Question about Coffee Makers & Espresso Machines
Slider is stuck closed in Nespresso U - Coffee Makers & Espresso Machines
2 Suggested Answers
  • 34836 Answers
SOURCE: I have a Delonghi Nespresso Machine and would like the location of a service centre in Delhi
Try searching online to find a DeLonghi service center.
Posted on Dec 16, 2014
Nespresso U coffee does not come through the spout
There are two nozzles in front of the machine attached together, the nose of the bigger one on the top slides into the smaller one on the bottom. When it makes coffee, the spout outside the machine becomes lower so coffee can come out. When it is done making coffee, the spout goes up so water/coffee drips in the drip tray. If one of the nozzles breaks, the spout on the smaller one will not go down and the inside end is lower and coffee goes inside the drip tray. It has nothing to do with cleaning.
Jan 20, 2014 | Nespresso Coffee Makers & Espresso...
Capsule stuck in machine (u) slider won't open. Have tried unplugging it. Still won't open. Desperate for a coffee!
Download user's manual from the manufacture's website and search the troubleshooting section. There may be a safety feature engaged preventing you from hot water burn.
Dec 22, 2013 | Nespresso C100B Essenza Single-Serve...
2012 HONDA ODYSSEY DOOR STUCK OPEN
It's possible the fuel door was left opened when the power slider opened? Turn off the power slider switch on the left side of the dash board (left of the steering wheel), then manually close the slider. Close the fuel door then turn the power switch back on. If it continues to jam, turn off the power switch again and open/close manually until you can get it to the dealer.
Jul 26, 2013 | Honda 2012 Odyssey EX-L
DeLonghi Nespresso U not puncturing capsule
Not a fan of nespresso, a lot of cheap plastic. I am guessing the pivot for the capsule puncture arm has worn out allowing some play in it, which is keeping it from closing all the way just a guess, but it is an issue I have fixed before.
May 02, 2013 | DeLonghi Coffee Makers & Espresso Machines
Slider is stuck in Nespresso U can't get it to come back. If I place a new capsule it falls right into garbage
Go on line with the manufacturer, Nespresso and request a complete parts list with drawing. It will show you all the parts and you can figure how it works from that. There may be a bad part in it that you will now have the exact part number to order. Good Luck...
Dec 15, 2012 | Coffee Makers & Espresso Machines
Nespresso essenza lever stuck
My Nespresso lever won't push back and it won't produce any coffee from capsule that is stuck in machine.
Jun 13, 2012 | Nespresso Essenza C100 Espresso...
Our machine does not puncture the Nespresso capsule - so we only get murky water.
I just had the same problem with my new (less than one month use) Nespresso U. (the top of the capsule doesnt puncture and only water comes through). I called Nespresso customer service and a very helpful man suggested I run water through three times by pushing the top slider open with the Longa button pushed and then closed without a capsule in the chamber. That released the air bubble and now I am enjoying a wonderful cappuccino again! The customer service is fabulous, there was never a suggestion of charging me and I was told that Nespresso will send me a free loaner machine if anything goes wrong in the future that can be readily fixed over the phone. The Nespresso U is the best thing I ever bought.
Aug 25, 2010 | Nespresso C100B Essenza Single-Serve...
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Coffee Makers & Espresso Machines Logo
54 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
