Question about Ovens
Oven wont heat on bake or broil. Tempature reads 100 and stays there
watugot
  • 290 Answers
SOURCE: OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Posted on Nov 24, 2007
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
SOURCE: Bake element does not heat
After removing the racks, rack rails and the back plate I removed the 2 screws the hold the bake element. Lifting the front of the bake element up and carefully pulling the element out and gently moving the element so the connector clear the hole I was able to disconnect the wire. After testing for continuity with an ohm meter (non found) I determined the element need to be replaced. $37 and 45 minutes total.
Posted on May 29, 2008
SOURCE: Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Posted on Apr 09, 2009
  • 3230 Answers
SOURCE: GE JTP 1580W288 Set oven to Bake, switches to broil at bake temp
The F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
How to remove and replace the temperature sensor. In most GE ovens, when you open the door, you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left. It's about six inches long and a bit more than 1/8" in diameter, held in place with two screws.
Turn off the circuit breaker (built-in ovens) or unplug the range before attempting the replacement.
The replacement sensor will come with instructions, but basically it's a matter of removing the sensor, pulling out the wires to where they are connected and disconnecting them. You may have to snip. The replacement sensor will come with high-temp wire nuts to hold the new connection. Polarity doesn't matter; it's a straight resistance thermocouple. Hook it up, be sure you poke the connections back far enough so that they're on the other side of the thermal insulation and not resting against the back of the oven.
If you continue getting the F2 error after replacing the sensor, then the problem is likely in the control module - this is the circuit board behind the keypad and clock.
You'll need to remove the decorative bezel to get behind the control panel. Remove screws and set off parts in order - it's not complicated. Once the bezel is off there are two more screws that hold the panel in place. Then you can lift the panel up about a half inch and pivot it forward toward you. You'll see a bunch of wires going to a circuit board.
On the panel you will notice some black plastic boxes that say "Potter & Brumfield" on them. These are relays. Check the relays - slide the black plastic cover straight up to expose the coil and the contacts. The coil, when energized, closes the contacts - look at all the relays. You can manually close the contacts with your finger (be gentle). If the contacts of one of them are stuck, they might be welded together. You can fix the problem by prying apart the welded contacts gently with a knife blade. Take some time to gently polish the relay contacts with a folded bit of fine grain sandpaper - this will get some more life out of them. Be gentle and careful - the relays aren't complicated but if you bend the contact or rip it out, you'll have to replace the controller, which will set you back a couple hundred dollars. If you unstick and burnish the relays, they will probably eventually weld together again as the rough spot will spark, but when you burnish them with sandpaper they should be good for some more life before they need to be replaced.
If the problem isn't the temp sensor or welded relay contacts then the problem is obviously somewhere else, but temp sensor and relay contacts will account for the lion's share of F2 errors.
Once again, be safe, be careful, be gentle. Ovens are not very complicated and they're tough, but always exercise care. Always disconnect electricity before messing with them.
good luck,
Posted on Jun 28, 2009
No heat when fan oven is turned on
do you have to set a tempature in for bake or broil etc.
Jan 28, 2015 | Ovens
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
Feb 12, 2014 | Ovens
My bottom oven ( non-confection) will not go on-it will just sat 100 degrees but won't get warm or hot. Top seems to be working fine. This started after I tried to use the self cleaning feature.
If broil and bake do not work on your bottom oven, it is probably your lower thermistor or control board. If the bake works but broil doesn't or broil works and bake doesn't, it is very likely your heating element. With an ohmmeter, the heating elements should be about 40 ohms. Much higher or lower signals a problem. If you suspect the control board is the problem, they can be repaired quickly and reliably at www.fixyourboard.com
Oct 11, 2010 | GE Profile JTP56 Electric Double Oven
My oven wont heat up?
Hello there:
first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you .
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Old kenmore built in oven wont unlock
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Apr 09, 2010 | Ovens
The oven wont heat up.
Hi.
Since the oven has two heating elements, if the oven does not heat up on any condition, and both broiling and baking element are not working, then the most common fault causing the problem is a faulty temperature probe.
The temperature probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electronic oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reaching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven DOP340 wont heat up and the fan doesnt
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Oct 05, 2009 | De Dietrich DOP390 Pyrolytic Electric...
The bake on my oven does not heat up ? what's the problem
Hi and welcome to FixYa.com!
First thing to check is the bake element. Examine it for signs of blisters or cracks. If you have a VOM, check it for continuity. It is likely that your problem is just a open bake element. Very common problem.
Hope this helps you and Happy New Year from the FixYa crew!
Dec 27, 2008 | Maytag 30" Built-In Single Electric Wall...
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Maytag oven will not light
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Aug 23, 2007 | Maytag CWG3100A Gas Single Oven
Ovens Logo
12 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
