Question about Westinghouse Irons
No steam coming out
As I pour water into the box for the water, no steam comes out and the unit is hot.
    Top Expert:
  • Westinghouse Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Posted on Nov 29, 2013
DiYerTech
  • 70 Answers
SOURCE: Not steaming
Hi, it sounds like the steam trigger has a broken pin on the end inside the handle. Unplug the unit from the wall and let it cool. I found out that you can remove the main rubber cover by gently prying it up from the front and pivoting it up to the cord end and lifting it off. You will see the trigger snaps in, but look at the finger end going under the microswitch that activates the "Burst of Steam"...it is probably broken. You can get another one from California Electric Service in Concord CA; or you can epoxy a small 3/4" by 1/8" x 1/16" piece of aluminum, bent at 45 degs into trigger hollow, approx 1/4" sticking out to actuate the micro-switch and after a day or two for the epoxy to harden it should work just fine.
Posted on Feb 13, 2008
SOURCE: No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Posted on Feb 25, 2008
SOURCE: Russell Hobbs Steam Glide 2200 won't produce steam.
I had a problem and tracked it down to the pump. If you take the iron apart, the pump sits towards the front of the iron and has 3 tubes connected to it. Remove the srew-down bracket and free the pump from the plastic clasps on the base. Disconnect tubes and wires (remembering where they go.
Remove the circular securing spring from the front of the pump and drop the metal barrel from the housing. Unscrew the rear plastic assembly and set aside. there is a joint inside where the plastic assembly was - this is has an o-ring and is simply a pull-apart. It deos not need screwing. Pull the metal barrel apart, taking care to note the sequence for reassembly. Inside the barel is a larger rubber washer. Pull on the metal tube that goes through the centre of the washer using a pair of pliers - it will come free.
You will then see the problem - the spring inside the metal barrel will have broken. Take care, because at the other end of the spring is a small plastic washer that must be retained. Find a pen that has a short spring inside and use this as a replacement. If necessary, you can trim the spring to make it the right lenght. Ensure you have removed all broken pieces of spring, and reassemble. Try it out before finally attaching the pump inside the iron. It took me 2-3 attempts to get the spring tension right. If you can find a 'PENAC RB-085B BA1002' pen, the spring is perfect.
Once you have got it right, reassemble.
I have to replace the spring approx every 6 months as the replacement is obviously not meant for the job and wears or rusts or breaks. However, I am getting extended use from my otherwise broken iron.
Take care - things inside get HOT!!
Hope this helps.
Posted on Dec 17, 2008
  • 43 Answers
SOURCE: swan steam iron steam coming out of front and leaking water
the temperature is not set correctly for the fabric.
Posted on Sep 18, 2009
DiYerTech
  • 70 Answers
SOURCE: NO STEAM COMING OUT....IRON IS HOT AND WATER IS
Diagostics 1: When pressing trigger, do you hear microswitch click? If not, the plastic tab on the trigger mechanism has broken off. You can pull the plastic cover off the handle with orange stick or thin screwdriver...gently to not scar anything. In other diagnostic threads on this great Rowenta iron there is an appliance store that can get you the parts and is very good.
Posted on Jun 05, 2010
I have a Tefel Protect Turbo Anti-Calc Autoclean Pro Express Iron. When I press the steam button it just pours out water out of the metal plate?
NOT being an expert on Irons but I'd pretty much guess if water is pouring out where steam is suppose to come out, then the heater element that makes your steam is not working.
Jun 09, 2017 | Irons
Water boiling inside but no steam wants to come out
Ronel:
The steam port is clogged up with lime. get some vinegar or CLR (calcium lime and rust remover from home depot or lowes or any store like that. Pour the water out of the iron and put the CLR or vinegar in the iron and let it sit for a while. Plug the iron into the wall and let it get hot. It should steam in a while... be careful that you do not breathe in the fumes.
Jun 20, 2015 | Irons
Gravity feed steam iron
If you have been using tap water in your iron, and your water has lime or calcium in it, then the iron is probably clogged up. You might try using a product like "Lime Away". Read the warnings on the bottle first. Don't get it on your skin or in your eyes. Don't breathe the mist or steam. The bottle I looked at also had warnings about how it would mess up some counter tops or sinks.But if the iron doesn't work anyway, carefully pour some into your iron maybe about one fourth full, then carefully shake the iron to get the stuff all over the insides of the iron holding the iron like you would if you were ironing. Let the iron sit for a bit, then shake it again, maybe a couple more times like that. pour it out into an old bowl that it wont ruin, and see if there are a lot of minerals in the liquid. If there are, that may have cleaned it enough to start working again. Pour enough water in the iron until it is half full, plug it in and turn the temperature up to where it will produce steam, but don't iron any clothes yet because there is still cleaner in the iron. turn the iron so it is like you are ironing, but don't let it touch anything. Hold it over something like some old rags. If steam comes out, don't breathe it, but let it come out for a little while. Pour out that water and refill with fresh water and let it steam over the rags again. Pour that water out and all the chemicals should be flushed out of the iron. Carefully wipe the hot plate off to get any chemicals off the plate. Good Luck
Nov 02, 2013 | Irons
Philips steam iron no steam and red tap light is flashing even when filled up with water it's still getting hot and water is boiling but steam fiction not working as red light will not go out
It sounds like the flow holes are CLOGGED with scale inside. To clean it out:
