SET IT AT 1,30 IT COMES ON AT 3 WIERD !!
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 25, 2010 | Honeywell Programmable Thermostat Heater
Cant get thermostat to bind with receiver box
Go to honeywell.com
Feb 14, 2010 | Honeywell Programmable Thermostat Heater
Remote not workin
what's happened here is the cm61 ng and the reciver box have lost there connection you will have to "rebind" them then it will be fine -
THE BINDING OPERATION DESCRIBED BELOW IS REQUIRED IF:
· Any of the system components (room unit or relay box) are replaced
· HC60NG has incorrect or no binding data stored (e.g. when pre-bound system pack components have been mismatched)
· Interference with the RF signal has caused a communication failure
During the binding procedure keep approximately 1m distance between the room unit and the HC60NG
1 Turn off mains supply to HC60NG for 10 seconds. Re-connect supply.
2 Press and hold the HC60NG push button for 15 seconds to reset previously stored data. The red LED will start to flash at 0.1 s on/0.9 s off. Release the push button.
3 Press and hold the HC60NG push button for 5 seconds to enter the binding mode. Red LED flashing at 0.5 s on/0.5 off confirms the binding mode has been entered.
4 Move the CM67NG slider to the OFF position (CM61 push the OFF button) and press the TEMP , TEMP and PROG 1 buttons together. The CM61/67NG will display InSt.
5 Press the i button to send the binding signal. The red LED is switched off on the receiver box to confirm the successful binding operation. If the red light still flashes push the repeat steps 1-3 and press the the i button until binding is successful.
hope this is helpful
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Honeywell - cm61ng- Keeps going on and off all night
Instructions on how to turn off your optimum start:-
Turn off ‘Optimum Start’
Step 1 Put the thermostat in the OFF position.
Step 2 Press 3 buttons together (at the same time) which are the INFORMATION BUTTON (i) and PROGRAM BUTTONS 3 & 4.
This will show a code of ICL 1 – now let go of the buttons.
Step 3 Press PROGRAM BUTTON 2.
This will now show a code of 30t 1
Step 4 Press the + BUTTON (on the left of the display), tap through until you reach 15 OP 1
Step 5 With the TEMPERATURE DOWN BUTTON; change the 01 to a FLASHING 0. Confirm the FLASHING 0 with the INFORMATION BUTTON ( i ). The 0 will now be static.
Step 6 Put the Thermostat back in the ‘AUTO’ position.
‘OPTIMUM START’ is now switched off.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
