Question about Garden
I am having trouble figuring out how to mount the deck belt on this lawn mower it is an old one closest year i could find was an 1985 hoping someone could find a diagram or if someone has one maybe take a pic so i could copy. thank you, Ben
  • kokomo132 May 10, 2009
    I am sorry i thought i added the make and model but i was wrong. there is nothing on the deck there was a sticker under the hood that said it was an deutz-allis and all it said for a model number is 611 special
  • rjbeg123 May 11, 2010
    Ben we're going to need a make/model or manufacture to try and help you. Years are usually on a metal plate on the deck or engine as well as model info.
    President:
  • 272 Answers
I'm not familiar with that model, but there is a guy on eBay selling the manual for it. Here's the link. Might be worth having if your going to get it going again. Best of luck!
http://cgi.ebay.com.my/Deutz-Allis-611-616-Lawn-Tractor-Operators-Manual_W0QQcmdZViewItemQQitemZ400019882929
Posted on May 10, 2009
  • 86 Answers
Can you send me a picture of your mower and also a picture of the deck ?
Posted on May 09, 2009
I need to see a diagram on how to put a deck belt on a 1515 cub cadet lawn tractor
This YOU TUBE link will hopefully help you. www.youtube.com/watch?v=iwjI4i-dLFk
Apr 18, 2014 | Garden
Yardman 38" 7160 the deck belt is loose
Have you been mowing high grass, and how long has the belt been on? if you have mowed tall grass or belt is older than 2 years old it needs replaced, most don't realize how much a belt stretches from mowing tall grass. I hope this has been helpful.
Sep 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Blades turn slower when deck is lowered on cub cadet 1042
Had the same problem after winter storage and couldn't find an answer anywhere. I noticed that the drive belt (not the ribbed deck belt) was loose when the deck was down below 4 and tight when it was up higher.
That told me either belt is stretched beyond the belt tensioner's or the tensioner wasn't working right. Found that the tensioner was hard to move and would stick. Greased the zerk on top of the large bolt, worked it back and forth a number of times by pulling on the belt. Problem fixed. But I'm thinking it may be time to order a new tensioner spring and belt anyway. Hope this helps someone down the road. If so pass it on. :) jerseyjimmers@yahoo.com
Jun 16, 2012 | Garden
Replace blde belt on Model # 917.256562 Lawn Tractor, someone please, please tell me how to do it. I was told u could , and not drop deck.
I totally disabled for 6 years. Remove the deck is the only way. It takes me a week or two but finally take it.
Dec 09, 2011 | Garden
Mountfeild self propelled mower works nearly perfect pull the leever for the mower to move on its own nothing there cheked the slack on cable not the problem now it only works by pushing the mower any...
There is usually a belt that runs from the blade shaft to a small gear box. Front drive mowers have this belt mounted atop the deck, and rear drive mowers under the deck. The problem is usually a broken or worn out belt if all the linkage is working properly. Sometimes however, the gear box goes bad, or the parts in the wheels fail... (depending on the drive style) Check that belt! Good luck, and don't worry. Lawn mowers are pretty simple to figure out!
Oct 01, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Replacing belt on lt1000 lawn tractor looking to fing where to hook spring to engage belt it popped off and cannot figure where wher to reattch it . is there a diagram on the layout Thank...
I do not have a diagram,but I do know where it goes.Look at the tension pulley.The arm it is mounted on move.That arm is where the spring belongs.First move the arm with your hand.pull it so that the blades are not engaged.Now the side of the arm away from the pulley and closest to the rear of the mower,is where the spring goes.There may be several holes,do not pull the spring too much,just get it in one of those holes.Then try the blades.If they do not engage,move the spring,to another hole.
May 20, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I'm having trouble replaceing the motion drive belt on my LT1000 lawn tractor. The mowing deck is off, the old drive belt is off. I can't get the belt around the transaxle pully. Any suggestions?
Often there is a keeper on the back of the pulley, and the belt must go inside the keeper. Get an inspection mirror up in there to look if necessary. Start by putting the belt on the transaxle pulley, then on the PTO pulley, then on the idler, last have someone sit on the mower and depress the clutch pedal while you put the belt over that pulley.
Sep 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Can someone please help lookingh for belt routing for the mower deck for a ariens riding mover yt12g model and the belt to the mower deck how it routes on tension pulley thankyou john
Hey John..my name is Keith..and you can go to an online lawn mower parts site..and they will have a pic of the deck and they way the belt is routed...one of the sites is www.outdoordistributers.com ...i hope this will help
Jul 08, 2009 | Garden
Need a belt. 12 hp 40 in. deck lawn tractor. Murray. Model: 40710a Date: 1404 What size do I need? Mower man in town can't seem to figure it out
Hey...my name is Keith...im not sure which belt you are asking for...but the drive belt is a 37X61 and the deck belt is a 37X62..i hope this helps
Jul 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub cadet model LT1045 belt coming off the pulley for cutting deck?
FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING!
I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing.
Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw.
It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!!
- Mike
If you for some reason you cant
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
268 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
