Question about LG 42LE5400 42 in. LCD TV
Not turning on
Will turn on after warming up for some time
  • 59 Answers
If it only turns on after it has warmed up for awhile, this may point to faulty filter capacitors in the power supply or the filtering circuits.
Look of bulging tops (the should be flat when good). The middle 3 in the photo are examples of what bad ones look like.
Posted on Nov 28, 2013
2008 land rover sc warm up car turn on heat blower working warm air at first then clod no heat
When is the last time you change the thermostat and coolant?
Recommended interval is 2 years.
Coolant is the heat carrier to heater core.
Top off the coolant level for now and re-test.
Dec 31, 2013 | Land Rover Range Rover Sport Cars & Trucks
How to turn on sabbath control on my whirlpool stove
To Activate Sabbath Mode:
To use the Warm Zone and/or Warm Drawer during Sabbath Mode,
press the WARM ZONE and /or WARM DRAWER keypad before
activating the Sabbath Mode.
1. Press BAKE.
2. Press the "+" or "-" key to set a temperature other than
350F (177C).
3. Press START.
For timed cooking in Sabbath Mode, press COOK TIME, then
the "+" or "-" keys to set the desired cook time.
4. Press TIMER SET/OFF for 5 seconds. "SAb" will appear in the
display.
To Adjust Temperature (when Sabbath Mode is running):
1. Press the "+" or "-" keypad. Each press of a keypad will
increase or decrease the temperature by 25F (14C). No
temperature will appear in the display.
2. Press START.
To Deactivate Sabbath Mode:
Press and hold TIMER SET/OFF for 5 seconds to return to regular
baking or press CANCEL/OFF to turn off the range
Feb 09, 2013 | Kitchen Ranges
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
1988 ford f250 460fi wont turn over when warmed up runs fine just cant turn off.
if it turns over good first time starting,but barely turns after engine has been warmed up from running,yoou will need to replace the starter,
Jan 29, 2010 | 1988 Ford F 250
RCA modelD52W20 Problems turning TV on when it is cold or for the first time after being off for an extended amount of time. The green lite comes on ,stays on a few seconds and goes out. After continueing...
well usually what works for me is a small heater on near the tv or just keeping the room above 65 degrees. There is a way on some tv's to turn off the power saver and that will keep your tv warm. But on others you cant turn it off so you have to deal with the heater or keeping the room warm cause that tv wont turn on for anything exept if its warm....
Dec 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
On/off cooling
You will need to replace the outdoor fan and capacitor before it cause damage to the compressor. Thx RepairUSA
Aug 25, 2007 | Intertherm P3RA-048K Air Conditioner
LG 42LE5400 42 in. LCD TV Logo
64 people viewed this question
