Question about Frigidaire Affinity ATF7000E Front Load Washer
Affinity washing machine not level/unbalance. Harm machine?
  • 2,113 Answers
It's definitely not healthy for it. adjust the legs at the front and use a level on top while leveling. The rear feet self level
Posted on Nov 28, 2013
Stylemaster #4217140 Reguardless of how I load the washer it always ends up spinning unbalanced. The machine is level Lto R & front to rear.Any thoughts?
top loader
the problem will be that the tub support air dampeners have failed and any small unbalance is not controlled and so goes into big unbalance
a kit of 4 rods will be available from the service agent spares section and if the technician is doing the job about 15 minutes
if you are doing the job about 1 hour
Nov 22, 2017 | Washing Machines
Fisher and paykel aqua smart washing machine alarms to indicate imbalance during rinse and spjn cycle even when no clothes in it. Have checked that it is level.
when using a level to set the machine up use it on the tub and not the lid
the unbalance can be from a suspension isolator that has failed and dropped the tub to one side
Feb 04, 2017 | Fisher and Paykel Washing Machines
Model ATW 44775x00. Why does it become unbalance during spin cycle?
The tub balance could have been upset when the machine was moved to storage.
Oct 20, 2015 | Admiral Washing Machines
Washing machine
Two types of balance involved with washers. First is the machine. Most new machines are self leveling with the front legs. If the machine is not level, shake the machine to change it orientation. Most times this is cause leveling.
Second level is the load inside the machine. Clothes need to be distributed equally around the inside.
Oct 15, 2013 | GE GTWN3000MWS Washer
Affinity will not turn on
Hi Patricia Benninger - You may try and reset the washer by disconnecting the power to the unit for up to ten minutes by flipping the circuit breaker off and back on. Is the washer making a humming noise? If so, either the drain hose or pump is clogged and needs cleaning. Will the drum manually rotate (when it is not in use)? If it does not, then the drum could possibly be unbalance and/or have a broken shock/bearing. Other possibilities are: experiencing an issue with the door lock assembly, control board communication, faulty timer/pump, and damaged cord. Because it could be a number of any one of several underlying causes, I would recommend reaching out to an expert to properly diagnose and repair the unit.
Mar 25, 2013 | Frigidaire Affinity FAFW3577K Washer
Lg washer dryer wd12126rd what does ve symbol flashing mean.
Actually it is UE error.It means UNBALANCE error where either the machine is not LEVEL or wash inside is on one side.
Check.
ALPER
Cyprus
Aug 05, 2010 | LG WD-12126RD Front Load Washer / Dryer
Spin cycle tub becomes unbalance
When the drum gets unbalanced more often then not, there's a few things to check:
1. Check to make sure your machine is level. Check level from side to side and also front to back. The machine has leveling feet to adjust. Make sure they are all in firm contact with the floor when leveled.
2. Wash items that are alike in material. In other words, wash towels with towels, shirts with shirts, etc. If you wash a load of shirts with a towel, it will have a tendency to get unbalanced quickly.
3. Avoid over-stuffing the machine and washing under sized loads. Both of these scenarios will cause a tendency to go out of balance on the spin.
This will solve 75-80% of unbalance issues. Let me know how it goes..
Dec 07, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Water level
its a h/e washer its uses lesss water duh
Dec 08, 2007 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Unbalance
You problem may a simple leveling issue. Check your machine front to back and side to side to ensure it properly level. Also, most top-loaders have "self-leveling" feet on the rear legs. If you walk up to your washer and it looks like the back is sitting lower than the front, you may only have to follow a few simple steps to re-level it. If your machine is equipped with this type of leveling system all you have to do is to lift the rear legs of the floor about two-inches by rocking the machine (empty of water, of course) towards you: 1. Lift the lid. 2. Place one hand under the rim of the front casing (not the wash tub). 3. Place your foot at the center of the front base to keep it from sliding. 4. Pull towards you to lift the back feet off the floor. 5. You should hear clicking noises as the feet re-level. 6. Slowly lower machine back to the floor. This should take care of most leveling problems that cause your machine to vibrate and shake during the spin cycle. These legs periodically become unlevel due to vibration and need to checked from time to time. I hope this may help you.
Apr 09, 2007 | Magic Chef CAV4000 Top Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
19 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
