Question about Maytag 27" Built-In Double Electric Wall Oven - White
F 3 comes on when I press the oven temp or boil button. We have already change the sensor
  • Maytag Master
  • 842 Answers
This fault is a bad or open sensor to the oven, the control unit can't see the oven temperature and won't run it if it can't control it.
I hope this helps
Posted on Nov 28, 2013
Whirlpool Accubake Wall oven pre heat but temp goes 350 and downwards when pressing temp up
I am not sure about this, but sounds like a connector is on backwards or in the wrong place.
Nov 26, 2014 | Whirlpool Ovens
Whirlpool Oven GW395LEGT6 Replaced the oven temp sensor But oven will pre-Heat and run for 15 minutes then shut off with Error code EO F3
Have you tried pulling the connectors off the control board and reinserting them. If you still have problems the control board could be the issue.
Sep 24, 2014 | Ovens
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Whirlpool RBS305PD Electric Single Oven
I have a GE wall oven that does not heat up to the set point. Model JKP13GP. 75-100 deg cooler. The temp prob measures a little less than what is required. 1.00 in ice water, 1.07 @ room temp and 1.27 in...
No the sensor is going to be the problem...at room temp it should be between 1060-1100 ohms. In boiling water it should be somewhere around 400 and in icewater it should be appx.2500-3000
The sensor needs to be replaced. The part number for it is WB21X5301 it can be purchased at your local appliance parts store or online at
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
partselect.com
GENE
Sep 26, 2011 | GE Ovens
I self cleaned the oven and over 12 hours later am getting a f2 error. How do I fix it?
The F2 error code means that the oven over heated by at least 100 degrees and the oven temp.sensor needs to be replaced.
On the self clean cycle the oven temp can easily reach over 600 dergees and therefore the sensor thinks it got too hot. If you have not already done so the F2 can be cleared by pushing the CLEAR/OFF button on the control...if the F2 error code reappears the sensor has became defective and it would need to be replaced.
GENE
Sep 05, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
Temperature probe icon persists on the display and cannot be extinguished. Seems to be locking out other oven functions. Tried removing power overnight - no change. Followed protocol to turn off "Sabbath...
If the probe is not connected, then the actual connector in the oven is faulty. If you don't use the temperature probe, you can take the front control panel off and disconnect the probe connector. I did this 8 years ago
Jan 10, 2010 | KitchenAid KEBC107 Electric Single Oven
I have a Maytag Performa oven model pgr5710bdw. The Temp is all over the place, too high, too low and constantly changing. Cannot figure out what it will do next. I have already put in a new temp...
If you already changed your oven sensor, then your ERC or electronic range control is not reading your sensor correctly. You need to replace the ERC and its overlay. Not a cheap part. Also strongly recommend you buy a 2000 joule or higher surge protector to plug your range into, to prevent this problem from happening again. Good Luck, Appliance Specialists
Dec 22, 2009 | Ovens
Oven won't pre-heat
This is a failed oven temp sensor. the control is not receiving a proper resistance signal from this sensor at this time. the control will shut down the unit if this is the issue. check the oven temp sensors connections form the control to the sensor housing for loose or worn contacts, if the wiring is ok, replace the temp sensor.
Sep 24, 2009 | Ovens
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag 27" Built-In Double Electric Wall Oven - White Logo
37 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
