Question about Exercise & Fitness
No display for left side intensity
The intensity display for the left side has disappeared. Intensity can still be increased as the value is shown on the rig ht side of the screen with the left arrow. Can only increase the intensity one side at a time
    Top Expert:
  • 12,223 Answers
If your system has batttery , replace by new ones. However you must clean the contacts batteries, with alcohol isopropyl 100% from dirty, oxide, corrosion, and try again. Test your adapter for the output voltage use the multimeter and compare the output with the label printer in the adapter. You can download the owner manual from www. fitness.manualsonline.com and go to the section troubleshooting.
God bless you
Posted on Nov 29, 2013
How do I get my sylvania 10 in. Photo frame video intensity increased
Image Settings; Calendar Settings - Sylvania SDPF751B ...
www.manualslib.com > ... > SDPF751B > User manual
Sylvania digital photo frame user manual. Hide thumbs. 1 · 2 · 3 · 4 · 5 · 6 · 7 · 8 · 9 ·10 ... You can decrease/increase the value by pressing. Time: Press to set Date, time. ... Digital Photo Frame Sylvania SDPF733 User Manual. Sylvania digital ...
Electronics - Sylvania
Dec 10, 2015 | Sylvania Cameras
Investigation based on the effect of light intensity on the rate of photosynthesis.state the hypothesis and variables
Well, your variables are in the statement of the topic. Light intensity and rate of photosynthesis. the independent variable could be the light intensity.
No light ( Intensity =0), no photosynthesis (rate=0). Increase the light intensity, the rate of photosynthesis should go up.
Hypothesis: As light intensity increases, the rate should (? ) go up.
Nov 07, 2013 | Chevrolet Bolt. Air distributor. Driver...
Can i increase intensity of dash lights on citroen xsara picasso
There is a dimmer control for dash lights, check the owners manual for location and operation instructions.
Jul 11, 2012 | Cars & Trucks
How can I turn down the power on the FL50 to get more flashes. Can you turn down the power on the camera E510 with hte FL50 attatched?
the user manual is here http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/accessories/man_fl50_e.pdf
Have a look at page 46 TTL Auto mode - you can adjust the variable between power setting - + or - 3 stops Page 48 gives full details on adjusting this setting
Light intensity adjustment
  • The flash light intensity can be adjusted between +3 and –3.
  • The light intensity adjustment must be set to ON in the custom setup operation (page 61). • The indicator appears in the control panel.
  1. Turn dial B to select a light intensity adjustment value in the following steps. (This selection is also possible with dial A.)
  • 0 → +0.3 → +0.7→ +1.0 ... +3.0
  • 0 → –0.3 → –0.7→ –1.0 ... –3.0
  1. The display shows the light intensity adjustment value except when the value is 0, in which case the display does not show the light control range.
  2. If the camera’s flash adjustment mode is selected, the actual flash light intensity will be the total of the light intensity adjustment value set on the FL-50 and that set on the camera. The light intensity adjustment value displayed is that of the FL-50 only.
Apr 11, 2010 | Olympus FL-50 TTL Flash
Having problem copying from ADF
On this model, the Intensity needs to be set to 'Manual' to make copies from the ADF.
1. Press the 'Settings' button repeatedly until 'Intensity' is displayed
2. Press the left or right arrow until 'Manual Adjust' is displayed, then press the 'OK' button
3. Press the left button to decrease the intensity, or the right button to increase the intensity, then press the 'OK' button
4. Press the 'Back' button repeatedly to return to the Copy standby mode
To return to 'Auto Adjust', follow the above instructions selecting 'Auto Adjust' at step 2, and skipping step 3
Aug 28, 2009 | Canon PIXMA MX310 All-In-One Printer
Brake light problem Corolla 97
the tail light and brake lights are working from double contact bulbs. check the grounding, you dont have enough ground from one of the bulbs
May 30, 2009 | 1997 Toyota Corolla
My hair straightener stops working when i increase the level of intensity to dry hair, what can be the problem?
Sounds like a short in the unit. It can be taken apart and make certain all of the wires are tight. Not sure what what you mean by increase intensity but if it means you oull harder it may just be too much for the unit. Try not putting so much pressure on it. Good luck.
Aug 14, 2008 | Conair Professional Ceramic Hair...
Scanning on an mp500
First you should have installed the scanner in the computer using the cd comes with the scanner.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Load paper in the auto sheet feeder or the cassette in the portrait orientation.
  3. Lift the document cover and set a document on the platen glass.
    MEMO:
    - Regardless of the document size, set it in the landscape orientation.
    - Place the copying face down on the platen glass.
    - Align the document with the alignment mark (shown as the arrow) on the lower right corner of the platen glass.
    Note: The machine cannot scan the area approximately 3 mm from the front and right edges of the platen glass.
    < 1 > Alignment Mark
  4. Close the document cover gently.
  5. Confirm that the printer is in Copy mode. If the printer is not in Copy mode, press the <COPY> button to switch into Copy mode.
  6. Check the copy settings, following the procedures below carefully.
    < 1 > Check the paper size and media type.
    < 2 > Use the up / down cursor button to specify the number of copies.
    < 3 > Use the right / left cursor button to adjust the intensity.
    Memo: Pressing the right cursor button increases the intensity. Pressing the left cursor button decreases the intensity.
  7. Press the <Color> button for color copying, or the <Black> button for black & white copying. (The printer starts copying.)
    Note: To cancel copying, press the <Stop/Reset> button.
Apr 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
Exercise & Fitness Logo
418 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
