Question about Mercedes-Benz Vehicle Parts & Accessories
Benz C180 twin cam timing marks how to set - Mercedes-Benz Vehicle Parts & Accessories
    New Friend:
  • 60 Answers
I would just buy a MB service manual that will have all your cars specs, Chilton, Haynes manuals are very useful and cost about $20 USD
Posted on Jan 01, 2014
2 Suggested Answers
caterpillerc
  • 45 Answers
SOURCE: how do i set valve timing on a benz C180 kompressor with twin cam and a chain
how many cylinders do you have because other wise i can not help you and may i please have the firig order
Posted on Nov 28, 2013
How to install timing chain with timing marks both crankshaft and camshaft
Hellen, For the second time, Re POST year, make, model, engine size and complete question so we, here at fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Still pulling hair Twin Cam timing marks How accurate Engine Exhaust...
16v fast tbelt swap
Twin cam 16 valve timing marks Google Search
Aug 11, 2016 | Cars & Trucks
Mercedes benz timing
Timing marks for any vehile,even a Mercedes,are on the harmonic balancer.The pullys that drive the belts is bolted to the crankshaft and that knotch needs to be marked with a white paint pen.Line it up with the timing tab on the block right there at the harmonic balancer.
May 10, 2014 | 2002 Mercedes-Benz C180
Mercedes benz c180 timing marks
TRY GOING TO THE SERVICE AND REPAIR DEALER AND ASK IF YOU COULD GET A COPY OF THE C180 TIMING MARKS DOESNT HURT THE EFFORT
How do i set valve timing on a benz C180 kompressor with twin cam and a chain
Nov 28, 2013 | Mercedes-Benz Vehicle Parts & Accessories
Replacing timing belt; need timing belt markings for 2000 mazda protege
If it has the twin camshafts, then you need to align the bottom crankshaft pulley marking (there's only one marking at top dead centre). Then you'll need to align the two camshaft pulleys. You need to use the first two sets of markings and then double check the markings on the camshafts themselves, within the valve cover area. Always double check the crank shaft sensor is aligned properly on re-assembly as misalignment will result in a non-start and you might doubt your own work. Don't worry about timing belt failure or misalignment on the twin cam engine as this is a "safe-engine" and will not result in any damage.
Oct 30, 2012 | 1998 Mercedes-Benz CLK
How to set timing marks for briggs 310000
there re marks on the cam and rod gears line them all up if overhead cam there is marks on the cam that need to line up flush with the head
Sep 13, 2012 | Briggs & Stratton Briggs Stratton Intek V...
2000 roadking efi we are changing over to gear driven cams we have the work done now we cannot seem to get the timing to go right we have the marks all line up but i guess we are not finding the true...
You have two "timings" to set on your Twin cam. The cams must be correctly timed to each other and then the combination must be timed to the pinion gear that drives the cams.
Now, Twin Cam engines are NOT my expertise but in all other Harley engines, the timing mark that you time the cam with has nothing to do with top dead center position of the crankshaft. There is a specific mark on the pinion gear that the cam has to be timed to or the timing will be incorrect. Knowing the way Harley does things, the same is true with the TC engine.
Good Luck
Steve
Oct 02, 2010 | Harley Davidson FLHR-FLHRI Road king...
Wanting to know how to set the timing and the
set the cam marks lined up with the cylinder head along with the marks on te magnito lined up with the case mark
Jul 23, 2009 | 1976 Yamaha XS 500
I AM REPLACING THE TIMING BELT ON MY 1999 DAEWOO WITH 1.5 LITRE ENGINE AND NEED TO KNOW THE TIMING SPECS SO I CAN SET THE TIMING ON THE CRANKSHAFT....ALSO I NEED TO KNOW THE T.D.C. ON THE #1 CYLINDER FOR...
single cam
cam at 12 o clock
crank at 6 o clock
marks in rear timming cover
twin cam
cams marks face each other 3 & 9 o clock
crank at about 6 o clock mark in cover
all marks are visible on gears and covers
May 15, 2009 | 1999 Daewoo Leganza
Vehicle Parts & Accessories Logo
62 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
