Question about Hoover Dryers
Have a Hoover Dryer D6792 that as soon as the Dial is turned /the Door button pushed in to start, trips the safety fuse in the house switchboard. I suspect the heating coil is blown. Can get the screws off the back easily but then am confronted with the back of drum, any instructions from there appreciated.
watugot
  • 290 Answers
SOURCE: Kenmore 62822 electric dryer
Check your heating element to see if it is shorted to ground.
The element has 110V to it all the time, so if the element shorts to ground it will heat all the time. This is a fairly common failure.
If the element is ok, you may have a stuck centrifigul switch inside the motor, this is very rare but does happen sometimes.
Post back to let me know what you find or if you have any questions.
Thanks/Mike
Posted on Dec 20, 2007
  • 2315 Answers
SOURCE: Matag Dryer won't run
If the thermal fuse is blowing or the breakers when you bypass the fuse it means a part has a short circuit. There are more than one thermal fuses in there, so you will have to find where the one that blows is connected to.
My guess at this point would be that the motor or the start up capacitor are causing the fuse to blow but also check for a defective or shorted heater element.
Check this site for additional help: http://www.applianceaid.com/may-apart.html
Posted on Feb 08, 2008
jonniewalker
  • 1029 Answers
SOURCE: Hotpoint Aquarius Dryer TL61
check the thermostat that regulates the heating cycle if its in good condition and the thermal fuse. If the fuse is blown you will want to replace
Posted on Aug 12, 2008
AlmostBob
  • 550 Answers
SOURCE: I have a Frigidaire gallery
the dryer circuit will be clearly labelled in the house box, there will be two fuses or a single two phase breaker for this circuit.
there are not usually electrical fuses as such IN a dryer, there are thermostats to regulate temperature, and a thermal fuse, that cuts the power totally to the heat element if air temperature rises above its melt point.
the element itself has a limited life span and may fuse/burnout.
to test electrical components.
Unplug dryer
open case, by removing the front,
described elsewhere in any of the 'changing belt' threads
locate the thermal cutouts, on the fan housing or exhaust duct and disconnect one wire to isolate it from the rest of the circuit, test with ohmmmeter, no-continuity replace, continuity reconnect wire
3aca526.jpg5d18df6.jpg thermal cuttouts look like these ~1inch accross.
locate the heat element and disconnect one wire to isolate it from the rest of the circuit, test with ohmmmeter, no-continuity replace, continuity reconnect wire
while you have the dryer open de-lint the fan and exhaust ducting, most common cause of element or themal fuse failure is air flow restriction
7713ef8.jpgce0732c.jpg you get a lot of lint out of the fan even when proper cleaning is done, and clean out the ducting right to the exterior walls
95b69b0.jpgthis was the rather extreme result of not cleaning the duct (brainiac placed a wire across the terminals of the burnt out thermal fuse)
Posted on Oct 23, 2008
jmgldsmth
  • 1869 Answers
SOURCE: GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Posted on Jun 01, 2009
My whirlpool dryer model wed510vq0 has no power at all,i,ve reset breaker but it wasn't tripped what could be the problem?
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Feb 22, 2015 | Whirlpool Dryers
Hoover 5030d wont turn on after power surge. Is there a reset button on this dryer?
Hey GOD IS GOOD !!!!
Feb 21, 2015 | Hoover Dryers
Why does my dryer only work for 20-30 sec. and then turn off?
The high temp safety switch could be shorted.
Aug 24, 2014 | Maytag Dryers
Maytag dryer waont start when you push start button
Try opening and closing the door a few times it might be the door interlock switch, Are your plugs fused like in the UK. If so check fuse, or there will be a safety fuse inside the dryer which has blown in which case it will have to be examined by a qualified repairer.
Nov 13, 2011 | Maytag Performa PAV3200
Dryer has power but wont run when i push start button
Problem is either the door switch or the safety thermal, fuse,. Open door and manually push door switch lever to see if you hear a click when depressed. If you do then the problem is the safety fuse located on the blower housing. Small white plastic piece with 2 wires going to it. Hope this helps. Rick
Mar 09, 2010 | Whirlpool Dryers
When fan is turned on, all electrical power in house goes off (safety switch is tripped). This happens even when the fan light is off.The fan is an older model (i don't know what brand) that was in the...
It may be possible that fan wire is connected to another wire, so it is short circuited. Thats why safety switch is may be tripped... Check the connection of the wire.
Mar 05, 2010 | Heating & Cooling
Dryer won't turn on
touch the door swich and see if it clicks when you push in on it,if that is good you'll have to check thermal fuse that is located either on blower wheel housing or in back of dryer,check to see if belt broke some dryers have switch that kills dryer if belt breaks
Nov 03, 2009 | Kenmore 73932 Gas Dryer
Whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
Aug 27, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer qquite working.
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch will not activate and the dryer will not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
I would also check the thermal fuse as well. it is located on the vent duct or blower housing. If this fuse is damaged or tripped, it will not allow the dryer to run as well.
Jul 20, 2009 | Dryers
Hoover HDC7FM condensor dryer starts then cuts out
Open the dryer door (right after the breaker trips) and check for a burned smell. If it smells in the dryer, you probably have a direct short in the dryer wiring. Check for a burn smell at the wall socket. There may be a short in the socket itself, but not likely unless a mouse is lying across the contacts in the wall.
If everything checks ok replace the circuit breaker if this is an older home. Circuit breakers weaken after years of use. A 30 amp circuit breaker will trip at a much lower amperage after a period of years especially if it has tripped often.
Mar 12, 2009 | Hoover HDC7FM Dryer
Dryers Logo
95 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
