Question about Sony SLV-940HF VCR
VCR won't eject tape - timing of loading mechanism is off
I have a 940HF. Recently, I loaded a cassette which had, unbeknownst to me, one of those little tape labels that come with a vhs tape, stuck to the bottom ot the tape. Static electricity I guess. Anyway, I put the tape with the label stuck under it into the machine. The machine tried to load it. I heard a few loud clicks - which I assume were gears - and the tape got stuck in the machine halfway loaded. Pulled the cover, got the tape out. The machine wouldn't load anymore. I took the machine to a friend who is a tech. He took apart the whole loading mechanism and re-timed it. But here's the problem. We've set the timing right THREE times now. Every time it's used, everything works fine until you hit rewind. If you try to rewind a tape, it throws the timing back out again. This is making the unit useless. What could possibly be causing this? Why would a transport control affect the loading mechanism timing?
  • 3,267 Answers
Now-a-days most of the gears are made out of plastic(HDPE, if I remember correctly), when the rewinding command is given even if one gear tooth is worn/broken it will throw the entire timing out of 'gear'. Since the problem has already occurred, and, this is the only function that has malfunctioned my advice would be to leave it as it is! ('cos repairing/replacing it is manual & therefore a costly affair plus there is no guarantee that the replacedment will function properly)....sodeep
Posted on May 09, 2009
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
Toshiba VCR
Check this link it has some solutions that you can try in removing the tape inside the VCR http://www.fixer.com/no-eject.html
Hope that helps...........
Sep 12, 2008 | Televison & Video
I got an LG VCR GC980NW (MG 64) VHS VCR. I've wrongly pressed both the eject and play forward button at the same time. After that, the VCR shows both the 'EJECT' message and 'No Tape' signal, and then...
It is possible that the mechanism is out of mode as the front cassette loading mechanism and the tape forward loading mechanism have gone out of sync. Now it is important that the MODE of the system control is in the correct parking.
Hence I feel that the VCR must be opened and the mechanism reset-ted. Make sure that the tape loading has come back to the correct parking and also the cassette loading has returned, other wise remove the mechanism and reset.
Apr 05, 2011 | LG MG64 VHS VCR
Tape loaded normally but now won't eject. The unit just powers off after a few seconds.
Unplug the power from the combo unit and give it 30 seconds, now plug back in, sometimes this will eject the tape, if not! take the top off the machine and check to see if the tape is spewed in the mechanical section and around the video head, if yes! get a pair of scissors and cut the tape carefully to avoid damaging the video head and remove all tape deb-ri, now power up and eject the main cassette. But! if you find the cassette has loaded in place and the tape is still in the vhs cassette, this would indicate a loading problem with the main carriage, broken belt, bad idler assembly and possibly sensor issues.
Feb 06, 2011 | Sony SLV-D350P DVD Player/VCR
Fault F04
F04 is "loading lock". most likely problem is that the timing of the gears in the tape loading mechanism is mis-timed.
Aug 01, 2009 | Panasonic Televison & Video
Vcr will not load vcr cartridge
The tape mechanism is not loading and/or driving the VCR tape properly. Most people don't realize that the tape is physically pulled out of the VCR cassette and wrapped around the video heads in a semi-circle configuration. Your VCR guides are pulling the tape out but not retracting it into the cassette shell when you press eject. Causes: mode switch, mechanical failure, video head speed/drive problems. All these problems are somewhat complex for a novice repair person and don't forget that new VCR's are selling for $30 at the big box stores....Glen.
Jun 05, 2008 | JVC DR-MV1S DVD Recorder/VCR
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
SLV 940 HF
Is it having trouble either loading or ejecting the tape? If so, then something is probably awry in that mechanism. Take the top cover off and watch a load or eject operation. If tape isn't fully loaded, and tape threaded, then an error condition will result, as will be the case if it won't eject. Causes include a broken piece of the load mechanism (also called cassette carriage or carriage mechanism), broken or cracked gear. If the mechanism is gear driven, timing is critical, just being out of time one tooth will foul things up. There are often marks on the gears which must line up exactly in a particular mode as specified in manufacturer service literature. Most VCRs since the early '90s are disposeable, very prone to breakage, in contrast to early units which were made like tanks, costing $400 plus.
Aug 26, 2007 | Sony SLV-940HF VCR
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Jul 13, 2007 | Toshiba MW24F52 24" TV/VCR/DVD Combo
Sony SLV-940HF VCR Will not accept tape
Dear Rob, There can be two reasons for your problem.Let us consider the simpler and most likely cause.....Belts!!! Unplug the Plug from the Power socket. Open up the top and bottom Panels.Check the belts. Most likely you will find a belt has snapped ( a 80% possibility) or become very very loose. Also check the Tape Loading mechanism,there is a small belt which connects from the Loading motor to the Loading Mechanism. Replace the belts as a entire set. Let me know if this worked out. Good Luck.
Jan 27, 2007 | Sony SLV-940HF VCR
Televison & Video Logo
906 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
