Question about Honeywell Programmable Thermostat Heater
Honeywell cm61ng binding with relay box - Honeywell Programmable Thermostat Heater
    Master:
  • 571 Answers
Make sure all the wires to the termination posts are flush (or stuffed in the wall) behind the plastic so that there is no bowing.
Posted on Dec 11, 2013
My Honeywell CM921 wireless thermostat is showing 41c on display and not communicating with the Relay Box. I have tried resetting it using the Binding / Rebinding procedure but still nothing.
Take the cover off and see if there is a reset button (usually recessed so you need a pencil or wire to push it. If that doesn't work check on the circuit board for a blown fuse. It might be like a car fuse 3-5 amps.
Sep 20, 2014 | Heating & Cooling
Honeywell cm61ng binding with relay box issue
Make sure all the pins line up, and your thermostat wire is not causing the binding.
Nov 28, 2013 | Heating & Cooling
Honeywell cm61ng connection to relay box
Make sure the green button is on @ the relay box.
Nov 27, 2013 | Honeywell Programmable Thermostat Heater
IT COMES ON WHEN IT WANTS , NO MATTER WHAT I SET IT AT ITS A CM61NG , IF I SET IT AT 1,30 IT COMES ON AT 3 WIERD !!
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 25, 2010 | Honeywell Programmable Thermostat Heater
Cant get thermostat to bind with receiver box
Go to honeywell.com
Feb 14, 2010 | Honeywell Programmable Thermostat Heater
Remote not workin
what's happened here is the cm61 ng and the reciver box have lost there connection you will have to "rebind" them then it will be fine -
THE BINDING OPERATION DESCRIBED BELOW IS REQUIRED IF:
· Any of the system components (room unit or relay box) are replaced
· HC60NG has incorrect or no binding data stored (e.g. when pre-bound system pack components have been mismatched)
· Interference with the RF signal has caused a communication failure
During the binding procedure keep approximately 1m distance between the room unit and the HC60NG
1 Turn off mains supply to HC60NG for 10 seconds. Re-connect supply.
2 Press and hold the HC60NG push button for 15 seconds to reset previously stored data. The red LED will start to flash at 0.1 s on/0.9 s off. Release the push button.
3 Press and hold the HC60NG push button for 5 seconds to enter the binding mode. Red LED flashing at 0.5 s on/0.5 off confirms the binding mode has been entered.
4 Move the CM67NG slider to the OFF position (CM61 push the OFF button) and press the TEMP , TEMP and PROG 1 buttons together. The CM61/67NG will display InSt.
5 Press the i button to send the binding signal. The red LED is switched off on the receiver box to confirm the successful binding operation. If the red light still flashes push the repeat steps 1-3 and press the the i button until binding is successful.
hope this is helpful
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Honeywell - cm61ng- Keeps going on and off all night
Instructions on how to turn off your optimum start:-
Turn off ‘Optimum Start’
Step 1 Put the thermostat in the OFF position.
Step 2 Press 3 buttons together (at the same time) which are the INFORMATION BUTTON (i) and PROGRAM BUTTONS 3 & 4.
This will show a code of ICL 1 – now let go of the buttons.
Step 3 Press PROGRAM BUTTON 2.
This will now show a code of 30t 1
Step 4 Press the + BUTTON (on the left of the display), tap through until you reach 15 OP 1
Step 5 With the TEMPERATURE DOWN BUTTON; change the 01 to a FLASHING 0. Confirm the FLASHING 0 with the INFORMATION BUTTON ( i ). The 0 will now be static.
Step 6 Put the Thermostat back in the ‘AUTO’ position.
‘OPTIMUM START’ is now switched off.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
67 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
