Washing machine will not spin
I can get a reading of 240 v on two of the motor interfases socket, I changed the c Brushes, i took out the motor, there are 6 input cables, I am getting continuity in 3 pairs, Do you think i have a motor issue or a card input issue
    Genius:
  • 1,198 Answers
Check the capacitor. A dent will ruin it.l
Posted on Nov 29, 2013
Testimonial: "Thanks, Mike. Theres no Capacitor, I went back at it I think the motor is finished. I got power across all three coils and it remains stationary."
  • 1462 Answers
SOURCE: My bosch washing machine wfo2865
remove back panel.remove motor wiring undo two bolts in front. remove belt. motor will pull out.
my experience of these is that often the commutator is damaged hence brushes worn
Posted on Aug 07, 2008
SOURCE: Motor won't spin, with flashing "End" light and 3 beeps
this should be a blocked pump or waste pipe or pressure switch ( round grey disk with small pipe off the drum)
Posted on Dec 20, 2008
barkencoa
  • 3463 Answers
SOURCE: changing brushes on motor of Bosch WFL 2450 washing machine
Remove rear panel of washer, and undo 2 screws that secure the motor, lever motor back with a screwdriver or similar, and unplug motor lead.
Be sure to keep hold of the motor so it does not drop on the floor.
You will see the brushes at the terminal end of motor, remove and replace.
Plz rate my solution.
Thanks.
Posted on Jan 05, 2009
barkencoa
  • 3463 Answers
SOURCE: how to change brushes on beko washing machine
remove rear cover of washer, locate and remove belt.
Unfasten motor ,disconnet motor lead, and remove motor.
Brushes are located at opp end to motor pulley.
Replace if less than 5mm long.
Thanks
Posted on Jan 21, 2009
SOURCE: beko wma 510 w washing
new pump washing machine will not spin or empty. what could be the problem
Posted on May 20, 2009
Why won't the drum spin on my washing machine and can I fix it myself
Very likely the brushes are worn, these are located either side of the motor. if you are able to take the motor off the machine but don't know where the brushes are, take the motor to your local repairer who will probably change the brushes for you at a small fee plus brushes. if you are able to identify the brushes and can take them off, the carbon inside the brush holder should be no less than half and inch long. If its less they are probably worn out. get new ones and replace. be careful the carbon brush is very brittle and will break easily. I can't be more specific on changing the brushes as each machine is different.
Oct 17, 2014 | Tricity Bendix Biw125w Washing Machine...
Bosch washer won't agitate or spin
brushes are spring loaded you take your motor out of the machine and replace them your machine will work
Jan 06, 2014 | Bosch WFVC3300UC 300 Series Vision Front...
Bosch FD8805 washing machine rinse light was on but nothing working replaced brushes on motor were well worn down but still no response machine dead apart from flashing rinse light dn
Plug off the power cord from the wall mains. I give you several alternatives, sort out thru the easiest: Note your brand and model. Check on YouTube for change of motor brushes. Then disconnect your motor and check your brushes; follow noting how you dis-assemble so you can re-assemble easier. If your brushes are less than half an inch long get new brushes (thru this very site Fixya) and refit; actually this is quite easy. The spin has a lot to do with worn motor brushes. Manufactures want you to dump machines and buy; it helps them all. Not you - you shell out bucks.
If you have already cleaned out your filter, which is usually just under the tub (be prepared for a lot of water; and disconnect from the wall power socket), your washer still may not spin. So look into next para below. The tech sheet is usually taped to the body of the washer inside somewhere.
Note your brand and model. Check on YouTube for change of motor brushes. Then disconnect your motor and check your brushes; follow noting how you dis-assemble so you can re-assemble easier. If your brushes are less than half an inch long get new brushes (thru this very site Fixya) and refit; actually this is quite easy. Thespin has a lot to do with worn motor brushes.
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been overloaded and shut itself off.
There is a big connector located at the motor - giving power to the motor (located under the tub) to the right side, could be loose. Disconnect the connector and refit to make sure it is tight. Before refitting the back, etc, try the spin alone; if it works you are done.
Click if helped pl, at my solution. I am doing this for the enviro. (& you)
Apr 05, 2013 | Bosch Washing Machines
Avantixx 7 doesnt spin
If you have already cleaned out your filter, which is usually just under the tub (be prepared for a lot of water; and disconnect from the wall power socket), yourwasher still may not spin. So look into next para below. The tech sheet is usually taped to the body of the washer inside somewhere.
Mar 29, 2013 | Bosch Washing Machines
Classixx6 will not spin
Mar 28, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Front load washer not spinning out
You may have damaged the motor brushes, if the motor is too strained it can burn out the brushes, In some cases it can also damage the machine electronics.
Mar 08, 2012 | Frigidaire Washing Machines
Clicking sound on Washer Spin Cycle
You are quite correct in thinking that it is the motor brushes that are worn.
You need to remove the motor and replace the brushes.
This will solve your problem.
Good luck.
Nov 28, 2009 | Bosch Axxis WFL 2060 Front Load Washer
How do i change the brushes on my wma35 hotpoint washing machine so that it'll spin?
unplug first then remove top cover motor should be there remove motor 2 bolts then u can change brushes
Jun 30, 2009 | Hotpoint WMA30 Front Load Washer
Trying to change the carbon brushes but can't find a socket the right size any ideas?
all done it was the brushes on both sides of the motor and borrowed a tool set to do it only cost £7 each and the machine is back on
Apr 28, 2008 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
