Question about Universal Home
Need to remove a china cabinet drawer
I have a napkin stuck behind the drawer and I need to remove the drawer
Instead of trying to remove the drawer, try opening the drawer part way and use a vacuum cleaner hose (with the vacuum turned on) to snare the napkin and extract it. If you have one of those crevice tools (the long flat attachment) you can probably pull the napkin out without it getting sucked into the vacuum. I am assuming this is a cloth napkin?
Posted on May 30, 2014
What is the difference between a china cabinet and a hutch?
There are quite a few small differences between these two special pieces of furniture. Here are a few:
While both may feature glass doors, the doors on a hutch are usually quite smaller.
China cabinets do not have detachable pieces, whereas hutches typically consist of two separate pieces. The lower part of a hutch usually comes with a set of drawers used for cutlery or other objects.
Hutches are much less formal than china cabinets.
China cabinets do not have serving areas.
Sep 02, 2012 | Acme Furniture
I just bought a china cabinet and don't know how to display my china so that it looks good. Any ideas?
It's a good question - it's not as easy as it looks to make your stuff look good on a china cabinet. You need to plan what kind of look you are going for and what your main pieces are that you want to focus on. Here's a good article that helped me when I was putting my display together http://www.essortment.com/organize-china-cabinet-display-china-dishes-11723.html
Aug 13, 2012 | Furniture
Do china cabinets come with drawers?
most china cabinets are built with drawers underneath the shelving unit, so that you can keep some stuff without having to display it all (and dust it!). Here's a link to a website that shows their range of cabinets with drawers.
http://www.thefind.com/furniture/info-3-drawer-china-cabinet-hutch
One of the drawers on my china hutch is stuck, how can I fix this?
It could be that the paint on the drawer is too thick - youshould take a heat gun and scraper and remove any excess paint from the sitesof the drawer by heating the paint and scraping of the excess, try not to burnthe outside edge of the paint as you will still want it to look good.
May 29, 2012 | Furniture
I have a 4 draw Plano Tackle box as I have something stuck behind I can't close bottom draw,can you tell me how to remove draw as I've tried and cannot remove regards Sno
Use a long flat blade screw driver with a 1/4 inch blade. From either the right or left side, with the top drawer fully open, take the screw driver and place the blade between the inside of the outer casing and the drawer guide and gently pry the casing away from the drawer guide and pull the drawer open until you release the side catch on the drawer. You only need to free one side, and the drawer will sort of pivot out and the other side will be free at that point as well. Repeat for the rest of the drawers except for the bottom drawer which you will be able to access anything behind it as the upper drawers will not longer be blocking access when removed. I had a small bag of sinkers sitting on the bottom.
Feb 16, 2011 | Plano Four Drawer 757 Guide Series Tackle...
How do I replace the control panel? Where is the
You need to remove the top panel before you can remove and replace the control panel. Remove the screws holding the top panel to the back of the machine and slide the panel backward.
Disconnect the user interface wiring harness from the Central Control Unit (CCU). Pull the dispenser drawer out and press down the release tab at the back of the drawer to completely pull it out.
Remove the screw that was covered by the dispenser drawer in the recessed hole next to the drawer opening.
Open the door and insert a flat-bladed screwdriver into the notch at the bottom center of the control panel to release it.
Press and release the tab behind the right hand side of the control panel securing it to the cabinet.
Gently pry up and release the top of the control panel and pull it off the cabinet.
Install the new control panel in reverse of the steps above.
Feb 23, 2010 | Kenmore HE2 Plus Front Load Washer
The top drawer of my Fisher Paykel two drawer dishwasher will not close all the way. Something appears to be stopping it. How do I fix it?
To find out what might be blocking it, you can remove the drawer. There are two tabs one on each side of the drawer near the bottom front. Push those in and pull the drawer out. You can lift the drawer up and push the slides in to get them out of the way. Then you should be able to see into the cabinet and what if anything is stuck behind the drawer
Apr 22, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Fisher&Paykel DW lower drawer leaks.
hello have you levelled the front and back feet you need to remove the bottom drawer again for this? Is the metal arm that holds the wires behind the drawer still conected to the white plastic wire clamp half way down the loom? check the lid seal has no dents or rips in the rubber seal. cheers get back to me if you still have no luck.
Mar 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Paper drawer is stuck open?
there is a piece of paper stuck behind the paper drawer, remove the drawer and then look inside, also open side panel and you may be able to see part of the paper there also .
http://www.websitetoolbox.com/mb/copierquestions
Jan 27, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Copier jamming
One of your feed tires or rollers may have come off or be worn out. You may also have paper stuck behind one of the drawers, does it do this out of all the drawers?
Oct 23, 2008 | Canon imageRUNNER 210S Copier
Home Logo
638 people viewed this question
Top Universal Home Experts
Donni Steen
Tom Chichester
Are you an Universal Home Expert? Answer questions, earn points and help others
