Question about Sony SUWL500 Wall Mounting Bracket
I have a TECHNIKA LCD42-207 that I am trying to wall mount with a tilt and swing bracket. I have tried several brackets, but have had to return them as none of the fittings will secure to the rear of the TV
2 Suggested Answers
The Joat
  • 81 Answers
SOURCE: can I wall mount my proview tv? do I need to buy
You can wall mount your Proview TV with any standard VESA mounting system that is certified for up to the size of you tv.
Posted on Feb 03, 2011
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
My screen broke moving on my sony flat screen. Tv
I would try contacting<a href="http://www.tvvideorepairil.com">flat screen tv repair in Chicago, IL</a> because that's where I went when mine broke.
Oct 03, 2013 | Universal 40-42 Inch Flat Screen Panel...
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
Hi we have samsung lcd 22 inchess.. we need to fix it to wall and there is no backside stand .. how can we get the stand
Most electronic stores sell wall mounting brackets. There are several types. one mounts the LCD screen flat to the wall with a limited range of tilt. Another type mount the LCD screen on an arm that allows tilt and swing movements.
Jul 22, 2010 | Samsung YP-K3 MP3 Player
I have a 32'' Technika tv and have recently bought a tilting wall bracket do u have to put screws in the back of the tv????
There should be screw holes in the back of your TV.You might want to make sure your bracket screw holes line up with them.
Feb 27, 2010 | Televison & Video
Best wall mount for sylvania 6842thg plasma
To make it simple: Mounts go by the size of the TV.
You have the choice to get a standard mount that can only swing or a mount that can swing and tilt or even extend. Plasma TVs are a bit heavier, than LCDs therefore, you need a solid mount. There are wall mounts and ceiling mounts. Mounts can be purchased from Home Depot, Lowe's and best buy, they can also be bought on line. If you buy it from a local store and does not fit, you can take it back the next day, an option you wont have if you buy online.
Good luck
N Sabre
Nov 08, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
What bolts sizes are needed to wall mount a technika lcd32-209 television?
consult your wall mounting bracket instructions that come with wall mounting kit
if there not included it should have recomendation as what to use
Nov 02, 2009 | Televison & Video
How do I remove a plasma panasonic mounted on a wall.
if it is a swing bracket 4 screws on back bracket holding it in need to be removed, if it is flat wall bracket lift strait up the wall to remove.
hope this helps
daniel
Jan 11, 2009 | Panasonic TH-50PX75U Plasma HDTV
Attaching 26 " lcd to stud wall
12 inches is the minimum for mounting the unit to the wall. I mounted a 42 inch LCD using a Sanus tilt (non-swivel) mount from Best Buy. We mounted it on wooden beams exactly 12 inches apart. Works great!
Mar 05, 2008 | Televison & Video
Sony SUWL500 Wall Mounting Bracket Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
