Question about Kenmore 30169 Electric Single Oven
Oven wont lite - Kenmore 30169 Electric Single Oven
Oven wont lite
if its a pilot lightr that stays lit all the time,then its the thermocouple next to the pilot light thats bad and cant keep the pilot on
Nov 24, 2012 | Ovens
MY SUBURBAN OVEN PILOT LITES, BUT WHEN i RELEASE KNOB PILOT GOES OUT AND OVEN WONT LITE. i REPLACED SAFETY VALVE BUT STILL SAME PROBLEM.
the polit light lights but when you let the nob go for the oven burner to come on the polit light goes out
Sep 22, 2011 | Ovens
I have a frigidaire oven and every thing works but the oven wont light,the glow plug come on but just wont lite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Feb 12, 2011 | Frigidaire FFEW2725LB Oven
Oven wont light this a gas range with electric lite
Hello and sorry to hear about your problem.
It sounds like your oven glow rod, is defective. This is the electronic pilot lite for the unit.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Tappan 30IN ELEC IGNa Oven
OVEN WONT LITE. THE GLOW COUPLER GLOWS AND THE BROILER LITES
sounds like this is gas unit . if so replace the bake ( bottom ignitor ) as it is weak . and this should correct problem .. mm hope this helped ..
Jul 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Takes a long time to lite
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has failed...
Yeah it sounds crazy, but read this..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 03, 2010 | Maytag CWG3600A Gas Single Oven
Oven wont lite or work
You say it will not lite ? I must think you have a gas range and you most likely have a bad ignitor. If the range is electric you may have a bad bake element. You can change this easily from inside the oven. Simply unplug the range, then inside you will see the bake element on the bottom of the oven. You will find two screws holding it in. Remove the two screws and gently pull the element out of the hole. I will have two wires attached. You can remove the wires by simply pulling them off, some will be screwed to the element. You can then check the element with a voltage meter for continuity. If you have none the element is bad. Hope this helps and feel free to call if you need further help.
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven wont lite. top pilots all ignite
oven ifnitor has failed / remove bottom of oven to replace. not a hard job.. ignitor cost 49 to 70.00 depending on model best to use a maytag flat style . this will cost you less.. mm hope this will help you mm
Dec 06, 2009 | Magic Chef 9112 Gas Double Oven
OVEN WONT WORK
Even though the igniter is red, if you are not getting gas it is almost 100% sure that the igniter is simply not getting hot enough. A new igniter should get that valve to open and you will be baking like crazy.
Nov 30, 2009 | Maytag CWG3100A Gas Single Oven
Magic chefa313-230lw gas ignitio
hi .thanks for the question . A very common problem with gas ovens replace the igniter thanks the appliance doc
Sep 29, 2008 | Magic Chef 9512 Electric Single Oven
Kenmore 30169 Electric Single Oven Logo
14 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
