Question about Exercise & Fitness
Check speed system - Exercise & Fitness
  • dwi fitriani
    dwi fitriani Nov 28, 2013
    Hi dwi fitriani, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • dwi fitriani
    my treadmills 9865 don,t starting because in monitor have latter check speed system i don.t understand plese help me
    Top Expert:
  • 12,223 Answers
Please RUN the software calibration, go under the HOOD of the motor and read the steps, or go to the owner manual, for easy diagnostic and fix it. God bless you . see the diagram attached. tight the connector very well, and clean the s. sensor, with alcohol isopropyl 100%
God bless you
Posted on Nov 29, 2013
How to fix cruise control on a 2006 ford freestar, does not work at all, wont turn on
Note the diagram, at least check the fuse. Check trouble codes, related to cruise control. to check codes yourself, at least, you need an obd2 code reader that will read po codes as well as manufacturer specific codes. It is worth the investment, in my opinion. Make sure the brake lites work.
Mar 05, 2017 | Ford Cars & Trucks
Power supply ok but it's error coming check speed system
Dear Sir:
Please run the software calibration for easy diagnose and troubleshooting and fixing. Clean very well the speed sensor, and tight the connector.
sincerely. God bless you
Apr 16, 2012 | Startrac Fitness Products Star Trac Pro S...
Hey, I have an ECS GF8200a with ddr2 1066mhz 2gx2 ram from team Xtreem. Ram will only run at 800mhz, ? everything seems up to date like drivers etc.
The speed of system RAM is dependent upon the RAM itself for the most part. Check the label on the RAM sticks as this will indicate the speed of the sticks. Also, the system will only ever run system RAM at the speed of the slowest stick. So if you have two sticks, one rated at 800Mhz and one at 666Mhz, then the system RAM speed will be at the lower 666Mhz speed for both sticks. I would guess that the sticks you have installed will not run at the highest bus speed of 1066Mhz. The RAM controller may also be detecting that running the RAM at the higher speed may or will cause system instability and is reducing the speed to maintain a stable system.
May 21, 2010 | EliteGroup ECS Socket AM2+/ GeForce 8200/...
Where's the cruise control fuse located on a 2002 Ford Excursion V10 (Gas)? Stopped working,
Check the Central Junction Box and this diagrams; also can check this in your 2002-Ford-Excursion owners manual.
Fig. Vehicle Speed Control, Page 01 (2002, System overview, Gasoline engines)
Fig. Vehicle Speed Control, Page 02 (2002, System overview, Diesel only)
Fig. Vehicle Speed Control, Page 03 (2002, Gasoline engines)
Fig. Vehicle Speed Control, Page 04 (2002, Gasoline engines)
Fig. Vehicle Speed Control, Page 05 (2002, Diesel only)
Good luck.
Mar 10, 2010 | Ford Excursion Cars & Trucks
I need to recall the system speed dial directory on my NEC Electra telephone system. I am unable to find a memory re-call/display feature in my manual.
With this old model of phone you don't have the soft keys to scroll through the directory like the newer models have.
In order to check the system speed dials you will need to check them manually:
System Speed Dial #'s
LNR/SPD key and the system speed # 00~79
Station Speed Dial #'s
LNR/SPD key and the system speed # 80~99
This will dial the # and/or display the name associated with the speed dial.
In order to program them refer to this manual:
Elite IPK Features and Specs
Look under Speed dial-Station or System.
Nov 11, 2009 | NEC Electra Professional ETW-16DC-2
Having the same problem the other guy described.
First of all, these codes are what are called "Powertrain Trouble Codes' (that's what the "P" means P=Powertrain). TCM Request (Transmission Control Module = TCM). The request was to turn on the 'Check Engine" light.
P0720 - output speed sensor circuit malfunction
P0715 - Input speed sensor (turbin speed) circuit malfunction
P0442 - Evaporative Emission System Leak (Small Leak)
P0455 - Evaporative Emission System Leak (Large Leak)
Check fuel filler cap problems - for Evap Emiss leaks
Replace the pulse generators & have the trans fluid replaced/flushed.
The Main Catalyst System Efficiency Bank 1 Is P0420, not P0442
If you had P0420 code, the catalytic converter is shot... and that's an expensive component.
Oct 06, 2009 | 2001 Hyundai Elantra
My computer is very sloly
check ur ram, increase ram to get a fairly good speed. remove unnecessay programs and files from ur system. check which antivirus u are using, Some anti virus result in decreasing the system speed. Unable the antivirus and check the speed. If nothing helps, format and reinstall ur operating system. Install only necessay files.
Aug 23, 2009 | Microsoft Windows 98 for PC
Speed so slow internet of no use to me!
by doing two simple steps u can improve your speed
1)delete all temp files in yor system
2)give clear cache every day..at any time u wana test your interenet speed reach here http://www.ip-details.com/internet-speed-test/
Jan 27, 2009 | Computers & Internet
Processor slowing down?
On the system properties you will able to check your processor speed and your memory, it is possible that the other description is referring to your memory or Ram.
You can use other program like aida32 to check your computer spec or you can try the steps below.
To check the CPU speed, from the Start menu, select Run... , then enter msinfo32 .
You can also type DXDIAG then enter.
http://support.microsoft.com/kb/312104
Mar 07, 2008 | Computers & Internet
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
