Question about Ricoh Aficio MP1600SPF Copier
Ricoh aficio 6001 service code sc555 - Ricoh Aficio MP1600SPF Copier
blueydfox
  • 13 Answers
SOURCE: Ricoh Aficio 2035e SC542 service code
Actually the code is for fuser. Here you go.
To get in the service mode is reset 107 hold clear button.
To clear out the code go into service mode turn off and on machince. If that does not work. The solution is below. Hope this helps.
Fusing temperature warm-up error
The fusing temperature does not reach
the fusing standby temperature of 45oC
(113oF) within 9 seconds for the B135
(35 cpm) 14 seconds for the B138 (45
cpm) after switching on the main power
or closing the front cover, or 40
seconds after reaching 50oC the fusing
roller does not reach warm-up
temperature.
Solutions
• Fusing lamp defective
• Poor fusing unit connector
• Thermistor warped or broken
• Thermostat has tripped
• BICU defective
• Power supply board defective
Posted on Apr 29, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
  • 161 Answers
SOURCE: service mode
call service --- possible bad thermistor (fuser)
could over heat
Posted on May 06, 2009
angelus316
  • 41 Answers
SOURCE: Ricoh Aficio MP 6000 copier with error code SC555
there is no sc 555 on those machines only sc 550 and that relates to what is called a fuser web.It does need to be changed but you can reset it by pressing the following in order
1- yellow clear key
2- number 1
3- number 0
4- number 7
5- press and hold down the orange clear/stop key for 5-10 seconds.
the screen changes
select copy sp
select sp 1
scroll down to SP1902 001 and select
reset that value to 0 and select enter
switch machine off and on and that should get you going for now.
Let me know
Posted on May 28, 2009
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
RICOH AFICIO 5500 - SC555 ERROR HOW CAN THIS BE CLEARED?
press yellow clear then enter 107 and press and hold the orange stop key untill you enter service mode.
select copy sp
press 7807 and then the # key. select execute on the righ on the display
when it says complete turn off the machine from the red power switch. turn machine back on. if error returns repost here .. you may need parts
Aug 08, 2011 | Ricoh Aficio 1224C Black and White Copier
Service Code Error SC555. This machine is not connected to the network. There is not an obvious paper jam. Can you describe a possible fix. Carolann
SC 555 is the main motor error. the main motor needs replacing. its the only solution. the main motor fits at the back of the machine. if you open the back cover, you will be able to see it.
Nov 19, 2010 | Ricoh Aficio MP1600SPF Copier
Mp6001 with sc555 error code
Fusing lamp overheat error (rear)
555 A
After the fusing
temperature reaches the
target temperature, the
fusing lamp does not turn
off for 20 consecutive
seconds.
?? Fusing thermistor defective or out of
position
?? Power supply board defective
u need a servise engineer to reset/fix it
Nov 18, 2010 | Ricoh Aficio MP1600SPF Copier
I need an expert for sc555 ricoh 2060
That is a fuser fault. Can be caused by dirth thermistors on the hot or pressure rolls.
Can be a bad heat Rod. But on a 450, It is almost likely a bad thermistor. It is the flexable temperature sensor that rests on the hot roll to monitor the temperature.
Nov 12, 2010 | Ricoh Aficio 450 Copier
We have a Ricoh aficio 2051sp with error code SC555 what does this mean?
you will need to remove these and test with a multimeter. we are in michigan do you need a ricoh copier service 248-677-8112
Oct 07, 2009 | Ricoh Aficio MP1600SPF Copier
1- yellow clear key
2- number 1
3- number 0
4- number 7
the screen changes
select copy sp
select sp 1
Let me know
May 23, 2009 | Ricoh Aficio MP1600SPF Copier
Ricoh 3800c Error code sc555
SC 555 Pressure roller
fusing lamp
When the fusing unit is not
running in the Ready condition,
the pressure roller fusing lamp
keeps ON with full power for
100 consecutive seconds.
Replace the fusing unit.
Dec 01, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh 3800c error code SC555
fuser related -- call tech to reset --- thermistors
Ricoh Aficio MP1600SPF Copier Logo
52 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
