Question about Whirlpool GW399LXUS Stainless Steel Gas Range
Bake does not work Whirlpool GW399LXUS Stainless Steel Gas Range
4 Suggested Answers
  • 60 Answers
SOURCE: I have Whirlpool Gas Range
will the ignitor glow if it does and its dim the ignitor needs to be replaced if not the control board needs to be replaced
Posted on Aug 04, 2008
SOURCE: I have a Whirlpool GS563LXSS
Hold the night light button for @ 3 seconds. It works for me.
Posted on Oct 21, 2009
heatman101
  • 43501 Answers
SOURCE: Gas does not ignite/click on while trying to bake
The problem most likely is with the igniter that lights the burner for your oven. I have just written a tip on that subject. You can view that here.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 18, 2009
Top burners OK. On convect bake the oven will heat up to set temperature then shut off and cool down. Normal bake function seems to work ok.
PDF]BUILT-IN ELECTRIC CONVECTION OVEN - Whirlpool
https://www.whirlpool.com/.../Use%20and%...
Whirlpool Home AppliancesBUILT-IN ELECTRIC CONVECTION OVEN. Use & Care Guide ..... To Turn TonesOff/On: Touch and hold COOK TIME until a tone sounds and the lower oven ...
Teach me how to use my convection oven - Chowhound
Jan 01, 2016 | Maytag MES5875BAS Slide-In Electric Range...
Whirlpool gfg461lvs broiler won't light
Hello. How old is the range? The broiler ignitor might be worn out. The part number you might need is 8054129. The ignitor for the bake is 9758079. I hope this helps you.
Sep 12, 2015 | Whirlpool GFG461LVS Stainless Steel Gas...
My oven's bake will not come on. You can hear the gas come on, but it will not ignite. My range and broil are working. Had it serviced, but after replacing the ignitor, gas valve and module, it...
The holes on the actual bake burner bar(tube) could be clogged so ya hear the gas coming out the rest of it, the spark cant ignite the gas since the gas isn't getting to the spark. If it hasn't been done the holes could be poked with a paper clip to assure their clear,or the burner bar could be replaced. If that doesn't fix it it's what my airplane mechanic friend would call a hanger queen and that plane will never fly.
Good luck,i hope this helps,
Gene
Aug 04, 2011 | Whirlpool GS563LXSS - stainless Steel Gas...
Whirlpool GS563LXSS: bake and broil doesn't work.
Oven suddenly stopped to work.
After trying to turn on "bake" or "broil" I can hear couple clicks but nothing else happens.
No flame/no gas is coming out.
Mar 19, 2010 | Whirlpool GS563LXSS - stainless Steel Gas...
E1 -F5- .. Locked - displays after cleaning the
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Dec 21, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
Gas flow problem with stainless steel GE Adora stove.
If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Dec 19, 2009 | GE Adora JBP77SMSS Stainless Steel Kitchen...
Whirlpool sf368leps
can hold down bake the and adjustment comes up can adjust in 10 degree steps 30 degree up and 30 degree down use the temp up and down to make the adjustments
Dec 22, 2008 | Whirlpool SF368LEPS Stainless Steel Gas...
Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
Dec 18, 2008 | Frigidaire GLGF386DC Stainless Steel Gas...
Whirlpool GW399LXUS Stainless Steel Gas Range Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
