Question about Other TIM7785-14L TOSHIBA MICROWAVE POWER GaAs FET Gold
Lamp won't work
Need to replace lamp
    Sergeant:
  • 432 Answers
Wrong lamp with just too short feet , need g10 and bought smaller, but ask in the store the use for the bulb
Posted on Oct 13, 2014
Kf 55e200a
if its a dlp check the light engine there is a color wheel inside it may be worn out hence stuck and needs replacement do check that the fans are all working if one is not replce it to cos these r the only moving parts
Jul 15, 2013 | Televison & Video
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
Left headlight
If the other head light works ,it won't be a fuse
Check every fuse in the car,won't take long &
the fuses will protect a complete circuit,not just
a couple head lights.
The light switch has a circuit breaker not a fuse.
Have you removed & tested the lamp it'self
No owners manual? Need that for fuses & bulbs/lamps
Sep 04, 2012 | 2001 Hyundai Sonata
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
My viewsonic 3d projector won't turn...but it has
You should replace the lamp it is already damage, when you replace the lamp do not forget to reset the lamp hour meter.
Aug 22, 2011 | ViewSonic Televison & Video
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
T V won,t come on and timer lamp on front panel stays lit.
Your lamp hours have expired. Try taking the lamp out then putting it back in. The TV will go to a reset menu for the "new" lamp it thinks that you have put in. From there you can reset the lamp hours from the menu. It it doesn't work, the lamp may be burnt, and you have to replace it.
Aug 13, 2009 | Samsung PCL542R 54" Rear Projection...
Timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
Jul 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Other TIM7785-14L TOSHIBA MICROWAVE POWER GaAs FET Gold Logo
654 people viewed this question
Top Other Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Other Audio Player and Recorder Expert? Answer questions, earn points and help others
