Question about Toshiba Computers & Internet
I had set a password for my harddisk and now I wish to remove it. Please assist me how to do it.
Toshiba, Processor Intel 2 Duo CPU, RAM 2.87GB,My e-mail address is fillifour@gmail.com
Go to Sony website for support and drivers and then check the type of chip set used for display drivers most likely it will be Intel Graphics Driver then search for that in Linux forums,alternatively you can try to update packages on your Operating system
Posted on Nov 28, 2013
Lollyloopp
  • 31 Answers
SOURCE: Manual for Toshiba Satellite P105-S6217 Notebook
You should be able to download from the following link:
http://www.askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1621541xml&sliceId=&dialogID=26002858&stateId=0%200%2026004004
look for the userguide next to file.
Hope this helps!
Posted on Nov 29, 2007
  • 66 Answers
SOURCE: upgrading the Toshiba P205-S6237 Inel cpu T2080 to a newer one
if you email me the model part number i will tell you. vaughns@cssnow.com
Posted on Oct 30, 2009
SOURCE: Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
Posted on Mar 12, 2010
KingDWS
  • 1606 Answers
SOURCE: Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Posted on Apr 12, 2010
Testimonial: "Thanks for the quick response. I was afraid that might be the answer but I appreciate the confirmation."
puertobori
  • 7733 Answers
SOURCE: I want to restore my Toshiba Satellite Pro to
Set BIOS defaults
  1. Press the [F1] key.**** Bad RTC battery ****
    **** Bad Checksum (CMOS) ****
    Check system, then press [F1] key
  2. In the BIOS setup screen press the [Home] key to restore the default values, then press the [End] key to save and exit, then the [Y] key to confirm and restart the system.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 27, 2010
My system config is : Intel C2D E7500 with 2.93 GHz CPU MOBO is Intel DG41RQ and 2gb DDR2 RAM OS is Windows XP - 32-bit (Service pack 3) Problem is overall system performance is not good. System is...
A slow computer could becaused by a number of things - 1. InsufficientRAM memory - if your computer has less than 512Mb of RAM then increase it to atleast 1Gb of RAM. 2. Registryproblems - clean and repair the registry, it will contain unused registry keys.Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/removeunused programs, this will also free up hard disk space. 4. Notenough hard disk space - swap file space may need to be increased if Windowshasn't been configured to manage it. 5. Installlatest Windows updates. 6. Updatevirus definition files and scan computer for viruses, Trojans, malware etc. 7. Clearthe Internet cache for faster browsing. 8. Harddisk maintenance is required at least once a month to keep it functioningefficiently. Runthe following programs - Disk Cleanup -removes temporary files that are no longer used and to recovers hard disk space. DiskDefragmenter to make fragmented files into contiguous files and thereforethe hard disk access is faster.
Jul 28, 2011 | Intel DG41RQ Motherboard & Core 2 Duo...
My Core 2 Duo CPU Fan has got a problem recently. Would any replacement of the Original CPU Fan be harmful to the computer? If there is any such problem, please let me know. Please suggest any CPU...
Try newegg.com, tigerdirect.com,directron.com,geeks.com. You want a Core 2 Duo cpu fan oem (socket LGA 775). Should be able to get one around 10 dollars or so plus shipping. You can pay more for a bigger fan but you really would not need it. OEM will be just fine.
Jan 11, 2011 | Intel Computers & Internet
I have a Intel D865GLC and it will not boot! The green led light on the motherboard is lightning and the CPU-fan is rotating but there is no screen on the monitor and the computer is not boot A have tried...
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattch both.
Make sure motherbord is not ground with cabinet.
When you power up the computer press F1 or F2 or "del" key then enter in bios .
Make sure in bios your harddisk is detected.
If not then change SATA or IDE cable of harddisk.
Then check .Go to boot menu nof bios then set first boot device as your harddisk.Then save settings and exit.
Let me know if you need further assistance.Thanks.
Nov 13, 2009 | Intel D865GLCLK Motherboard
Earlier i had ASUS P5G-MX motherboard & 2.0 GHz Core 2 duo Processor.I upgrade my Motherboard to Asus P5KL-AM/PS & then i have a black screen with my 2.0 ghz processor, But i tried 2.8 ghz Core 2...
HI,
The only Thing To Do, is view both Motherboards, user Manuals.
To see The boards CPU Support List.
It could be to do with, certain Motherboards Supporting, certain CPUs.
I.e a 533mhz cpu, would not run on a Motherboard that supports 400mhz. The Systems Bios, May cause Other Problems.
If your getting a Black Screen, is it a possible Graphics/Ram Problem, Rather Than The CPU ??
Mike @ Compurepair.
Oct 22, 2009 | Intel Computers & Internet
Maximum HARDDISK CAPACITY FOR Intel 865GV motherboard
Yes, your board will support 320gb. I am not aware of a limit to how many gigabytes you can have per computer. I currently have 1.5 terabytes. 1500gb.
Apr 22, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Passowrd
Try this Link. Pay and download the software. follow instructions and remove the bios password, cheap price to pay,
Mar 16, 2008 | Intel Core Duo T2300E, 1.66 GHz...
Buying a laptop
I wasn't aware they still put mobile Pentium 4 processors in laptops. If you can, you should get an Intel Core Duo or Core 2 Duo.
Other than that, the specs look pretty good. You might want to upgrade to 2GB of RAM though if your computer is going to be running Windows Vista.
Regards,
Javabytes
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
20 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
