Question about Genie Company GV150 Wet/Dry Vacuum
Throws dust out side of the vac - Genie Company GV150 Wet/Dry Vacuum
    Top Expert:
  • Genie Company Master
  • 12,962 Answers
Bag is broken and contents are being blown out
Posted on Nov 28, 2013
Kobalt 10 saw blows dust everywhere ,even with a 2 shop vac connected to the dust chute .
It is possible that the dust chute on the Kobalt saw is plugged, not allowing the vacuum to pick up the dust. Run a rod through the dust tube and see if that clears it.
Jun 19, 2015 | Shop Vac Vacuums
Tip
Safe way to vacuum drywall dust
SAVE THAT VAC
One of the hardest things on a shop vac is drywall dust. It is so fine that it gets through the regular filter and destroys bearings/bushings and ruins the motor. Just the other day, a friend commented that he had to get a longer hose as his vac was blowing out a lot of drywall dust because the filter was slipping down!
High performance filters are available at most hardwares and box stores. They resemble the paperbag filters in carpet vacuums and catch the drywall dust so that the bag can just be thrown away when done. The bag is U-shaped to install in the shop vac and have clearance around the regular cartridge filter. The inlet has a rubber seal that pushes around the inlet on the inside of the tank. Just run the vac normally but spare it and your lungs!!!
on Mar 02, 2010 | Vacuums
How do I empty the mini shop vac?
Pull out on the clips on each side while pushing on the red part in the center of the clips. Pull black bottom away from the red top while pulling out on the clips.
Dec 11, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Ridgid shop vac. use filter or not when vac. water
Just use the sponge filter, if wet dust goes through the blades, it will build up, throw it off balance and the vacuum blades will break loose from the shaft.
Jun 07, 2014 | Shop Vac 925-13 Canister Wet/Dry Vacuum
My central vaccum just stop working last night. It does not turn on at all.
I've gone through 3 vx475 vac in the past 7 yrs. Last one was sent to me in Apr 2010. Just yesterday, once again, my vac just quit. Green power light is on but no other sign of anything. Had a burning smell when vac quit, like motor just fried. Called Nutone again and they can't imagine whats going on but will send out another vac free and was told to throw out old one. They said dust may get into the motor and cause it to quit. These vacs aren't cheap, can't imagine that its so simple to just call up and have a brand new one sent to me. I've asked if they are rebuilt units and was told no. So my advise to you, if you haven't already, is to simply call them up w/model and serial # and they shouldn't give you any prob. good luck.
Sep 03, 2010 | Broan-NuTone VX475 Bagged Central System...
Central vac... picked up rings, how do we get them back
Bummer! The rings are still there. They will either be lodged in the pick up nozzle or in the bag itself. Take the bag out, this will be am out door job due to the dust present. Open the bag and carefully search through the debris. They will be there. Don't throw that bag away until you find them.
Zashiban
Jun 23, 2010 | Electrolux Harmony Canister Vacuum -...
Dust shoots out the back of my shop vac...
Use collection bags or change the filter.
Jun 04, 2010 | Vacuums
Beater brush is good, vacuum running no suction
this sounds like your vacs dust passage from the rotary brush to bag is blocked ? you can diy this if you turn vac over to show the brush and covering cover you will see cover is held by some screw/bolts ? remove these and cover then the brush assy is slotted in place either side on bush/bearings and the drive belt is around the brush memorise how it fits! then gently/carefully lift brush out the belt will create spring action once brush removed you will see where the dust travels thro an arpeture on the belt side of vac this usually is where blockage is clear it out and any other within the area of brush then reassemble and check vac
Dec 08, 2009 | Electrolux Vacuums
Kenmore upright vac model 33922 - good suction but developed loud whining noise after accidentally vacuuming room without bag. Added bag and changed both filters. Still makes noise. How can I stop noise?
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Sep 14, 2009 | Kenmore 33922 Direct Drive Bagged Upright...
Dust blowing right back into the air
You need to check the filter and make sure it's on all the way. To do this take the top off the vac, make sure the filter is all the way up and in place. There should be a plastic nut to hold it in place. If you are using it for fine dust particles such as drywall dust, you need a special filter for small particles. The filter that comes with the vac just won't do it!
Mar 23, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Genie Company GV150 Wet/Dry Vacuum Logo
61 people viewed this question
Top Genie Company Vacuums Experts
Jim Parker
Jim Parker
ugeeks
Level 1 Expert
Are you a Genie Company Vacuum Expert? Answer questions, earn points and help others
