Will a projector focus better on a screen - Office Equipment & Supplies
  • kenneth wayne howell
    kenneth wayne howell Nov 29, 2013
    Hi Julius pantojas, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    no power , no lights don,t no where to start
No put on a white sheet rock wall
Posted on Nov 29, 2013
    no put on a white sheet rock wall
How can I focus it other than using the focus knob
The focus knob is the way you focus overhead projectors. Perhaps you simply haven't turned the knob far enough? How far is the projector from the screen? If it's quite close, you need to turn the knob to raise the lens. If far away, turn it to lower the lens.
Nov 25, 2015 | 3M 9200 Overhead Projector
Out of focus
the glasses in the Lens are failing.the glasses were burned
you need the new Lens, USD80
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Mar 23, 2014 | BenQ MX615 DLP Projector 3D Ready...
Eiki projector focus problem
is the lens wheeling(moving) when you press the "up" or "down" after the word "focus" appears on the screen.
1,the lens does not wheel(move),---the motor of the lens is failing
have a nice day!
Jerry Lampdeng Limited
Apr 09, 2013 | Eiki LC XNB4 LCD Projector
White spots on screen i have changed the lamp
It's probably you have a busted DMD chip, have your technician replace that, better yet buy a new projector because replacing that chip costs almost a brand new unit.
Nov 19, 2011 | BenQ Office Equipment & Supplies
Cannot focus uniformly across the projected screen. This seems to be more than a focus problem in that some areas of the image seem blurry as opposed to out-of-focus. Also, in what may be a related...
try bringing the screen up as close as possible to the projector and still get a focused picture. check keystone here and also for image clarity. if you still have problems, check for dust or moisture etc in the optics. check the lamp for a clean front surface. clean the air filter also. Try a different image source for differences
May 20, 2011 | Eiki LC-XB25 Projector Multimedia...
I have a panisonic pt-lb50ntu Projector. It will only focus the center of the image. When you adjust the focus to the bottom of the image the top and center are out of fucus. The same goes for focusing on...
Is the picture a perfect rectangle shape on the screen. If not then either adjust the angle of the screen, or use the keystone function on the menu to correct it.
Does it still not focus correctly after doing this
Nov 12, 2010 | Panasonic PT-LB50U Multimedia Projector
I have a Panasonic PT-AX200 LCD Projector. It is mounted on the ceiling. I need to know how to focus the screen without climbing up to the machine itself to do it. Is there a way to find the focu using the...
I'm afraid, no remote option available to focus image of this projector and has to do manually. Check projector Menu and select Test Pattern for optimum focus and it would be one time job if projector and screen distance has not been changed.
I'm not sure about the advice regarding "color management" as it has nothing to do with focus.
User manual link is also broken and take you no where.
Aug 11, 2010 | Panasonic PT-AX200 LCD Projector
The image projected is simply not very clear. I
It is 1100 lumen or ANSI projector.Less the projection distance you get better result
Feb 13, 2010 | Sharp XR-1S Multimedia Projector
Focusing
Hi real12
Unfortunately you will have get the focus ring replaced before you will be to make use of it if your model doesn't have automatic zoom and focus in the user menu.
Sorry , but there simply is no other way.
May 21, 2008 | Toshiba TDP-S9 DLP PROJECTOR *2% DISCOUNT...
20 people viewed this question
jasbo
jasbo
