Question about Baby Gear
How to set time zone on Digiview PCR102W - Baby Gear
How do I set time zone? S/N: 502 16764PH.
Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there's nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet clock radio as follows: ZONE 1 - Atlantic Time ZONE 2 - Eastern Time (Default Setting) ZONE 3 - Central Time ZONE 4 - Mountain Time ZONE 5 - Pacific Time ZONE 6 - Yukon Time ZONE 7 To c h a n g e t h e d e f a u l t t i m e z o n e d i s p l a y, depress the TIME ZONE button. The number "2" will appear on the display indicating that the default zone is ZONE 2, Eastern Time. Hold theTIMEZONE button and then press either the or buttons your own time zone appears on the display, then release the buttons. The clock display will change to the correct time in the time zone you selected . The clock will always return to the correct time in the zone you selected after every power interruption. http://www.emersonradio.com/resources/owner_manuals/manual_1396274206.pdf
Apr 08, 2016 | Emerson Smart Set Alarm AM/FM Clock Radio...
Tip
Procedure For Setting Time Zones For Emerson Clock Radios
IMPORTANT: The first time you connect your new SmartSet® clock radio to
zone. If you live in the Eastern Time zone, there’s nothing else to do. Your
display to your own zone. You only do this one time and the SmartSet® will remember
interruption.
There are 7 time zones programmed into your SmartSet® clock radio as follows:
ZONE 1 — Atlantic Time
ZONE 2 — Eastern Time (Default Setting)
ZONE 3 — Central Time
ZONE 4 — Mountain Time
ZONE 5 — Pacific Time
ZONE 6 — Yukon Time
ZONE 7 — Hawaiian Time
To change the default time zone display, depress the Time Zone button.
The number “02” will appear on the display
Eastern Time
on Jun 12, 2009 | Emerson Smartset Clock Radio
Setting time smartset
I couldn't figure out how to change the time zone because I didn't have the manual. Here's how to change time zone:
1. On top of clock you hold down time zone button
2. Push the up or down button to change the time zone. There are 7 time zones. The clock is set at zone 2 -Eastern Standard time. My zone is 3 -Central Time - I then had to manually set the correct time -(I'm not sure why but I did that) To test if the time zone worked properly I switched the time zones and the time on the clock adjusted automatically to the associated time for that area. I, of course, moved it back to zone 3 and the correct time for central time was displayed. I am waiting to see if the time properly adjust when time the DST changes. Also, for the manual: http://www.emersonradio.com/owner_manuals_list.php?ID=157
This is the manufacturers website (Emerson) for the EZ Set clock radio. Hope this helps.
Oct 03, 2013 | H.H. Scott SCR120 Clock Radio
Sentry self setting atomic clock lost the instructions
Select The Time Zone - For Sentry Self-setting Atomic Clock (ATC - 10)
The default time zone is Pacific zone.
1. In the normal time mode, press the MODE key to enter the alarm time mode.
2. Press the SET key to change the time zone.
each press of the SET key will move the time zone back one hour
P= Pacific M=Mountain C=Central E=Eastern
3. Press MODE key when correct Time Zone is highlighted.
I think the Instructions may tell you to use the ADJUST key instead of the SET key.
ADJUST key does not work for TIME ZONE change, SET key works.
This will set your clock to your chosen Time Zone for normal time.
Instructions for the ATC20 are located at the following url
http://www.sentryindustries.com/pdf/instructions/ATC20_instructions.pdf
Sep 28, 2010 | Office Equipment & Supplies
How do you set the alarm for pacific standard time on the emerson
Here is the procedure for setting the time zones for your Clock/Radio. Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time I will give you the web link for the owners manual so you can find any other information you might need for your Clock/Radio. (http://www.emersonradio.com/owners/iPod%20Series/iC200_042007.pdf) copy this web address and paste it in the address bard of your browser and it will take you to a pdf copy of the owners manual. I hope this information help you with your problem.
Apr 27, 2009 | Emerson Smartset Clock Radio
Time Zone Setting
Sorry it took so long to give you a answer to your problem. I hope this information help you with the problem. Thank you for using FixYa and have a nice day! Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time
Nov 04, 2008 | Emerson Smartset Clock Radio
Why won't it automatically set time?
Sorry it took so long to give you a answer for the problem.I hope this information help you with your problem.Thank you for using FixYa and have a nice day! Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time
Oct 21, 2008 | Emerson Smartset Clock Radio
IPhone sync with Outlook Calendar - Appointment time put on iPhone 1 hr later.
This solution pertains only to the one hour time difference people notice upon syncing to MS outlook.
In iPhone, there are two areas where you have an option to change your time settings.
1. When you go to 'settings', then to 'general', you can set up time and date, and also 12-24 hour format. Please note that changing the time here DOES NOT correct the problem, despite iPhone displaying correct date, time and time zone. Many people in this thread have stated that the problem persisted despite them setting appropriate time zone.
2. When you go to 'settings', then to 'mail, contacts and calendars' row (NOT the 'General' row) - you get an option to change your time zone at the very bottom of all the choices. You will see that wrong time zone is selected here - likely cause of the problem. Correct this choice and the one hour discrepancy between appointments in outlook and iPhone disappears.
Additional problem solutions - in the solution No. 2, if you set 'Time Zome Support' to 'ON', then all your appointments in the calendar will be displayed in the time zone of your HOME address. In other words, for example, if you are a person in central time zone, your appointments will be displayed ALWAYS in central time zone format - they will NOT change automatically when you travel from central time zone to eastern time zone. On the other hand, if you set the time zone support to 'OFF', then all your outlook appointment display times will change and adjust according to any time zone you travel to - This is often an inconvenience since most of us would like to remember our appointments as they were made in our home time zone, regardless of what time zone we traveled to.
Please note that the above solution pertains to only display of appoint times in outlook - This solution does NOT relate to the time displayed by iPhone and how that displayed time adjusts when you travel to different time zone away from your home time zone. This second issue is addressed below -
You can get your iPhone to display the current time in two ways -
1. Either always show the time in your home time zone, regardless of where you are (i.e., a person from Texas central time zone can set up to see the time always in central time, even if he/she travels to another time zone). This display setup is good for people who always think of time in their home time zone and then do mental conversions to reach at the local time zone time.
2. On the other hand, you can get iPhone to do this for you and change displayed clock time automatically to the local time zone that you have traveled to, away from your home time zone. Please note that enabling this capability in iPhone has no bearing on how the appointments are displayed in MS outlook.
Go to 'Settings'. Go to 'General' tab. then click on 'date and time'. Pick the 'set automatically' option to 'ON'. Now, the iPhone will automatically adjust displayed time to show the current time in which ever time zone you travel to.
If you set the 'set automatically' option to 'OFF', then you can select your home time zone. Then, the iPhone will always display time in your home city time zone and will NOT change even if you travel to a different time zone.
So, in summary, there are two places you need to adjust the time zones in iPhone - to do two separate tasks, first task of displaying appointments always in your home time zone upon syncing with outlook thereby avoiding the one hour skip; Second task of getting iPhone to display either your home time zone clock, or getting it to adjust current time to reflect the time in new time zone you travel to.
Hope this helps.
Dec 12, 2007 | Apple iPhone Smartphone
Resetting the atomic clock to the correct time zone, and outside temp to work.
For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
Good luck,
Doc
Dec 01, 2007 | Baby Gear
Baby Gear Logo
111 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