1. Drain the water/steam out the pour-in shoot at the top of the handle, over the sink. Is any crap coming out?
2. Take some VINEGAR and pour it straight into the fill pour-in shoot. Don\'t dilute it. Fill up the IRON to full line. Let the vinegar SOAK the inside of the COLD iron for 15-20 minutes, by placing it FACE DOWN on an old bath towel, on a heat-resistant surface, such as a granite counter top, or metal cookie sheet. Don\'t put the towel on the ironing board!!! It may get stained badly. Let it sit, COLD for 20 minutes. You can swirell the vinegar around by shaking the iron.
Stand it up on its flat end, with the vinegar inside, still. Take some fresh vinegar and dip Q-tips into the vinegar and clean the slots and holes on the bottom plate. Any burn streaks or soil can be removed with wiping the plate with vinegar. After you clean all the holes and slots with vinegar from the outside, TURN ON THE IRON with the vinegar inside. The vinegar will heat up and should come out the holes. If any holes are not blowing vinegar/steam, clean them with q-tips again. Don\'t let all of the vinegar inside steam out!! Just heat it enough to make sure all of the holes are clean. Some white film may come out of the holes on to the face plate--it is calcium build-up from using tap water in the iron.
Now DUMP out vinegar inside the iron and reservoir through the pour-shoot You may see crud and crap coming out. Repeat the process of filling it up, steaming through the holes etc. until the vinegar comes out clear!!!
DON\'T use tap water in any IRON. Use distilled water, or even bottled drinking water (without flavoring, additives, of course). This will prevent corrosion and calcium build up in the iron.
ALWAYS completely drain the iron from the pour-in spout each time you are finished using it!! After pouring out the tank\'s water, you can set the iron to STEAM HIGH, and force any water inside to boil off and out of iron.! Never keep water in the reservoir or iron.
I set my iron, when hot, and done using it, with the pointed side DOWN in the sink drain to make sure it is dry.
So clean it with vinegar often, use bottled drinking water or better, distilled water and it will prevent this.
Oct 24, 2013 | Irons
Shark sc618
Are you using distilled water? May be clogged with chemical residue that shows up by the residential water treatment process if using tap water from your faucet. When tap water evaporates (i.e. steam) it will leave deposits. Try mixing a solution of a small amount white vinegar with water to see if it breaks up. Heat until hot and then turn off. Be sure to 'flush' by pouring out and refilling with fresh distilled water after heating it up and letting it sit a little bit first. If successful only used filtered water from now on.
Sep 29, 2013 | Shark Euro-pro Sc618c Steam-in-a-bottle,...
I have a hinari steam generator iron and the steam has stopped coming through the iron and now coming through the base that the iron stands on!can anyone help please
Check the water reservoir of the steam generator and look for some hairline cracks. Also a clogged tubing will likely to go back water on reservoir inlet water pouring. Once you found the cracks, seal it with epoxy just enough to fill the cracks.
Thanks for asking.
Jul 13, 2011 | Rowenta Steam Generator DG050 Iron
While ironing with steam, scale deposits came out through holes. how do I clean iron
You can try this out, fill the Iron with a considerable amount of water, Switch On your Iron, Increase the heat controller Knob to the maximum so that the water boils and Place it Upside Down (As if you want to Iron) but dont let it touch the Pressing Table. Then keep pressing the button that disperses the steam until the whole water inside it finishes, repeat this same process over and over until it comes out clean...
(Alternatively however, you can just pour hot water though the water-inlet hole, and after a while, shake the iron and turn the water out upside down and let it pass out of the water-inlet hole...but please be careful with this second method though...because of the hot water)...hope it helps.
Jul 10, 2009 | Sunbeam 4214 Iron
Rust coming from iron
See if you can get a hold of some CLR (Calcium, Lime, and Rust). It's a cleaner most drug stores and hardware stores carried in the states. Pour that into the system and then flush it out. Make sure the CLR isn't in the iron before you use it again.
Use filter water in your iron in case there is rust or sediment in the tap.
Aug 11, 2008 | Rowenta Powerglide DM273 Iron
Irons Logo
77 people viewed this question
Top Westinghouse Irons Experts
Are you a Westinghouse Iron Expert? Answer questions, earn points and help others
