Question about Sony Cameras
How to disassemble Sony 70-300 lens - Sony Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
Do you have access to a lens collimator and other equipment needed to ensure proper alignment when reassembling the lens? If not then you may just as well use a sledgehammer to disassemble the lens; it'll work just as well afterward.
Posted on Nov 28, 2013
I want to know how to disassemble my Sony HVR-V1U 20x Zoom Lens
You will need vacuum cups and special screwdrivers or picks to open the lock rings
Oct 14, 2014 | Sony HVR-V1U Mini DV Digital Camcorder
Tip
DVD lens cleaner is not recommended and may void your warranty. A DVD lens...
When your console does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the PS start losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the PS, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
before doing tis, contact Sony to check if the unit can be replaced or repaired by Sony, you find the number on the Console documentation.
Things work in the same way on Xbox, Just contact Microsoft instead than Sony.
on Jun 20, 2009 | Sony Playstation 3 (PS3) Console
How do I disassemble a 20 zoom lens for a Sony V1U camcorder?
Jeff, to assemble a lens, you need a collimator to make sure all optical elements ate correct in place. You need skills and a manual, to be able to adjust all lens elements in a correct order.
Asking this question, I'm sure you don't have a manual, a collimator and you miss the skills. So if you don't want to end up with a pile if glass, unable to act as a lens, please don't try this yourself. Even Sony will not reassemble the lens if you took it apart. If you really need a lens to b cleaned, please bring it to a Sony certified service centre and ask them what it will cost to clean / replace the lens.
How do i get rid of mild fungus in Sony Hybrid handy cam DCR-SR65 lens
Bring it to the camera photo repair shop where they can disassemble, clean your lens. They have the tools and cleaning solution to get rid of lens fungus. I hope my advice give you some idea.
Mar 18, 2011 | Sony DCR-DVD755/E DVD Camcorder
Sony Handycam dcr-dvd610 Lens cover cant close
The lens cover mechanism in these cameras is susceptible to debris and requires disassembling the camera to repair. This can be repaired fairly inexpensively. However, it's not a user serviceable problem due to the fact that the camera will need to be partially disassembled and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Mar 08, 2011 | Sony Video Cameras
My Sony DSC-F717 has mold inside of the lens. How may I disassemble the lens to clean the optics inside?
This is a relatively common job for cameras with removable lenses, but even then, best left to those with expert experience because of the precision required for reassembly. It is considerably more complicated for cameras that do not have removable lenses.
You might try camera stores in your area, but you best bet would be Sony service:
eservice.sony.com
Feb 28, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
Reassemble the camera lens
Hi, i have provided some disassembly and reassembly detail on my blogsite to deal with a loose lens problem. The site has a link to the service manuals which might help, otherwise my detail might be all you need. See: http://howtheheckdididothat.blogspot.com/2010_10_01_archive.html There are lots of pictures and step by step instructions. Hopefully this will fix your problem.
Aug 24, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
You don't have to disassemble the lens. My camera would lens extend , pause and then lens retract, pause again, then lens extend, pause and then lens retract. It would do this maybe 4 or 5 times before displaying "ACCESS" on the screen and then shut down completely.
Where the lens extends from the body is the area I am referring to, there is a tiny gap large enough to slide a sheet of paper into. That is the area I shot a tiny drop/burst of wd40 into. Wd40 is sort of electronic safe and most of it WILL evaporate.If you would like, send me your email address I will send a photo file-picture of how i did it. Hopefully it is the same problem.
jgbhornung@hotmail.com
Just put "camera problem" in the subject box
Jim H
Mar 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Something inside lens
i work with sonys all the time ..I do not recommend disassembling the lens section at all. unless its between lens and CCD imager but I doubt its there..
Nov 08, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Cameras Logo
123 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
