Question about Carrier Heating & Cooling
E6 code Flashing on carrier programmable thermostat
  • 6 Answers
SOURCE: my programmable "Carrier"
blown fuse on circuit board, or transformer dead, or hot (red) wire disconnected or broken somewhere in circuit.
Posted on Feb 16, 2009
nanbuenbrazo
  • 553 Answers
SOURCE: install programmable Carrier thermostat
you'll be needing an assistance from an A/C technician, If this a progammable you want, some configuration need to be done and a technician can only do that.
You can search the web for a local carrier dealer nearest to you
Posted on Nov 05, 2009
  • 141 Answers
SOURCE: Carrier programmable thermostat
if it takes batterys pop some in and see if not it gets the power from the indoor unit
Posted on Apr 06, 2010
  • 674 Answers
SOURCE: Carrier 6 wire, installed programmable hunter ther...
Is this a heat pump? Look in the thermostat. You should have something like the following.
Red wire to R terminal
Green wire to G terminal
Yellow wire to Y terminal
White wire to W or W1
Blue or Orange wire to the O or B terminal
Brown wire to C terminal.
Let me know what you have in the thermostat. The wire colors are not always the same.
Posted on May 23, 2010
SOURCE: Carrier Programmable Thermostat - E5 Code
I "rebooted" the thermidistat by opening it up to disconnect it from it's power supply, waited 30 sec, and closed it up again. After a few seconds E5 went away and the indoor temp appeared. The A/C started up after about 5 minutes. It seems to be working normally.
Posted on Jun 24, 2012
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
How do you re-set error code for "change filter" when filter has been changed on Carrier programmlbe thermostat
Clean Filter Feature -
The thermostat will display the CLEAN FILTER indicator when it is time to change the filter. Press the Reset Filter button to restart the timer after the filter has been changed or cleaned. Helpful?
Dec 28, 2010 | Carrier TSTATHCP Programmable Thermostat...
E1 code flashing
E-1 Room temp sensor which if fixed in front of the coil is defective replace it. Helpful?
Dec 20, 2010 | Carrier TSTATHPP 7-Day Programmable...
Help please. We lost instruction manual for our Carrier programmable thermostat. Not even sure what model but looks like a EDGE TP-PRH01-A. It says "Check Filter".
check filter is a setpoint left in the program of the thermostat it does not effect the thermostat peformance check carriers web site or google that number may come up but that reminder does not effect the function .
Aug 20, 2010 | Carrier TSTATHCP Programmable Thermostat...
Apr 06, 2010 | Heating & Cooling
Install programmable Carrier thermostat
Nov 05, 2009 | Carrier Heating & Cooling
Ok what you need to do is call your local service company and have a technician come out and check your Thermostat, its currently not able to read humidity probably due to a power surge
Apr 28, 2009 | Carrier Heating & Cooling
Carrier Thermostat Displays Error Code E3
Carrier Air Conditioning display an error code E5 and then swtich off
Apr 01, 2009 | Carrier TSTATHPP 7-Day Programmable...
Heating & Cooling Logo
218 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
