Question about Cuisinart Kitchen Appliances - Others
Cuisinart TB 40 calrod replacement - Cuisinart Kitchen Appliances - Others
The bottom blade in not moving n seems jammed
Have you taken it apart and cleaned it well, checking to make sure it is not bent?
Jan 27, 2013 | Cuisinart SPB-7 SmartPower 40-Ounce...
I am missing the measuring beaker (part CEC-7BK) that is used with the Cuisinart Egg Cooker. They are no longer available in Canada and several US companies don't ship here. Any solutions welcomed.
Hard: 1 egg/8 TB; 3 eggs/7 TB; 5 eggs/6 3/4 TB; 7 eggs/6 1/2 TB. Medium: 1 egg/4TB; 3 eggs/3 3/4 TB; 5 eggs/2 3/4 TB; 7 eggs/2 1/2 TB. Soft: 1 egg/2 1/2 TB; 3 eggs/2 TB; 5 eggs/1 3/4 TB; 7 eggs/1 1/2 TB. Note:oddly, the amount of water goes down instead of up for more eggs.
Dec 02, 2011 | Cuisinart CEC-7BK Egg Cooker Beaker with...
Why does Cuisinart TOB-40 produce steam and condensation on the glass door when toasting?
The bake/toast compartment is almost air-tight, creating an adequate seal to produce steam/moisture when the heat is applied to the water content of the food placed inside.
Mar 23, 2011 | Cuisinart Toaster Ovens
Cuisinart CEK-40 electric knife. Stopped working,
The top section where the blades are inserted, the grey piece, are two sections glued together. Need to separate the halves to have access to the motor, gear and electricals.
Nov 28, 2009 | Cuisinart DCC-2000
GE range two large burners do not work. The two small burners work OK. One of the large burners has an obvious break in the calrod. Could it have blown a fuse or circuit breaker inside the stove that...
Burners went bad, Replace them. You may also have to replace where they plug into. Come problem with electric stoves. Easy fix! You can purchase at lowes, homedepot, or any appl repair parts store.
Aug 22, 2009 | GE JBP30 Electric Kitchen Range
Our Cuisinat dcc200 leaks water all over the counter.
This is most likely a result of a defective washer stopper in the reservoir. I took mine apart by gently pulling the rubber washer over the top of the plastic loaded holder. I lightly sanded it with 220 grit paper until it was smooth and replaced it.. No leaks so far.
I cannot find the replacement washer. It appears the Cuisinart only offers the entire reservoir as a replacement part and that costs about $40 ... Thanks a lot (all for a 99 cents rubber washer.) :-(
Jun 07, 2009 | Cuisinart DCC-2000
Dcc1100 carafe
You can get them at www.cuisinart.com or by calling Cuisinart
Oct 25, 2008 | Cuisinart Coffeemakers
Kitchen Appliances - Others Logo
42 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
