Question about Carrier Refrigerators
What is fault code 89 - Carrier Refrigerators
Miele washer w2809 fault code F144
fault codes are only showing to f 89
May 07, 2017 | Miele Washing Machines
89 bronco II fuel injectors not squirting fuel. have good pressure to rail
You need to run a fault code test, also make sure your check engine light works, if not check to see if the fuse and relay for the ECU is ok and the computer is getting power. To do a fault code test follow the link. http://www.tomco-inc.com/Tech_Tips/ttt6.pdf
Nov 04, 2016 | 1989 Ford Bronco II
Put brand new coil on 89 Camaro but still no fire going to distributor
Check the power cables and HT leads.
Check fuses and relays.
Check timing and dis cap and make sure all ground cables are secure.
Oct 18, 2016 | Cars & Trucks
89 dodge d150 318 tbi turn key to on position gas pours out of injection and fills throttle body in seconds I'm wondering is this absolute proof of complete failure of fuel pressure regulator failure?
89 dodge TBI system - that is NOT proof of the Pressure Regulator failing.
The fuel system will pulse on when the key is turned on to charge the fuel rail for starting. The injector should not leak - probable injector failure (stuck open) - try disconnecting the wiring to the injector (to rule out computer controls) and see if it still leaks with just Key-On. If it still does you can also tap the throttle body case where the injector is - if it stops - definitely the injector (don't damage the throttle body - lightly tap )
You may want to retrieve fault codes before you try disconnecting things and creating new faults. If you don't have a code reader - try Key On - Off - On - Off - On (without cranking) and count the flashes of the engine lite - all two digit codes - usually starts with code 12 (battery disconnected recently) and ending with 55 (end of tests)
Feb 05, 2015 | Dodge Cars & Trucks
What is the fault code 89 and what is the toyota p code
P is powertrain and the code is always figures or a letter and three figures i.e P0300 meaning random misfire.
please specify full code
Sep 05, 2014 | 2007 Toyota Quantum 2.7
89 ford bronco II uses to much gas
Check the system for fault codes this is called an EEC IV fault code test by Ford. Also make sure the fuel pressure is within the spec, that is 42-46 PSI at idle.
May 30, 2012 | Ford Cars & Trucks
What is code 89?
81. - 95. (0101xxxx) Phase 2 to 3 - Display/ Motor Controller.
See fault code 106
104. (01101000) Phase 2 to 6 See fault code 106
106. (01101010) Phase 2 to 3 - Display to Motor Controller module
Communications Errors (Phase 6 IW also)
These faults are reported when the Display module detects an error in the
communications between the Display module and the Motor Controller module.
Primary Source: Display module.
Action:
Replace Display module.
Secondary Source: Motor Controller module.
Action:
Replace Motor Controller module. If the new Motor Controller module corrects the fault, refit the original Display module.
Feb 18, 2012 | Fisher and Paykel GWL11 Top Load Washer
89 Isuzu 2.6liter petrol 4ze1 what is fault code 12
means diagnoses is starting or no trouble codes stored
Oct 25, 2010 | Isuzu Rodeo Cars & Trucks
Computer storing codes; need to clear them.
With the ignition ON, press OFF and WARM on the A/C panel . Ahter codes appear , press OFF and HI to clear codes. If faults still remain, codes WILL NOT CLEAR. Hope this helps
Apr 20, 2009 | 1989 Cadillac Eldorado
Refrigerators Logo
20 people viewed this question
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
