Question about Capital Cooking Kitchen Ranges
Fan rattle when the range is heating and cooling and the fan slows to off it rattles. Sounds like a bell being rang
gandhiforyou
  • 275 Answers
SOURCE: DELONGHI GAS RANGE DEGESC24SS COOLING FAN COMES ON NEVER SHUTS OFF
http://www.delonghi.com/ go to this website and select the country you belong to . in there you will find customer services. they will provide you contact number to call. hope this will sort out your problem.
Posted on Jun 25, 2008
micromaster
  • 3614 Answers
SOURCE: delonghi gas range fan on all th time, almost
behind the control panel, there you will see the thermal switch/thermal fuse, this part is the one holds and trigger the cooling fan.. once this part is broken it could result in system malfunction, like the one you gave encountered..
micro
Boogan
SOURCE: Viking range self cleaning not working - door locked
This is a more common problem than revealed by Viking.
Heres how I an "amature" fixed it.
Top center of many viking ovens have slots. With a small flashlight look into the center slots. "Its HARD to see" Look for something
shiney thats the latch/hook everything else will be dark.
I used a shish ka bab skwer. You need something like that or maybe an ice pick. Knives screwdrivers and things like that will
damage the face of the oven and then after opeining it you will forever feel bad about marring that very expensive unit.
Take the pick and with the flashlight guide it to the shiney part.
Once touching push to the LEFT. Keep trying as the pick will slip
many times. The latch should have no resistance if you can get on it.
Once open you can try and reset the hook to its open position.
Mine would not reset and prevented the door from closing.
This is now another fix. To keep the hook held to the open position. E mail me for how I jury rigged this part.
Mexvillas@aol.com
I have the hook held open now and will never be able to use the self clean function again. But thats better for me than a open wallet fix for the repair man and then wonder when it will happen again. To repeat. This is a known problem with Viking ovens.
Cheers
Posted on Apr 08, 2009
SOURCE: kenmore elite slide in range model 790-4101
how do you take the top off this LG LRG30357ST i cant get a tool small enough to fit the back right burrned orifes to convert it to lpg
Posted on Aug 28, 2009
SOURCE: KGST307 Gas Kitchen Range: gas range will not heat up when using Bake setting...
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
How do I fix an engine rattle at low rpm, light load, city speeds? The spark plugs aren't due for replacement yet, should I be going after an exhaust sensor?
Depends on your definition of rattle. Engines don't rattle unless something is loose or a rock has landed in a cooling hole on the side of the catalytic converter. So , if you can give us a better description of what the engine is doing, you'll get a load of incorrect answers.
Aug 10, 2016 | 2013 Chevrolet Silverado 1500
How to fix a vibrating and rattling noise inside the oven. From time to time it just starts up and sounds like something is loose.
It turned out to be the fan on mine and fitting a new one stopped the annoying rattle and buzz if that is of any help to you.
Nov 09, 2015 | Kitchen Ranges
Car runs great except it has a rattle in the mid range ?
this may be detonation from incorrect air/fuel /timing combination. IT is generally lean mixture and mostly can be heard on acceleration. Run fault codes to find faulty sensor that is affecting the correct air fuel mixture.
Mar 20, 2014 | 1999 Saturn SL
I KEEP HEARING A RATTLING AND A BELL JINGLING SOUND
Three things come to mind. A heat shield is loose, The inside of the converter is going bad or you ran over a reindeer!
Dec 30, 2011 | 2005 Cadillac SRX
#23350303200 Kenmore Elite Range hood - Range hood exhaust motor slows down
You have 2 windings in the motor that create a magnetic field. A winding is simply a coil of wire an they do not touch. when applying the voltage (turning on the fan) the windings create the mag. field causing the rotor to turn, which then of course turns the fan blade. When these windings get weak it causes them to heat up due to the resistance in the circuit and you there for loose ur mag. field... Or if the rotor starts getting restricted it will also heat up the windings an cause the fan to stop.. Time for a new venta hood....
Dec 01, 2011 | Kitchen Ranges
1994 toyota pickup rattles at low speeds (~15-19 mph).
Check for loose heat shields the cover the exhaust. I find this is the source of many rattles. They are made of sheet metal and if they are not clip or tightened down the low vibration frequency when the car is running at slow speed will cause them the hit the exhaust pipe/ front mainfold.
May 08, 2010 | 2003 Acura MDX
Convection oven fan rattles when it is starting up after the oven has reached its desired temperature. The fan motor has been replaced once but it didn't fix the problem.
Check the shield in front ok the fan. It may have become distorted with heat and is now touching on the fan when the oven reaches temperature.
Nov 22, 2009 | GE Cafe CGS980S Kitchen Range
Bottom end rattle on 1st gaer take off
Sounds like pre-ignition, AKA engine knock and detonation.
Install new NGK spark plugs one heat range colder than stock. >>Only use premium gas.<< Run through a tank of premium gas. Change gearbox oil and filter. (clean oil cools better than dirty oil).
The problem will likely disappear.
Please rate this answer. Thanks!
Apr 08, 2009 | 1994 Yamaha FZR 1000
Kenmore elite slide in range model 790-4101
Jan 20, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Ranges Logo
22 people viewed this question
Top Capital Cooking Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Capital Cooking Kitchen Range Expert? Answer questions, earn points and help others
