Rear speaker volume - Audio Players & Recorders
    Novelist:
  • 84 Answers
Check wire connection to rear speakers and ascertain the speakers are properly grounded. Using a multi-tester, there should be "zero" ohms resistance between the speaker ground and a nearby nut, bolt, or metal component part of the receiver. Get a cheap speaker and splice the test speaker to see if there's sound when radio is "on." If there's sound, but you can't control the volume, then the volume control knob is defective. The volume knob is a potentiometer, which is a variable resister identical in principal to the electronic fuel throttle of your vehicle. If volume is controlled by 2 buttons, then the button's circuit are not connected to the main motherboard.
Posted on Nov 29, 2013
Rear speakers' volume of X-540 is too low. Maybe 20-30% of the front speakers. I'd like to increase the volume but it's already at max. I'd like to get the same output from the rear speakers as front...
In order to do this, your computer must be able to support 5.1 systems! Seeing as how a person wouldn't buy this particular set of speakers without knowing that information, I'm guessing you have a bit of knowledge under your belt. You need to go into your audio device settings on your computer and you should have the ability to tweak the settings of the rear speakers from your audio controller panel. I myself have the EAX which allows access to adjusting the speakers volumes based on distance from the listener!
Apr 13, 2011 | Logitech X-540 Computer Speakers
How do I set the volume on both speakers?
Go to the stereo fader and balance the volume in each speakers. You can see there L for left speaker R for right speaker and F for front speaker and then R for rear speaker. Put them all in zero to have equal sounds volume.
Apr 06, 2011 | Pioneer DEH-P2000 CD Player
Plugged in to rear green port won't workwont
Make sure switch is on, try pluging it into an external MP3 player.
No sound would be coming from the speakers if nothing is playing on the computer also look at the computer volume as well as the speaker volume control.
Dec 19, 2009 | Dell A215 Computer Speakers
Radio works. volume problems on drivers side front speaker
It sounds like the problem is with the speaker, not with the radio
Dec 04, 2009 | Cell Phones
Replaced rear factory speakers now have low volume
Factory speakers usually have low resistance ( 2 ohm) When replacing speakers with aftermarket, most aftermarket speakers will be 4 ohm. If you want the same sound you may have to buy some resistors to put on the speakers (across the + and -). By putting a 4 ohm resistor across the connectors will now make the speaker 2 ohms which in effect will raise the volume. Depending in what vehicle you replaced the speakers the resistance will vary.
May 18, 2009 | Sony CDX-GT500 CD Player
Speaker Problems
push the "sound edit" button on the remote, it will bring up things like, bass, center spkr, rear spkrs.. change the volume control on the rear spkrs.
Apr 09, 2009 | Samsung YP-U3 MP3 Player
FRONT SPEAKERS HAVE NO AUDIO AND REAR SPEAKERS IMEDIATELY FADE
check all your wires in the front speakers and make sure there coverd
Dec 06, 2008 | 1992 Mercedes-Benz 190
X-540 speakers no sound rear speakers
rear speakers are not designed to put out the same output as fronts. They are for supplemental sound only, to make it seem like there's something happening behind you.
Dec 02, 2008 | Logitech X-540 Computer Speakers
Driving 2 sets of speakers with an external volume control on one set.
I think it's a bad idea to use a simple potentiomenter to do what you want to. You'd be better off using another amplifier with RCA cables in between them. It's not hard to find an old amp that you could use these days.
Sep 03, 2008 | NAD C372 Amplifier
Rear Speaker volume too low
Channel level output can be adjusted in the menu if you have the remote. Set the rear channel level volume higher and the fronts lower if need be, and then turn up the volume. Enjoy!
Jan 23, 2008 | Onkyo TX-SR500 Receiver
35 people viewed this question
 Grubhead
Grubhead
