Question about Canon Video Cameras
After loading cassette amessage comne up please remove cassette
  • williamsarno May 09, 2009
    i have a canon xl2 ,this problem happen even when i load the cleaning cassette or a newcassette
    Sergeant:
    Champion:
  • 219 Answers
Hi, Does this happens only to tapes which have been "used" (record or play) on the same camcorder ?
It looks like the camcorder is detecting "loose tape", i.e. the take up spool is not winding the tape "tight" enough. Try a cleaning cassette, or a trip to the repair shop for changing of belts and rollers.
Thanks! Sandy
Posted on May 09, 2009
  • Sandeep Gupta May 09, 2009
    well one more thing when you get a remove cassette message 9 times out of 10 it is 2 gears on the m-chassis that have failed they spit oil all over the inside and then the gear comes in contact with the m-chassis and binds up they are both white and in the middle you can see one when you open it and the other is on the inside that you cant see unless you take take the cover off and thats why you get that message but the ribbon part is something else that needs to be looked at you should send it in to a qualified canon repair facility. tell them the chassis is defective
    Thanks!
    well then in that caseu need to go to the repair shop for changing of belts and rollers.If its under warranty, it will cost u nothing.
    Thanks!
    Sandy
Mvx200i didn't load cassette
Are you putting the cassette in the correct way round ?
Jun 17, 2017 | Canon MVX200i Mini DV Digital Camcorder
When i write amessage i can'tsend it
please check the service centre number in text message settings
Dec 11, 2011 | Nokia Classic 2700 Cell Phone
Please describe your cannon laserbase 5630 showing paper check error after printing one print problem:
Hi mani4u58,
After the print,does the alarm indicator show?
Are the papers loaded and aligned in the correct way in the printers cassette?Please align them well and also note that the cassette can hold only around 250 sheets at a go.Remove the cassette completely when loading the papers and after paper load,insert the cassette as far as it can go.Does the printer feed paper correctly?If not,there may be a paper jam.To clear the jam,open the front cover by pulling it towards you.Remove the cartridge and inspect the compartment.Also make sure the orange adhesive tape around the cartridge is full removed to free its connections.You can also unplug the printer and leave it for a while and then plug it back to clear jam.
Hope it helps.Thanks!
Mar 27, 2011 | Office Equipment & Supplies
I am getting a supply Rec Paper Cassette alarm error. How do i fix this and have it work again.
Hi ..
This error comes when the paper is not loaded properly in the cassette ... Follow the below instructions to load the cassette and I am sure you will not get the error again.
  1. Grip the cassette handle, and pull it out towards you until the cassette comes to a stop.
  2. Open a package of paper, and remove the paper stack. small_note.gif black_dot.gif If the paper is curled, uncurl it before placing it in the cassette. Failure to do so will cause paper creases and a paper jam. black_dot.gif 17 lb to 20 lb bond (64 to 80 g/m2 ) paper is acceptable. black_dot.gif The cassette holds up to approximately 500 sheets of 20 lb bond (80 g/m2 ) paper.
  3. Load the paper stack beneath the cassette's length guide (1) and width guide's claw (2).
    load_paper_in_cassette.gif small_note.gif black_dot.gif Make sure that the paper stack does not exceed the length and width guides' claws in the cassette. Failure to do so will cause a paper jam. black_dot.gif Do not load extra paper when there is still paper left in the cassette. black_dot.gif Only load one size of paper into the cassette. Do not load different sizes of paper into the cassette at the same time. black_dot.gif Do not load labels or transparencies into the cassette.
  4. Gently insert the cassette as far as it will go.
small_note.gif black_dot.gif The cassette is for plain paper, colored paper or recycled paper only. Loading other paper in the cassette may cause a paper jam. black_dot.gif If copies are curled, or a paper jam occurs, remove the paper stack from the cassette. Turn it over and then place it in the cassette. black_dot.gif If you load paper while making copies, do not load a different paper size.
Closing the cassette When closing the cassette, make sure to push it in completely as far as it will go. If copying is performed when the cassette is not pushed in completely, it will cause a paper jam.
If copy paper is sticking out of the cassette Sometimes, when you pull out the cassette, paper may stick out, as shown in the illustration below. Make sure that the paper is neatly loaded into the cassette, before you push the cassette back into the main unit.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon imageCLASS D860 All-In-One Laser...
Loading video cassette fails
without cassette open and close are normal and you heard a loud beef and the motor abnormal speed?Solution---Replace the capstan motor.
Hoshi
Jun 26, 2009 | Canon MV850i Mini DV Digital Camcorder
Jvc camcorder
E01 means Mechanism has not fully loaded up to the stop position
E06 meansTape drive motor is not rotating or stalled.
Thses two faults indicate a tape jam. please remove the cassette and insert a new cassette.
Nov 02, 2008 | JVC GR-AXM17U Camcorder
Loading a cassette
having the same problem...when I put a new tape in it just ejects it right away!
Apr 17, 2008 | Canon ZR200 Mini DV Digital Camcorder
Problem with loading cassette
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 13, 2007 | Canon Optura 200MC Mini DV Digital...
Can not load any cassette even empty cassette holder can not be closed.
I had the same problem and solved it by removing the battery to allow the camera to reset. Worked fine after that.
Sep 24, 2006 | Sony Handycam CCD-TRV11 8mm Analog...
Video Cameras Logo
60 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Chris Phillips
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
