Question about Vehicle Parts & Accessories
How Adjust tire pressure gauge?
As it says above, so my tire is giving more reading than a new one iam sure its wrong i checked with other gauges thanks
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
Sounds like it needs a new check valve if it's reading low.
Posted on Dec 01, 2013
Find a Toyota Vitz 2004 Manual?
Recommended tire pressure is on the tire itself. It may read max and adjust it down for a smoother ride.
Oct 12, 2014 | OEM Car Tyre Pressure Meter _ Professional...
My 2001 Ford Ranger Edge oil pressure gauge has been jumping around all over the place. Took it in today and they said pump needs replacing... and that they had to remove the engine to do so at the tune of...
Your oil pressure gauge works with the oil pressure sensor, which is screwed into the block, to transmit a reading. A faulty oil pressure sensor can cause the reading on the gauge to be erratic. You may have a bad oil pressure sensor. You should also inspect the wires going to the sender to make sure they are not loose, corroded, or shorted. If a new sending unit doesn't work, you can check the oil pressure with a manual pressure gauge. Testing for oil pressure involves fitting the oil pressure gauge with an adapter. Then you will need to determine if you have a gauge problem or an actual oil pressure problem.
Oct 22, 2013 | Ford Cars & Trucks
Not sure about tire pressure 40 pmi--what should read on topeak gauge pump
It's "PSI". Disregard the gauge as it is hardly a calibrated precision device. Ballpark is about as good as it gets.
Read this...
http://www.sheldonbrown.com/tires.html#pressure
Jul 09, 2011 | Huffy Cranbrook 24Inch Cruiser Bike
2006 chrysler 300 tire senor light, how do you reset?
If it is blinking, it means there is a failure somewhere with the tire pressure system. If it is on steady, it should go off when you inflate the tires to the specified pressure. Make sure you use a reliable pressure gauge, because these sensors can be a bit stubborn. Look in the lower inside of the driver door jamb or on the door itself for the correct pressure. If this does not work, you may have a faulty tire pressure sensor.
It's best to use an accurate gauge and inflate all the tires exactly to the pressure specified on the sticker in the driver door opening. Do this with the vehicle off, then wait a minute before turning the ignition on. This will give the system a chance to reset and update the sensor readings.
Hope this helps!
Sep 29, 2010 | 2006 Chrysler 300
"Check tire pressure" light still on.???
pls follow these instructions:
Instructions Things You'll Need:
  • Tire Gauges
  • Tread Depth Gauge
  1. Step 1 Let the tires cool before checking their pressure (tires are more inflated when warm, less when cold).
  2. Step 2check-add-air-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/01/q9/check-add-air-1.2-800X800.jpg'); }); Remove the cap from the valve on 1 tire.
  3. Step 3check-add-air-1.3-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/01/q9/check-add-air-1.3-800X800.jpg'); }); Press a tire gauge hard onto the valve and note the reading. The sound of escaping air means you haven't inserted the gauge properly: it's either pressed on askew or you're pressing too lightly.
  4. Step 4 Add air to achieve recommended pressure, which is listed on a sticker on the driver's side doorjamb and in the car's manual. If you overfill, you can release air by pushing on the tiny metal stem in the center of the valve with a fingernail or the tip of a pen or pencil. If you need to guess, 32 psi (pounds per square inch) is a good rule of thumb for most passenger cars with standard tires.
  5. Step 5check-add-air-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/01/q9/check-add-air-1.5-800X800.jpg'); }); Replace the valve cap.
  6. Step 6 Repeat with each tire, including the spare (the status of its pressure is often forgotten until it's needed, and then it's too late).
  7. Step 7 Check the tread depth. Recommended depth differs with types of tires. For a standard sedan tire, a penny pushed into the tread can give you a rough reading. If you can see any of Lincoln's head, it may be time to replace the tire. A $15 tread-depth gauge can give you a more accurate reading. There may also be wear indicators built into the tread; if they show, replace the tire.
  8. Step 8 Check for even wear (see "How to Interpret Your Car's Tire Wear.") If the treads on the outside or inside are particularly worn, you may need to rotate your tires or have your alignment checked.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Apr 07, 2010 | 2007 Nissan Altima 3.5 Sedan
S 60 low tire pressure
Yed the RFID sensors will send the proper signal to the computer and they will reset. Be sure your tire pressure gauge is accurate. Mine was out by 5 lbs and I struggled with that problem for a couple of days. went to a tire store and compared readings. threw gauge in garbage
Feb 01, 2010 | 2008 Volvo S60
How much air do i need in my tires
the tire industry recommends 32-34 PSI in all 4 tires
Nov 12, 2009 | 1995 Toyota Camry
I am not sure how to read the air gauge for my car
Look on the sidewall of your tire, it shows max pressure. Depends on type of tire and load. Do not go over max. Also take it to any service station,tire retailer or,walmart they will uselly check it for free.
Jul 22, 2009 | Computers & Internet
To erase tire pressure reading
Make sure you put air in tthe tires, then find the reset button in the fuse box inside the car if not you can unplug the battery then put the battery back on.
Mar 28, 2009 | 2000 Buick Park Avenue
Hobart LXiH preesure gauge is to low - 7 PSI
Todd - A pressure regulator will REDUCE pressure only. There is no back pressure - the machine's gauge is reading the incoming water pressure as it fills/rinses. Assuming the gauge is OK, the machine is only seeing 7 psi. There is an inline strainer in teh machine, check that for blockage. You said the machine was operating on 45 psi with a reading of only 12 psi. There may be some kind of pressure reducer - I have seen Hobart use special supply hoses with builtin orifices.
hope this helps, if not email me, i service commercial machines and came across your question as I was looking for help myself!
recordhound@yahoo.com
dishwasher in subject line
Oct 18, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
