Question about IBM Computers & Internet
Repeated beep sound
4 beep sound continously
    Problem Solver:
  • 14 Answers
Http://www.computerhope.com/beep.htm
Posted on Nov 28, 2013
My whirlpool white magic 650 P produces contineous beep sound while connected to the electric plug. However the power switch and light indicators on the mechine is not working.
Sounds like you have a control logic issue. Either a button on the control panel is stuck, or the control board is defective. Find the model number on the unit and post it in the comments please.
Jan 11, 2015 | Whirlpool Washing Machines
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
A continous beep sound is hear in my ups..........wat shall i do now
Continuous beeping can be an indication that the battery needs replacing, especially if you have had this UPS for awhile
Feb 22, 2013 | APC Back-UPS ES 350 - UPS ( external ) -...
Product Name : Intel Motherboard Dg31gl Type : Mother Board Problem : 3 beeps continously then space then sham four then space again space again its repeating d same give me any solution
Replace the processor. The 3 beeps means its the processor at fault..
continuous beeps with space in between means its the rams.. No beeps at all means its the clock speed.
from what your saying it sounds like the processor.
Dec 28, 2012 | Computers & Internet
Does not accept any RAM, continous long beep
blow off the dusts from RAM slot and fix the RAMs,, if still continous the beep sound get new RAM and Fix it
Jan 18, 2010 | Intel Motherboard
I have thinkcenter machine when i boot the machine continous beep is originating first small beep and then continous beep and behave like this and system does not boot please suggest
Yes those beeps are a beep code. The way it is currently beeping means you have a bad RAM stick. Open case and make sure the RAM is seated correctly, sometimes it can come loose. You can also take one stick out if you have two and reboot. If it does it again then take that RAM out and replace it with the one you took out. If it still beeps then you need to buy new RAM. That will correct the problem.
Please rate this solution with 4 diamonds.
Mar 06, 2009 | IBM ThinkCentre A51 PC Desktop
Able to boot the system but with continous beep sound
Sounds good to me, Betcha, you hit it on the head with Battery.
Nov 10, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Beeping M791G PCChip MotherBoard
These are called "Beep" codes. Most motherboard are the same codes, for instance 8 beeps then repeat is a video memory issue. See this site for details:
http://www.amptron.com/html/bios.beepcodes.html
It could be a mis pluged in ram or card. OR a failed motherboard. This site should help.
Nov 09, 2007 | PC Chips (M791G) Motherboard
Won't Boot
how much beeps it doing 1-2-3-4????
Nov 09, 2007 | IBM ThinkPad T23 2647 Notebook
Monitor did not responding
When you first power on a computer it checks itself out for proper operation even before you see anything on the screen. This process is called Power On Self Test, as no video is yet displayed and moreover there may even be a video problem the computer sends out beeps over its internal speaker to indicate its status. Usually you will just hear one beep then the computer will "come to life", if however there are any problems you hear a series of beeps. For a description of these beeps and what they mean please click here. Hope this helps !!
http://www.customautomaticsystems.com/ShowArticle.aspx?ID=54
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
24 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
