Question about KitchenAid Ovens
Lost communication error F6E4
Error F6E4
Model akz669/ix/04. What does error F01 indicate?
Communication error oven control board
Jan 05, 2016 | Whirlpool Ovens
Fix f5 e 1
F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
F9 still appears after unplunging and replug
Hi Don, this is Z. Thank you for your post!
If you are receiving error code F9, it typically indicates that the maximum oven door unlock time has exceeded. If resetting the power did not clear the error code, it would be advisable to contact an experienced appliance repair tech to assist further since your range may possibly have a communication error with the EOC (Electronic Oven Control), lock motor assembly, door light switch or door latch assembly. Hope this helps!
Jul 19, 2014 | Frigidaire Ovens
F6 E6 error code?
This fault is a communication error at the appliance manager, could be a loose wire or a bad display transformer, either way you will need a certified technician to fix this issue, there is no simple plug and go issue to resolve. I personally found the problem to be the transformer not send voltage to the appliance manager. This is solvable but needs someone who understand electronics to correct this issue.
F6 E0 Oven user interface - lost communication E6 Oven appliance manager 1 (upper, single) - lost communication
This is directly from the tech sheet of your oven and directly from the factory web site.
Good Luck
Dec 03, 2013 | KitchenAid KEBS179B 27" Built-in Electric...
EW30IS6CJS model f11 error code. What does it mean ? Brand new appliance, has had it only for a month!
Hi Julie! Thanks for posting your concerns online. I would strongly recommend contacting Electrolux directly if you have not done so already. The unit is well within the warranty period and should really be diagnosed by a professional. The code you are experiencing typically indicates a control communication error. This can be between the unit's control board (brain) and the rest of the unit or the wiring harness itself that relays these communications.
Sep 03, 2013 | Electrolux ICON Designer E30SO75ESS Oven
Error code -fc- beeping will not stop?
From JENN AIR FAULT CODES...
FC - Communication error between boards - Wiring harness or power relay board (PRB)
Hope helps.
Mar 24, 2011 | Jenn-Air Electric Double Oven
I have a kitchen add KGSS907 it is showing an error message F6E0 lost communications how do I correct this
F6 E0 means the switch pulse return line to the electronic control is not connected
The usual way to correct this is to replace the electronic control (clock).
You might want to check for loose or burnt out wires on the clock unit before replacing tho'.
Dec 17, 2010 | KitchenAid Architect Series KEBC107KSS...
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
E005 Communication error
Got this error this morning and it cleared when I turned off the circuit breaker and turned it back on.
Oven is now working
Mar 12, 2009 | Thermador M271ES Electric Single Oven
F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
Oct 27, 2008 | KitchenAid Architect Series KEBC107KSS...
Ovens Logo
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
