Hitachi codes F2 - Washing Machines
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
SATA Hitachi 1 Tb HARD DRIVEi AM TRYI8NG TO INSTALL A NEW HARD DRIVE ON MY DELL 4700 AND I CANT FIGURE IT OUT IT IS SAYING NO ( BOOT DEVICE NOT FOUND)\
Dear Jackson,
If you are connected your new hard drive, You just have to go into BIOS and set your old hard drive as first boot device . its all. for BIOS choose f2 or f10. Good Luck.
Nov 20, 2012 | Hitachi 1TB External USB 2.0 Hard Drive
HDDunlock.com & http://www.salvationdata.com these are not able to clear the password in hitachi hdd. Any other suggestions?
Hi im not sure about hitachi hdd but
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this works
Sep 23, 2010 | Acer Computers & Internet
I HAVE A HITACHI HARD DRIVE THAT IS LOCKED UP. AND I HAVE NO CLUE THE PASSWORD. HOW CAN I FIND THE BINARY OR GENERIC PASSWORD. PLEEEZ, AND THANK YOU, MR. ROB
You can get rid of the password by going into the BIOS. Press F2 when you see the logo and look around for security options.
If you can't find the hard drive password field, post what model laptop you have and I can be a little more specific.
Sep 16, 2010 | Hitachi SDM320BD 320 GB USB 20 Hard Drive
F2 error
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
You may post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Sep 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
Error code F2-04 and E7-10 on AR-168D
F2-04 is an improper cartridge code and the E7-10 is a shading/lamp brightness issue. I would say the F2-04 is causing both coded, Change the toner cartridge. I have seen those chips on the back of the cartridges cause weird problems. That or the developer unit has failed.
I strongly suspest that once you resolve the F2 issue the E7 will simply go away.
Aug 03, 2010 | Sharp AR-168D Copier
I need a code to work my Hitachi 32LD8D20U from my Sky Remote and Sky can't find one
I went to http://www.satelliteonline.co.uk/sky_remote_codes.htm there are lots of codes and I finally found the one for my Hitachi 32LD8D20U, it is 0065. I only got there by trial and error though because there are so many Hitachi codes. The generic Hitachi code 0145 worked also but just to switch on and off.
Sep 18, 2008 | Hitachi Televison & Video
Dell Dimension 5000
please reset the bios..on dell logo..press f2..press num lock, caps lock ,scroll lock so that all three are on. press alt e
press alt f
select the option that says
save changes and exit
your hdd should get detected.
please post back if it does not work so that i can check out fir further options
May 04, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
My laptop hitachi visionbook plus 5000 would not start up
Look at what the error message is and post it here. Press F1 to continue booting (try this first) Press F2 to enter Bios and make changes to the set-up
Oct 06, 2007 | Computers & Internet
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
