Question about Heat Controller Heating & Cooling
Energy knight model MSH-012B will not turn on
System will not on even though remote works
2 Suggested Answers
  • 340 Answers
SOURCE: The remote control won't work even though I have
bad remote control may something got spilled on it they do not like to get wet. Tom try google manufacture to get new is their power to the unit tripped breaker.Tom
Posted on Jun 21, 2009
What is the load capacity for a 84 AW white knight tumble drier?
5Kg
White Knight 84AW White Tumble Dryer by White Knight Be the first to review this item
Currently unavailable.
We don't know when or if this item will be back in stock.
  • Construction: Freestanding
  • Control of Drying: Timer Control
  • Display of Remaining Time: No
  • Energy Consumption in kWh at 1400 RPM: 2.5
  • Energy Consumption in kWh at 800 rpm: unknown
  • Energy Efficiency: A
  • Energy Savings Trust Feature: Yes
  • Heating System: Electric (incl. Heat Pump)
  • Height in cm: 85
  • Maximum Loading Capacity in kg: 5
  • Start Delay Option: No
  • Type: Ventilation
  • Type of Loading: Front
  • Width in cm: 59.6
84 aw white knight tumble drier capacity Google Search
Feb 19, 2018 | Dryers
Hi we have an energy knight ac wall unit . Can't operate it since the remote control is broken the model number is 6711A20026U would you have any suggestions?
I would repair the remote. Remotes can be very easy to resolve issues with as long as they are not physically damaged(dog chewing on them etc). Otherwise your best bet is calling the company for a new one or trying a multibrand remote for ac units like the Tado Smart thermostat.
Jan 02, 2018 | Heating & Cooling
Replacement remote for Mitsubushi aircon MSH-24TV, how do we get them talking?
If you wish to buy a genuine remote control, you have to contact the authorized service centre for Mitsubishi. If you wan to buy a universal remote control, you should first check, which brand remote control have setup codes to Mitsubishi brand TVs. If you wish to get this detail, try the links given here. It has setup code list, and setup procedure to many popular brand remote controls. Check and find out which brand remote control have the codes to Mitsubishi, and buy that one according to availability.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 24, 2013 | Televison & Video
Energy knight wall ac unit wont turn on with remote? Model mss-012B
The only thing you can do that is not going to cost you a service call is to replace the remote and hop for the best.
Sep 08, 2013 | Heating & Cooling
Even though the remote has lights on the split system air con. does not respond to the remote. We can operate the system manually but the remote is 'lights are on no ones home'!!
the remote may havce bad battery connections? bad battries? be locked off? remove and replace battries. locate program switch on wall stat. temp set to energy saving mode. set out of temp set up-back mode to run in on-off-on mode non occupied
if helpful please rate me. if not please tell me more.
Mar 03, 2012 | Heating & Cooling
The remote for my samsung ht-tx72 doesn't work even though the tv and dvd reciever lights on the remote work. It doesn't turn on my home theater system. Do I need to reprogram it?
Possibly. Maybe it's malfunctioning.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 12, 2011 | Samsung HT-TX72 Theater System
White knight superdry dryer doesn't heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Abbaka White Knight 38AW Electric Dryer
Energy Knight heat pump refuses to blow!
Does this problem happen when the temperature is below 30 degrees? When it gets about that cold outside, the air outside is too cold for the heat pump to "steal" heat from. On the thermostat you'll find a switch labeled aux or emergency heat. Turning this switch on will operate a traditional coil heater inside the system, providing you with heat. The only downfall to this is that it uses more energy to heat this way. Try turning the fan switch from "auto" to "on". If the fan comes on, then we can rule that out. If the aux heat switch is NOT on, set the thermostat such that the system will try to heat. If the outside unit is running, the problem is either it being too cold like I said earlier, or there's a problem with the heat pump's mechanical system that needs to be serviced by a professional. If the outside unit doesn't run but it should be, check it's breakers at the panel, the breaker inside the electrical box that feeds it, and look to see if there's a reset button on the unit itself. Finally, check the air handler (part of the system inside with the fan in it) to see if there's any circuit breakers or fuses on this unit. Make sure they're not tripped/blown. If none of this helps, you definitely want to get a pro to work on your system.
Feb 27, 2010 | Heating & Cooling
Energy Knight AC Blowing Fuses
My Energy Knight mini split air conditioner does not come on at all, no sound no lights nothing. I have changed the batteries with no luck. please help
May 28, 2009 | Comfort-Aire HMC24AD-1 Air Conditioner
Heating & Cooling Logo
Top Heat Controller Heating & Cooling Experts
jdthefixer
JonSnell Electronic
JonSnell Electronic
Tom Chichester
Are you a Heat Controller Heating and Cooling Expert? Answer questions, earn points and help others
