Question about Whirlpool Duet GHW9150P Front Load Washer
Remove inner tub from washer model # wtw5500xlo
tzweeb
  • 318 Answers
SOURCE: I am trying to clean out all the gunk that has
there is a special nut called a spanner nut. it is about 1 1/2 inches and needs special tool to remove it to get the inner tub out of the unit. you might be able to remove it with a pipe wrench and then you can get access to the outer tub.
i would recommend just using a washer cleaner and trying that first.
these chemical cleaners are designed to remove residues and are much easier then taking the unit apart.
Posted on Feb 23, 2009
  • 2976 Answers
SOURCE: Nail protruding into inner basket from outside
Hold the basket and remove the nut in the center. It's reverse thread.
Posted on Jul 01, 2009
TheMobilian
  • 8220 Answers
SOURCE: Washer gives F50 error. I've taken top off and
Press pause cancel once and that should do it. If not the repair manual advises calling for service. Lets see what the F50 is...hold on...Motor stalled, rotor position sensor detects no motion from the tub, does basket move freely? If basket moves freely see test#3 in the repair manual HERE
The manual gives readings to verify and has a long detailed complicated set of IF's for this machine. Good luck
Posted on Jan 12, 2010
TheMobilian
  • 8220 Answers
SOURCE: My washer has water in the bottom under the inner
What you hear is liquid in the balance ring. Normal.
Posted on Jul 22, 2010
red2872
SOURCE: I have a whirlpool Duet washer model GHW9150PW0
There is a lifetime warranty on this main basket. and 10 years on the outer front and rear buckets. My unit is 7 1/2 years old. and had the same problem. One of those 3 spokes connecting the main shaft to the rear bucket cracked and killed the front outer bucket. Whirpool tried to tell me I needed a professional to diagnose it but I told her the rear outer bucket was cracked, leaking water, and shredded the front outer. She sent me all three parts for $0! It took 2 hours to get apart and that was me being super careful. The parts will be here tomorrow morning! I did needd to buy 2 shocks at $21.00 each.
Posted on Dec 14, 2012
Remove maytag inner tub
Remove top cover, take out the bolt remove the small cover to expose the plate with several screws,remove the screws and lift the inner tub up. Usually this requires two people to get the tub up and out as it is very hard to pull up as it kind of sticks to the shaft
Jul 02, 2015 | Maytag Atlantis MAV6000 Top Load Washer
My whirlpool duet front load washer has loose fins in the tub. how do i tighten them??
You're not gonna like this:
Pull the washer tub (see elsewhere on FixYa for step-by-steps), split the tub by removing the screws holding the two halves together, and remove the inner tub. Bend any tabs tighter that hold the fins on, and tighten any screws. While you have it apart, check for grease stains or other leakage on either side of the outer tub, and ensure the inner tub bearing is tight so that the inner tub shaft rotates smoothly and without oscillation. If there are stains or if the bearing is showing wear, replace that (back) half of the outer tub to replace the bearing (unless this is one of the few machines that allow you to replace only the bearing). You don't want to put all this back together, only to have to take it all apart again when the inner tub starts hammering on the inner tub because the bearing went south.
Jul 24, 2012 | Whirlpool WFW9550WW Duet Steam 4.4 cu. ft....
Trying to remove spin basket (inner tub) from Washing Machine
See the Sears parts site for washer 82372110.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82372110
The following may also help.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=146
Jan 25, 2010 | Kenmore 22422 Top Load Washer
My washer agitator spins but the tub doesn't,also see metal insid
Repair or replace is always a judgement call. Most people will be better off replacing the machine. This is a rather big job, labor wise. On a difficulty scale of 1 -10, I'd give it an 8. The metal is the inner area between the inner drum and the transmission shaft, which has corroded and started to break apart. (located under the agitator) To repair, the agitator is removed, the washer front and top are removed to allow the washer's outer tub cover to be removed. This allows the inner tub to be removed. (caution: the big nut under the agitator drive spline is a left hand thread) Then, the drain hose, water level hose, suspension rods, and electrical to the motor are all removed to allow the entire drum to be removed from the washer to allow the inner tub to be removed. The actual metal part which needs to be replaced is then easy to replace by removing a few torx head screws from the underside of the inner tub.
Oct 02, 2009 | GE Profile WPSR3120WWW
Washer has a very musty smell. Trying to raise the top to clean inner tank but it will not budge. Does the top raise on the WJSR2070B model. Do not want to break it
Yes, but I would advise to try a washer cleaner before going through all the work to dissassemble your machine.
Use the longest, hottest cycle. You may have to run the cycle with a cleaner twice to remove all the built up soap scum inside the washer.
You could check out http://www.smellywasher.com/ for one possiblity. Others are " Washer Magic " or these: 73b1c2a.jpg fb3071a.jpg
If you still want to tackel the dissassembly: The washer front comes off by using a putty knife to push in the two retaining clips on the very top edge, where it meets the washer top. Now you will be able to access the screws which hold the top down. Of course to remove the inner tub, you still have to remove the lid switch, the agitator, agitator drive, the left hand threaded nut below that, the wire connection to the motor, the four tub retaining straps, the tub to pump hose, the four suspension rods, the tub cover and the water level hose. Then you would be able to remove the inner tub and pressure wash out the outside of the inner tub and the inside of the outer tub, if you bring the tub assemble outside. TRY THE CLEANER FIRST !!!!
Aug 16, 2009 | GE WBSR3140DW Top Load Washer
GE washer Model WDSR2080D5WW Transmission shaft wobbles
If you can't loosen the nut, you can break it with a hammer and a metal chisel. Tub nut is cheap. Grease on clothes = new transmission time.
By the way, after you remove the inner tub,.... you have to take the entire outer tub assembly out of the washer, flip it upside down, remove the yoke that holds the motor onto the outer tub, and pull the transmission out through the bottom of the outer tub.
Jun 11, 2009 | GE WDSR2080D Top Load Washer
I am trying to clean out all the gunk that has built up between the inner and outer tub on my trusty Kenmore 60 series washer. I have removed the agitator and tried to life the inner tub out to no avail. ...
Feb 23, 2009 | Whirlpool LSQ8000 Top Load Washer
Maytag mav6200aww removing inner tub
I broke a hammer removing the basket on a 6000 series today. These are known to be a real ***** to remove. Once those screws are out there is a seal nut to remove and the basket hub assembly is what it sits on. Look at 5 and 7 below.
Jul 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire Washer - Loose Inner Tub
the inner drum is most likely broken. go to sears.com select appliances then select parts enter model number and you can get a blow up. Hope this helps.
Jan 31, 2008 | Frigidaire FWT449
Maytag Washer: How to Remove Tub
Under the agitator is a flat nut with notches in it. this nut requires a spanner wrench that will fit into the notches. You can use a large channel lock plier. rotate the nut counter-clockwise. under the nut will be a seal. remove the nut and the seal and pull up on the inner tub. to replace you'll need to replace the seal. if the nut isn't too chopped up, use this to refasten the tub.
Sep 05, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
