Question about NorStar M7310 Corded Phone
Cics - blinking arrows never stop, date will not come on. can you help?
System would come on for a few minutes and then go down, now it won't boot up.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
This can happen if two phones get plugged into the same line. Try swapping this phone into an extension with the same type of phone and see if the same thing happens, if it does, the phone is bad. I recently had a phone doing the same thing, replaced it and the extension was fine.
Posted on Jan 27, 2014
My uniden phone message light won't stop blinking. Have deleted all messages. How do I get the annoying light to stop??
click on menu button
move down to answering set up keep going down to global set up
click menu and down to VMWI press menu
' move down to yes press menu and end
it starts from NBN installation
It will continually reappear so when you get the process correct copy it down
Oct 01, 2017 | Lands Phones
Seting time
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date.
Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date
press F10 to save to cmos and restart
hope this helps
Jul 28, 2012 | HP Pavilion dv9208nr Notebook
Cmos checksum bad boots to the splash screen then goes black with a blinking white line tried reseting the jumper cmos no luck load default settings no luck removed psu and battery no luck
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Oct 08, 2011 | EliteGroup ECS Socket Micro ATX...
Reason for showing "check main
your bios has been damaged the bios chip on your motherboard could be damaged to check it
restart your compuetr during the boot up process you will see a certain key to press to enter set up (bios) press and hold that key to enter bios using the arrow keys scroll to load optimised defaults
You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
hope this helps you
Sep 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
I can not get alarm to work on Constant elite colour change LCD alarm clock
Underneath clock there is 4 buttons, 2 of which are marked (m) & (s) and the other 2 buttons marked with arrows for (up) & (down). depending if you have the clock, alarm or date showing press down on the (s) button for about 3 seconds and the hour digit will start flashing, use the (up) & (down) arrows to set your hour. Then press the (s) button again just briefly and the minute digit will flash and use arrow (up) & (down) buttons to set this also. Press the (s) button again and all will stop flashing and Alarm or Time or Date will be set. Hope this helps as i had same problem but figured it all out in about 2 minutes as i couldn't find my manual lol,.
Jan 27, 2011 | Vacuums
Set right time on WIL
Hi this is how you can do it
First go into settings then calender.
This option lets you adjust the date and time of the console's internal clock. Please note that the Wii console uses a 24 hour clock. For example 1:00 pm is displayed as 13:00.
To Access the Calendar
  1. Access the Wii System Settings
  2. Choose "Calendar" on System Settings 1.
To change the Date
  1. Point at the up or down arrows for the part of the date you wish to chance (Month/Day/Year).
  2. Press the A Button on the up or down arrow to adjust the date as desired.
  3. Point on the "Confirm" button and press the A Button to set the date.
To change the Time
  1. Point at the up or down arrows for the part of the time you wish to chance (Hour/Minutes).
  2. Press the A Button on the up or down arrow to adjust the time as desired.
Jan 18, 2011 | Nintendo Wii Console
I have a hyundai radio 5064 and I want to change the time on it?
I have an 02 Santa Fe with 5064 radio. Here is what works for me. Key to ACC.
PWR on radio to OFF (display time only).
Press & hold { 4 D- } & { DISP } button simultaneously for about 3 seconds. Time will blink. If time does not blink, turn key to OFF, back to ACC & start over.
With time blinking....
Press { TUNE/SEEK UP } (double arrows) button to get desired hour.
Press { TUNE/SEEK DOWN } (double arrows) button to get desired minute.
Once set, wait a few seconds for time to stop blinking & your done.
Jul 17, 2010 | 2002 Hyundai Santa Fe
How can I restore to factory settings w/out restore discs
how about trying to restore to a point where everything was running real smooth,,,go to start/all programs/ accessories / system tool /system restore..check off restore to earlier date try to go back at least 2-3 month if possible..click ok..system reboot and prompt you on start up is this earlier date you chose okay...click okay
Jun 23, 2010 | HP Pavilion A610n (PC106A#ABA) PC Desktop
Changing the time on my Nortel T7316
Depending on the system that you have (BCM, CIC's, MIC's) and sotware levels, there are a couple of ways to get this to change the time and date on these systems...
There is the easiest way which is go to a set and dial without picking up the handset, this depends on the software level of the system if this is allowed or not:
-> Feature * * 8 4 6 3 (TIME)
and set the time and date by pressing change or next at the appropriate locations. Hours are to be input military time (24hr)
Then there is the longer way if that way did not work, for MIC's or CIC's systems:
-> Feature * * 2 6 6 3 4 4
-> password: 2 3 6 4 6 (ADMIN) (This have been changed by the programmer - you can also try 2 6 6 3 4 4 (CONFIG) as an alternative)
Now you will have to look at your LCD for 3 arrows
<- Heading....Enter->
<- Back .......Next->
You will not see these words in the LCD display, you just have to look for the 3 arrows that correspond.
-> you will now see TERMINALS&SETS press the NEXT button till you see TIME&DATE and press Enter and Change at the appropriate locations.
For BCM programming:
-> FEATURE * * 2 6 6 3 4 4
-> User ID: 7 3 8 6 6 2 (SETNNA)
-> Password: 2 6 6 3 4 4 (This have been changed by the programmer - you can also try 2 3 6 4 6 (ADMIN) as an alternative)
May 10, 2009 | NorStar T7316E Corded Phone
CLOCK RESET
Press the FN + F9 keys until the time and date appear on the LCD display.
press the FN + F10 keys to go into the Set Mode.
Use the left or right arrow keys to select the hour.
Change the hour by using the number keys on the keyboard or by up and down arrow keys
Use the right arrow key to select the minutes and change the hour by using the number keys or by using the up and down arrow keys Press the right arrow key again to choose the 12-hour or 24-hour format with the up and down arrow keys.
To change the date, use the right arrow key again and use the up and down arrow to select the month. To change the day, use the right arrow to select and the up and down arrows to change the day.
When you are finished, press Enter on the keyboard to exit Set Mode.
hope this helps
Apr 02, 2009 | Logitech Cordless Desktop MX3200 Laser...
NorStar M7310 Corded Phone Logo
18 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
